Floats and Boats: Amphibious Aircraft Group Build
    July 2014
Posted by modelcrazy on Monday, January 4, 2016 1:30 AM
It's my turn, I will be building the 1/48 Hasegawa A6M2-N Type 2 Rufe OOB.
My thought here is to display it tied to a beach similar to this photo using resin which will be a new technique for me.
This should be a pretty quick build. I will also be trying AK Interactive Worn Effects for the weathering for the first time.
So with that being said, here I go. I just have the office completed.
Steve
    November 2008
Posted by plasticjunkie on Monday, January 4, 2016 7:38 AM
Off to a great start Steve. I will be watching this one as i want to do the same theme with my Jake and have never modeled water.
 GIFMaker.org_jy_Ayj_O
    June 2014
Posted by BrandonK on Monday, January 4, 2016 9:07 AM
Me too. I've been thinking about a beach scene for my kits also. We'll see what happens.
Nice work on the pit, Steve. Are you planning a chipped scheme?
BK
On the bench: Alot !
On Deck: Alot more !
    April 2006
Posted by jgeratic on Monday, January 4, 2016 10:36 AM
Guys, good looking starts, and some very ambitious projects projected too.
For making I water, I found this site quite helpful:
http://www.finewaterline.com/pages/tips&tricks/tips&tricks.htm
regards,
Jack
    July 2014
Posted by modelcrazy on Monday, January 4, 2016 12:35 PM
RunwayOneSixRight
I am actually a paper modeler...if that would be alright.
RW16R
Brandon is the host, I'm just the co-host so I'll ask, but he has the final word, but personally I'm OK with it.
I know you are an airline guy, so which one are you leaning toward?
    July 2014
Posted by modelcrazy on Monday, January 4, 2016 12:41 PM
Thanks Jack for that link. I had it at one time and lost it at some point. The watercolor paper method has never worked for me, although the guys that can make it work really do well.
Posted by Bish on Monday, January 4, 2016 12:50 PM
Ye, off to a nice start Steve, and i wil be wathcing this as well. I won't be doing anything like this with the Dornier, but i recently got the BV 222 and would not mind having it going into water. So i hope you will be posting plenty of pics.
''I am a Norfolk man and i glory in being so''
On the bench: Revell 1/72nd S-100/AMT STAP/ Youngs Miniatures 1/10th Templar Bust
    July 2014
Posted by modelcrazy on Monday, January 4, 2016 1:07 PM
BK,
Yes, I do plan on making the weathering similar to the photo.
Bish,
I will be posting plenty of pics. I also have a WIP thread in the AC section.
    June 2014
Posted by BrandonK on Monday, January 4, 2016 5:56 PM
modelcrazy
RunwayOneSixRight
RW16R
If we are talking about a paper float or boat, sure, that'd be pretty epic. Heck, even if you made one out of iron as long as the build fits the floats or boats theme. It's all good here.
BK
    January 2015
Posted by BrandonD on Monday, January 4, 2016 11:50 PM
Thanks for the kind words, guys. The PE stuff has become a lot less frustrating since I started using Micro Krystal Klear as an adhesive (ditched super glue).
Steve - that looks like a fun build, and that's a great inspirational photo for it. Can't wait to see it come along.
-BD-
    January 2015
Posted by BrandonD on Tuesday, January 5, 2016 12:01 AM
Well, I got some work done on the floats. These things have huge panel lines that you could hide a 1/48 rifle in. All my reference photos show them being pretty smooth, with rivets more than panel lines. So I decided to slather the putty on them, fill them, then run my new ponce wheel over the putty.
I was more than a bit heavy-handed in applying the Perfect Plastic Putty.
But after sanding and the ponce wheel treatment, they came out like this. They're currently drying after being sprayed with primer.
The floats are bare aluminum, so I will most likely need to do a little more seam cleanup on top, since they were a little rough.
-BD-
    July 2014
Posted by modelcrazy on Tuesday, January 5, 2016 12:16 AM
Nice work BD, yikes what a mess that started out.
Well, this is where I'm at with the Rufe. It's going together as expected, pretty easely. Low part count, the only tought part will be the painting.
Steve
    November 2008
Posted by plasticjunkie on Tuesday, January 5, 2016 7:43 AM
BD
You can apply PPP and let it dry completely, usualy about an hour or less. Then take a damp paper towel and gently run it across the panel lines. This will remove most of the PPP and a little sanding will complete the surgery. Along curvrd areas such as wing to fuselage joints i slop on the PPP and let it dry. Then come back with a damp Q Tip and no sanding is necessary. You have better control when the PPP is dry than when still wet.
Steve
I will be interested to see if you try the AK Interactive product for the weathering as opossed to the hair spray method. I think they are about the same thing as far as the chipping effect goes but just curious.
    June 2014
Posted by BrandonK on Tuesday, January 5, 2016 9:09 AM
BD, there is no simple way around filling in those panel lines. Putty, fill, sand, repeat most likely. Looks like you have a handle on it now. That is gonna be a nice kit.
Steve, I too, am interested in how your chipping works out. I've used the HS method with good results, but never the AK way. Please let us know.
BK
    June 2014
Posted by BrandonK on Tuesday, January 5, 2016 4:35 PM
I'm making progress on the Pete. I have the pit completed and the fuselage is now closed.
I painted the pit a mix of XF-61 and XF-71 1:1 ratio of make a close estimate of Mitsubishi cockpit color as I don't have any yet. I then hand painted the rest of the pit and added the decals for the instruments. I then used a new technique with pastels in the pit. I want it to be nice, but still somewhat used, but not worn badly.
I used a rust orange color and heavily dusted whole pit and then blew it off and brushed the remainder away. I then used a green similar to the pit color and toned that down some. Again, I blew it off and brushed away the remainder. I then used a cotton bud and twist wiped the whole thing. This slightly polished the flat areas and high points while leaving dust in the resesses. I like how it turned out and it changed the color just tad to a more rust tone, more befitting a water bound aircraft. More to come later.
BK
Here you can see the before and after effects of the pastels.
    January 2015
Posted by BrandonD on Wednesday, January 6, 2016 8:14 PM
Steve - thanks for the tip on the PPP. I started toying with my Trumpeter Mig-3 last night, and it looks like it is going to have some wing root issues. I will definitely try that method on it. Your Rufe is looking good. Can't wait to see some paint on it.
BK - Really nice job on that cockpit. I'm envious of the skill in that.
-BD-
    January 2015
Posted by BrandonD on Wednesday, January 6, 2016 8:20 PM
I was working on the Lublin last night and got the floats where I wanted them to be, primed them and went to add the braces. There were some minor fit issues, and one problem with the rear bracing being warped.
I decided to cut the struts and re-glue them. I used solvent glue to melt them together, then super glue to strengthen the joint. Test fitting the the fuselage looks good at this point. Some cleanup will be needed on the lower attachment points, but hopefully not too bad.
Next up was finishing the cockpit. These had wooden floors, and I've never painted one before. I painted the whle thing Tamiya buff, then came back with Tamiya flat brown brushed on really thin, leaving brush strokes to hopefully simulate wood grain. I'm ok with where it is, but it's no work of art or anything.
I have to say, switching to Micro Kristal Klear as an adhesive to PE changed my life. This cockpit went together really easily. The Part PE fret didn't include belts, but I am assuming there was some sort of lap belts on these, so I added some from an Eduard set I have.
Now all that's left in the pit is mounting the instrument panel and putting it in the fuselage.
-BD-
    July 2014
Posted by modelcrazy on Wednesday, January 6, 2016 8:49 PM
BD,
Is that the 1/48 Trump Mig 3? Mine gave me fits when I built it earlier last year.
As far as the woodgrain, I always had luck with some thin brush strokes of Burnt Umber oil, thinned slightly with Turpenoid.
Steve
    June 2014
Posted by BrandonK on Wednesday, January 6, 2016 9:37 PM
BD, that looks really killer. The PE pit is awesome. You're really flying on this one.
Steve, as expected the water looks stunning. You may motivate me yet.
BK
    April 2015
Posted by Mopar Madness on Wednesday, January 6, 2016 10:07 PM
Fantastic cockpit!
Chad
God, Family, Models...
At the plate: 1/48 Tamiya Me262
On deck: 1/48 Tamiya Fw 190A4
In the hole: 1/48 Hasegawa Fw 190A4
    April 2006
Posted by jgeratic on Wednesday, January 6, 2016 11:10 PM
Brandon, both the pontoons (need to get a shot of ponce wheel in the photo) and cockpit look pro.  I would never of thought of using a rust colour inside there, but I'm probably wrong to think all cockpits were made of aluminum.
regards,
Jack
    January 2015
Posted by BrandonD on Thursday, January 7, 2016 12:31 AM
Steve - Thanks for the advice on the oil. I'll have to pick up some of that. Yeah, it's the Trumpeter Mig-3 (early version). I'm thinking of adding it to the 1941 Group Build.
BrandonK - Thanks! I have been looking forward to this build since you first posted the feeler, so it was my first priority when the year started.
MoparMadness - Thanks!
Jack - I just have the Trumpeter ponce wheel with four wheels you can switch out (pic below). As for the colors, the framework is a light grey color, and the inside of the fuselage I painted with buff and added a filter to make it look like doped fabric. The floor itself was wood, and I was going for a dirty wood look. I don't believe there was steel on this plane outside of the engine and weaponry.
Now I'm off to the bench to hopefullt get the instrument cluster sorted and the fuselage halves together.
-BD-
    October 2008
Posted by bsyamato on Thursday, January 7, 2016 5:16 AM
modelcrazy
Steve
Lol , i used the same picture as reference for my Rufe and wishing too to complete with a beach diorama. As i'm not used in diorama will follow with attention :)
Not yet decided about the subject for the group Tongue Tied
    November 2008
Posted by plasticjunkie on Thursday, January 7, 2016 9:40 AM
LOL, confusing with two Brandons Surprise BD and BK both have excellent results as usual.
Steve
You need to be renamed the "water king". Man that U Boat is a stunner and can't wait to see what you do with this Rufe. I hope my Jake comes out half way decent in that water setting I want to do.Confused
    July 2014
Posted by modelcrazy on Thursday, January 7, 2016 9:44 AM
Thanks PJ. I hope so too. Being a new method, I'm sure I will have some teething issues.
    July 2014
Posted by modelcrazy on Thursday, January 7, 2016 9:22 PM
Here is an update for the Rufe. I’m at the point of painting as soon as the glue dries. I tried the Worn Effects on the props. The front face of the prop blades are aluminum and the rear face is flat black. This gave me the perfect opportunity to try the effects out on a test surface. I really liked the result and am excited to try it on the rest of the build.
The base is Styrofoam that I shaved and sanded at an angle to simulate a beach. I applied my favorite substance, Acrylic Gel, for a glue, because it has texture and when dry is similar white glue. I then poured some Oregon sand on the gel to simulate beach sand. Later I will AB sand color on the sand since the Oregon sand is darker than South Pacific sand. This will also allow me to spray a darker sand color to simulate wet sand where the waves have wet the beach.
Next I will start adding resin to the base in stages. We will see how this works.
Steve
    April 2015
Posted by Mopar Madness on Thursday, January 7, 2016 10:08 PM
I'll be watching this one for sure.  I'm thinking something similar for my Arado 196 but moored to a wooden dock.  The water will be quite similar since my aircraft will be from a unit near Krete in the Southern Aegean Sea.  Great start!  I might "borrow" a few of your design ideas.  But credit will be given to whom its deserved of course!
Chad
    November 2008
Posted by plasticjunkie on Friday, January 8, 2016 8:00 AM
Great progress and the slope looks very good. You used Oregon sand and I will be using Florida sand LOL. How does the AK effect product compare to the hair  spray method? (assuming you have used it in the past)
MM
Will your Arado be from III/KG 100 stanioned at Kalamaki, Kreta?
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 8:52 AM
PJ,
My guess is that Florida sand is lighter and finer that Oregon sand. The AK worked very well. I was very happy with the results. I have never use the hairspray method but suspect that it's similar.
Here is the prop.
    June 2014
Posted by BrandonK on Friday, January 8, 2016 9:03 AM
Honestly, I'll likely be copying much of the work on the dio, Steve. You are teaching us how to do this. The GB is the push many of us need to do something new. Thanks for showing us the way.
BK
