Fourth Annual Berny Memorial Group Build
    November 2010
Posted by Son Of Medicine Man on Thursday, March 19, 2015 6:30 PM
Nomad53
Wow agsin Steve. I too would go blind.
Jim those panel lines look sharp. Great job.
Okay Ken here are two photos of the finished Pz IV. The panzer is from the 12th SS Panzer Division Hitlerjugend ("Hitler Youth") a German Waffen-SS armored division.
  Doug
PS Ken you pick the one you want to use for the completed page.
Great job Doug!  Well done!  Yes  Yes  The front page has been updated.
Ken
    July 2014
Posted by modelcrazy on Thursday, March 19, 2015 11:26 PM
Great job on Paula Doug. Yes Looks like it's ready to beat it out with a Sherman.
I finished all 6 Quad Bofors tonight. I have several duel and single to make still. I think I'm going to take a break from guns for a little bit and work on some superstructure tomorrow night. There's plenty of PE for that as well.
I know all the barrels don't look perfect, however some of the muzzles were broken off when removing them from the tree. I found out the hard way, they are very brittle and very hard to reattach. If anyone builds this kit in the future, be aware of this.
Steve
    May 2014
Posted by Nomad53 on Friday, March 20, 2015 5:29 AM
Nice job again Steve. At that scale I doubt  if anyone will see the breaks in the barrels. How do you glue the small PE parts? I would have CA all over the place. I have a kit coming up that has PE and resin parts. I have worked with PE but very little. I have never worked with resin.
Please any help with gluing PE and working with resin parts is needed.
Thanks
Doug
Thanks Ken for posting the photo.
Nomad53
Posted by Gamera on Friday, March 20, 2015 7:58 AM
Doug: Very nice work! I think I said before I really like the figures, I think tanks look kinda drab without a figure or two to give it some 'life'.
Steve: Ok, well six isn't too bad I suppose. Still sure you're glad they're done and curious here as to what part of her you're building next.
Btw: I finished painting the Hellcat, or at least she's to the point of decaling. The colour demarcation line should be a soft edge but I've read in 1/48th the line would look hard so that's what I went with. I had some issues with the edge on the wing leading edge but I decided to quit while I was ahead before I messed something else up repainting.
    July 2014
Posted by modelcrazy on Friday, March 20, 2015 9:32 AM
Thanks guys for you kind words. I'm having a blast with this build.
Nomad53
Doug,
I place a drop small puddle of medium or thin CA (I personally prefer Bob Smith Industries CA) on a piece of plastic (you know the plastic bags that the sprue trees come in) and use a sharpened toothpick to get the tiniest bit of glue to the area I'm attaching the part to, or dip the part itself into the puddle. Sometimes I'll spray (or drip) a drop of accelerator on to that same plastic, not in the same area of course, and using a separate toothpick, I'll just dampen, not soak,  the target area with the accelerator. Then I attach the glue laden part to the target area for a faster adhering. Those parts are so small that just the smallest movement with the tweezers will mess up the whole area.
As far as resin, I don't have a lot of experience with it, but again, CA seems to work well.
I have been....I guess you can say...questioned on other threads, for my exclusive use of CA, but it always works for me.
Gamara,
I was planning to work on some superstructure tonight and this weekend. There is quite a bit of the original kit that is removed in areas in lieu of a PE replacement. I'm excited to get into it and see.
Steve
    May 2014
Posted by Nomad53 on Friday, March 20, 2015 12:32 PM
modelcrazy
Nomad53
Doug,
Gamara,
Thanks Steve for answering my question. I will remember that when I get started on my next kit with PE.
Looking forward to seeing the superstructure.
Doug
Nomad53
    November 2010
Posted by Son Of Medicine Man on Friday, March 20, 2015 12:57 PM
Nomad53
Thanks
Doug
Hi Doug,
My preferences and experiences with PE and resin will of course be different than others, but I am glad to share my two cents worth on the topics!  2 cents
For PE, it depends on what I am working with.  If the surface I am applying it to is nice and flat, (for instance an instrument panel) I like to use Future as the glue.  This is because most likely there are going to be dials showing through, and the Future is good to use in the places where the dials are showing to give it an appearance of glass.
Using PE in other areas I prefer to use Gator's Grip Hobby Glue.  It gives you plenty of time to position the part where you want it, it is easy to clean up with water (before it dries), and it is a very strong glue that dries clear.
For resin, one thing you will need is a razor saw for the larger parts.  Almost all resin parts will have a large block of resin that is part of the mold.  You will need to cut this off.  Another note here is that you need to have some type of filtering mask to wear so that you don't breathe in the dust.  After sawing off the block, to get the remainder off you will need small files and sandpaper to finish the area.
Another thing about resin is that you will need to clean the parts to remove the release agents used in the production.  My preference for this is Westley’s Bleche Wite Tire Cleaner.  It is caustic so you have to wear rubber gloves when using it.  Just put your resin parts in a container that can withstand the cleaner and pour the cleaner into it until it covers the parts.  Then leave it soak overnight.  I also go an extra step and use an old long bristle paint brush and gently scrub the parts with the Bleche Wite before rinsing them off.
To attach resin parts to plastic, I prefer using epoxy.  I have not had good luck using super glue.  It comes in different setting times, from 5 minute to 60 minute.  Just remember if using the 5 minute that it sets up pretty quick, so if you’re assembly is complex, you might use the slower epoxy.
Well that is my quick overview for using PE and resin.  I hope it helps you out.  And as always feel free to ask questions.
Ken
    June 2009
Posted by jimbot58 on Friday, March 20, 2015 10:43 PM
Son Of Medicine Man
Nomad53
Thanks
Doug
Hi Doug,
Ken
My view on Photo-etched parts? when I am working with it, I sometimes swear that it has to be one of the most devious forms of self-inflicted torture ever devised by the human mind! However, when I finish and look at the results, I think it was worth the trip! Two of my favorite completed projects are my EA-18G Growler and my A-7D Corsair II, both of which had over a hundred parts to add! Those two models I wouldn't mind entering into a show if one ever comes along!
My best advise is, of course, Patience! And some fine tweezers and a magnifier!
Jim
On my workbench now:
Academy 1/72 SR-71 and Monogram B-52 "Big, Bad, and Beautiful"
    July 2014
Posted by modelcrazy on Saturday, March 21, 2015 12:30 AM
OK, here's some superstructure work. I'm planning on working the bridge and masts this weekend. Looks like I'm starting to make a dent in the PE sheets.
Steve
Posted by Gamera on Sunday, March 22, 2015 8:18 AM
Oh gee Steve, those ladders... I think they would drive me to madness.  Propeller
    January 2014
Posted by jelliott523 on Sunday, March 22, 2015 10:48 AM
Nice work Steve!!!  I'm with Gamera on that one, all that PE would drive me batty!!  I have a couple of kits with some PE and I just keep moving them down in the pile because I'm afraid I dont have the patience to deal with it yet.
    August 2014
Posted by goldhammer on Sunday, March 22, 2015 1:19 PM
Oh, man---After the PE on the Betty, I'd be a blubbering, drooling, crying boob in less that an hour with that kind of PE. Nicely done.  And I have pretty much the full suite donated for the RF4C that is next up.
    November 2010
Posted by Son Of Medicine Man on Sunday, March 22, 2015 1:34 PM
modelcrazy
Hi Steve,
Great job on those Bofors!  They look awesome!  Yes  Yes
Ken
    November 2010
Posted by Son Of Medicine Man on Sunday, March 22, 2015 1:38 PM
Gamera
Great work there Cliff!  The pre-shading looks just right.  Yes  Yes
Ken
    November 2010
Posted by Son Of Medicine Man on Sunday, March 22, 2015 1:43 PM
modelcrazy
Great work once again Steve!  All that work really pays off!  Yes  Yes
Ken
Posted by Gamera on Sunday, March 22, 2015 3:00 PM
Hey Ken thanks, I started decaling her for Lt. Alex Vraciu's fighter yesterday.
I think his name is pronounced Vrack-chew from an episode of the History Channel's Dogfights but am not totally sure.
    November 2010
Posted by Son Of Medicine Man on Sunday, March 22, 2015 3:02 PM
Hi Everyone,
A little more progress on my Zero.  First, here is the seat the way it looked before I started to remove the molded on seat belts:
To remove the molded on seat belts, I thought I would try the new tool I recently bought:
I used the medium grade.  Here it is mounted in my Dremel:
Here is how the seat looked when I finished using the Dremel:
I smoothed it out using some sanding sticks:
Notice how the photo etch seat belts are still attached after all the abusive handling!  They are held on by Gator's Grip Hobby Glue.
Next step is to repaint the seat.
Ken
    July 2014
Posted by modelcrazy on Monday, March 23, 2015 9:52 AM
Boy, I can see why the PE sets for ships cost so much now. It's not so much the manufacturing and materials, it's the time it took to measure and engineer ALL those wee little parts. I was working on the smoke stacks this weekend (I did't get much time between a grandson's birthday, showing the house and family issues) and the grate along the top of the stacks have 13 triangular braces. I could barely see them through my optivisor, let alone pick them up with my tweezers and just dip the edge onto a drop of glue. I don't know if anyone will ever notice all the tiny work I'm putting into this thing, but it should add to the the overall look. I will post pics of those insane smoke stacks when I complete them. Maybe tonight before bed.
In the end, my wife, you guys on the forum and I will know the extent to which I'm going. Ya'll just don't have to hear my string of curses like my wife does.
I also looked, in vane, for a base that would be suitable for the ocean scene. I could't find any long enough to do the "water" justice. Oh well, I will have to make one myself, which shouldn't be too hard. It will just be heaver than I would like. Some plywood and molding for the sides, and I think I have it. I'll start working on that soon and take some pics of that progress as well.
Steve
    July 2014
Posted by modelcrazy on Monday, March 23, 2015 11:07 PM
Here's tonight's progress,
The stacks are done, and it may not look like much but this equates to 2 nights work. The second set of pictures show the PE instructions along with the kits instructions. The 2 small boxes in the upper left are the kits instructions on the left for the mast and gunnery radar, and the 1 1/2  pages on the right are the PE instructions for the same steps.
Steve
    November 2010
Posted by Son Of Medicine Man on Tuesday, March 24, 2015 5:51 AM
modelcrazy
Nice work once again Steve!  You are moving full steam ahead on this!  (excuse my pun!)  Yes  Yes
Ken
Posted by Gamera on Tuesday, March 24, 2015 7:26 AM
Wow, again that's some crazy fine detail work.
    July 2014
Posted by modelcrazy on Wednesday, March 25, 2015 12:11 AM
Ya'll ready for this? The forward mast, radars, and various radio antennas. A tidy nights work if I say so myself.
By the way, It's lying on tissue paper.
Steve
Posted by Gamera on Wednesday, March 25, 2015 7:35 AM
That's just WOW...
I can do PE to some extent but never tried anything like that before.
    January 2014
Posted by jelliott523 on Wednesday, March 25, 2015 7:46 AM
That is absolutely amazing work Steve!!  I'm in awe of what you are doing with all that PE.  I am still intimidated by the little bit that came with my resin cockpit upgrade for my F-4G, I think I should quit complaining!  LOL
    July 2014
Posted by modelcrazy on Wednesday, March 25, 2015 8:01 AM
I thought I was intimidated by PE before I started. Now I'm pretty sure I can tackle most anything. I'm a little intimidated at the prospect of painting this thing. I typically try to paint ships as I go.
Steve
    November 2010
Posted by Son Of Medicine Man on Wednesday, March 25, 2015 7:49 PM
modelcrazy
Holy cow Steve!  That is amazing!  Yes  Yes  Another thing I am impressed with is your ability to understand the instructions well enough to assemble this.  I know every photo etch set I have gotten has nothing but pictures.  No actual explanation of how to assemble it.
Ken
Posted by Gamera on Thursday, March 26, 2015 8:02 AM
Well, I've gotten about two-thirds of the decals applied to the F6F and she's starting to look like a Hellcat. Still haven't found the missing decals for the Wildcat, if I don't find them by the time I'm finished decaling the Hellcat I'm just going to improvise.
    June 2003
Posted by Duke Maddog on Thursday, March 26, 2015 1:45 PM
Looking sharp Gamera! Way to go!
    June 2009
Posted by jimbot58 on Thursday, March 26, 2015 1:53 PM
Son Of Medicine Man
modelcrazy
Ken
I agree! That looks amazing!
Often I find instructions on these sets to be a bit vague at times. Couple that with the fact that I seem to have 10 fat, meaty German sausages attached to the ends of my hands where fingers should go! They always seem to be in the way! Not to mention the effect of aging on my vision!
It is worth the aggravation though!
Jim
    November 2010
Posted by Son Of Medicine Man on Thursday, March 26, 2015 4:49 PM
Gamera
Hi Cliff,
Your Hellcat looks great!   Yes  Yes  The decals do make it come alive.
Ken
