Steve, glad you found that link useful and that also the comments have not caused offense. It can be all to easy for people to take these sort of things the right way and throw their teddy out the window.
I like the idea of a company orientated GB. I had thought about doing a German one before but the timing has not been right. Like many here I am also interested in the history behind the builds and I like the idea of GB's run dates having some link to the subject.
Your June start date is a great idea as hopefully by then we will have a few less GB's and it give you plenty of time to get a feel for it. I would suggest looking at some of the GB's and seeing the different ways in which they are laid out. I like to have the first post for the rules etc and a second for the roster and completed builds. Other do this all in one post. Some people will put the completed pics after the roster others will put them within the roster and so on. Just see which you like the best and which you think will be easier for you to organise.
Once the GB has started, its important to keep on top of it and try and post regularly yourself. If it goes quiet for a while, just stick with it.
If you plan on doing a feeler, I would suggest about 2 or 3 months before your start date. So that would be the start of March or April in this case. You can iron out the rules, deal with any confusion, with a subject like this you might well get questions about whether certain subjects are aloud.
For example, Boeing now own McDonnell Douglas and N American. So would aircraft built by these companies before the acquisition be included. I think a build like this is not as straight forward as something like an Fw 190 build for example, so may need some thinking about.
Also you can get your badge sorted, if you are not sure how to do one, someone else will be able to help. Then I would plan on starting the GB build thread one month before your start date.
I will defiantly be in on this one. I have a couple of B-17's including an RAF Fort I I would like to build.
CheckMate, I used the Junkers company logo for the Stuka GB badge, and didn't have a problem, but as the company is now defunct, I am not sure if that would make a difference. I like the idea of using the Boeing logo, but it might be worth Steve just checking with Tim or Aaron first.
