Steve - That is just... OMG! I can barely handle the 1:72 PE work I do. I have barely enough patience to do maybe 2 or 3 parts in a sitting!
Doug, nice job on the Panzer!
I finally finished the decals on the A-10, sealed it all with some Testors Glosscoat, and started on the panel line pin wash. I am using artist oils and turpinoid thinner. I applied a drop here and there along the line and it flowed along the line. I wait a bit then wipe it away with old t-shirt rags.
The deeper recesses may require multiple applications as the paint tends to clump up a little in the larger gaps.
Mistakes can usually be rubbed away and sometimes I may need to hit some spots with a swab and a bit of the turpinoid thinner.
Also hit the upper wing of the F-8 - I have to be more careful here as the turpinoid can soften the paint. I can't let it pool too long.
Inside the gear bay - the thinner did start to soften the paint here and it could have worse. I should lay down a coat of the lacquer first. The thinner doesn't affect it.
I know that top side of the bay looks a little rough here (plane is actually upside down) but it wont matter because the other door mounts there.
Jim
