Floats and Boats: Amphibious Aircraft Group Build
    April 2015
Posted by Mopar Madness on Friday, January 8, 2016 9:36 AM
PJ, that's the one.
Chad
God, Family, Models...
At the plate: 1/48 Tamiya Me262
On deck: 1/48 Tamiya Fw 190A4
In the hole: 1/48 Hasegawa Fw 190A4
    November 2008
Posted by plasticjunkie on Friday, January 8, 2016 10:05 AM
BK is right, this is something very new to me so it's allways great to learn a new trick.
MM
Here's my Arado I did a while back and was featured as an article in FSM. It has the markings you will be using:
Steve
The kit's plastic base got the hair spray treatment to show some rust coming thru. It was kid of small so I attached it to a round wood base.
Found a better picture of the base:
 GIFMaker.org_jy_Ayj_O
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 10:08 AM
Wow, beutiful work PJ. I must have missed that article.
    November 2008
Posted by plasticjunkie on Friday, January 8, 2016 10:14 AM
Thanks Steve. It was the September 2013 issue.
    April 2015
Posted by Mopar Madness on Friday, January 8, 2016 10:15 AM
Ok, I quit!!  What a superb finish.  Is that the Sword kit?!
Chad
    November 2008
Posted by plasticjunkie on Friday, January 8, 2016 10:18 AM
LOL MM thanks. No it's the ROG 1/32 Arado with the Eduard Bid Ed pe set. IMO the pe was an overkill cause the molded details are fantastic.
    June 2014
Posted by BrandonK on Friday, January 8, 2016 1:32 PM
Wow PJ, that Arado just looks stunning. Certainly worth and honerable mention in the completion list.
BK
On the bench: Alot !
On Deck: Alot more !
    May 2013
Posted by hogfanfs on Friday, January 8, 2016 1:45 PM
I remeber the article, PJ! It's a 1/32 RoG 196! He showed the ware marks on the floor boards of the cockpit. Looked fantastic! I've gotten some great ideas from the article, now I need to put them into practice!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    November 2008
Posted by plasticjunkie on Friday, January 8, 2016 3:20 PM
BK and Bruce
Thanks to both. Yes I sprayed the pit black then the RLM02. I then took a fresh #11 blade and carefully scratched up the 02 showing the wear on the floors.
I entered it in the 2012 IPMS Nationals here in Orlando and won a Bronze in the 1/32  Axis Prop category.
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 7:53 PM
I completed the beach and painted the sand. I then taped some poster board around the edge to prepare for a resin pour
I made my first resin pour, and now I know what not to do.
First off, I used a few drops of blue water color to try to tint the “water”. It was like mixing water and oil, just slower. I finally was able to mix it by using the paint mixer. The turquoise color I wanted didn’t materialize, more of a light blue. Not bad but not what I was looking for.
Second, I was hoping the resin would harden fast enough so that running a sealer around the poster board would not be necessary. I apparently did not put enough hardener in the mix for it to harden fast enough and I had leaks. In fact, most of it leaked out. Oh well, this may actually work to my advantage
Ok, lessons learned....so far.
1. Seal the edges. I'm now using white glue.
2. Put in more hardener.
3. Put in a few drops of turquoise if you want turquoise.
Also, I painted the Rufe silver, air brushed the Worn Effects and am ready for the exterior colors.
Steve
    May 2011
Posted by Real G on Friday, January 8, 2016 8:02 PM
Steve, would clear packing tape work for sealing the dams? I use it as a barrier for CA glue, as it will not bond. The tape is smooth and fairly wide, which would seem suitable for your application.
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 8:55 PM
Possibly G. Although getting any tape to adhere to Styrofoam is problematic. Lesson learned, trial and error. The difference this time is, I'm showing everybody my boo boo's and we are learning together.
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 2:03 PM
New progress on the Rufe and beach. I sprayed the Worn Effects, let that dry then sprayed the IJN Grey, let that dry for about a day and a half. This morning I masked and sprayed the green and applied the decals. Interestingly, after pulling off the mask, some of the gray peeled off, which is just fine and adds to the effect. This was probably due to the Worn Effects. The cowl was not glued on yet but it did work on its weathering..
The beach is turning out very well in my opinion. I mixed up another layer of resin and mixed in some turquoise, maybe a little too much, but it is at depth so again this should work to my favor.
Steve
Posted by Bish on Sunday, January 10, 2016 2:11 PM
That is one sweet loking Arado PJ. I will have to go back and check out that article. Still can't get hold of one of these, rare as Unicorn droppings at the moment.
''I am a Norfolk man and i glory in being so''
On the bench: Revell 1/72nd S-100/AMT STAP/ Youngs Miniatures 1/10th Templar Bust
Posted by Bish on Sunday, January 10, 2016 2:15 PM
Steve, great work on the plane and the beach. And thanks for showing us warts and all. Some great lessons there.
What product are you useing to colour the water.
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 2:53 PM
Bish
Its an acrylic mix I made myself. It dosn't mix well in the resin, however this works to my advantage in the end.
    June 2014
Posted by BrandonK on Sunday, January 10, 2016 3:43 PM
Gawd Steve, that plane and beach look sooooooo good. Stunning work going on in here.
BK
Posted by Bish on Sunday, January 10, 2016 3:47 PM
modelcrazy
Bish
Thanks. And as long as the end result is what you want, thats the main thing.
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 6:01 PM
Here's another update. I believe I’m done with the Rufe once I finish the canopy.
I was able to pour quite a few more layers of resin and just about ready to install the build. In fact, once this last layer sets up enough I will set the Rufe on the surface so it sinks into the last layer a bit.
Steve
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 7:03 PM
OK guys I put the Rufe on the “water” and OMG! I am soooo pleased with this. This is actually looking like water! I will give this a few days to dry before I apply the last few layers. I will blow some waves in the last layer for some small surf. Oh boy, I can’t wait!
Steve
    November 2003
Posted by tempestjohnny on Sunday, January 10, 2016 7:32 PM
Steve that is starting to look exactly like the picture
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 7:34 PM
Yeah, I totaly stoked.
    November 2008
Posted by plasticjunkie on Sunday, January 10, 2016 8:08 PM
Excellent results Steve! Looks like real water and the chipping looks great.
    October 2015
Posted by ModelMan68 on Sunday, January 10, 2016 8:44 PM
PJ...your Arado is a work of art....outstanding job Sir....wonderful detail.
Steve...Kudos friend....you nailed it. Great job on the beach and water and the weathering and chipping on the plane is great.
Bow DownBow DownBow DownBow Down
I have really enjoyed both of your guys work!
Jeff
a.k.a.  ModelMan68
ON THE BENCH:  Spending Time With Family and Friends Big Smile
    November 2008
Posted by plasticjunkie on Sunday, January 10, 2016 9:11 PM
Thanks Jeff! I appreciate the kind words brother.
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 10:03 PM
Thanks tons Jeff,
I still have a few more levels of water to pour once this dries completely.
Steve
    June 2014
Posted by BrandonK on Sunday, January 10, 2016 10:33 PM
Simply outstanding, Steve. It's really taking shape, and quickly too. NICE !!
BK
    April 2006
Posted by jgeratic on Sunday, January 10, 2016 11:14 PM
Steve, that is looking mighty good, also impressed how quickly it all is coming together for you.
regards,
Jack
    June 2014
Posted by BrandonK on Tuesday, January 12, 2016 1:16 PM
This would have been something to see take off. Yikes, it's HUGE !!
Posted by Bish on Tuesday, January 12, 2016 1:20 PM
That does look real nice Steve. So how do you blow the water.
