Modern Group Build - COMPLETED - THANKS ALL !!
Posted by Gamera on Saturday, April 14, 2018 1:21 PM
Did you put down a gloss coat before the decals? Though in some cases I've had decals silver anyway. Once the matte coat is on it's kinda hard to correct. I've had some luck with cutting slits into the decal with a super sharp pen-knife and then brushing a little Future over it. The Future seems to seep down into the cracks and crevices and 'seal' the decal dealing with the silvering.
Good luck, I know your frustration.
    October 2009
Posted by JacknewbIII on Saturday, April 14, 2018 2:04 PM
I did not use a gloss coat. Is it safe to assume my newb mistake was that? I assume moving forward I need to gloss, decal then use flat? Thanks for responding. I might try to add some futures now to see what happens. It don't think it can look worse than it does now. I will report back asap!
Posted by Gamera on Saturday, April 14, 2018 2:37 PM
Oh yeah, the silvering comes from the decal not sticking perfectly flat to the surface and light can go under it, bounce off and then come back and you see it as a silver reflection. So you want the surface mirror smooth as you can make it, hence the gloss coat. You probably also will want to use decal setting solution, it makes the decals softer to suck down to the detailing.
Here's a FSM article, the decaling part is down near the bottom.
http://www.finescale.com/how-to/articles/2014/02/build-great-scale-models-part-4
The way I use the Future is it will seep down under the decal and fill in the cracks so the light can't get underneath it. It seems to cure the problem so far.
    October 2009
Posted by JacknewbIII on Saturday, April 14, 2018 10:31 PM
I have been using setting solution so I just need to stop trying to lay them onto a flat finish it seems. Thanks for all of the help and I have done my best to save the problem. I am not thrilled with it but it looks better. I tossed a nearly complete 1/72 P-51 as well today so the modeling God's have not been kind so far this weekend!
    November 2003
Posted by tempestjohnny on Sunday, April 15, 2018 7:17 AM
Jack when you put the gloss down make it as smooth as possible. After decals have dried put another coat of gloss. Let dry again then flat
    June 2014
Posted by BrandonK on Sunday, April 15, 2018 11:02 AM
When I prep for decals now I have learned, as others here mentioned, that the smoother the surface the better. I will gloss coat and then I sand the area to be decaled with 3000 grit paper which leaves a super flat surface free of dust and small defects that can cause silvering. I thing apply decals and follow that up with solvent if needed, then apply the flat clear. I haven't had a silvering issue since I went to the this method. I also quit using Future on the kit at all and I only use it sparingly on canopies now. As the current Future on the market just doesn't harden up like it used to and it creates problems in modelling now that didn't exist with the old formula.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    October 2009
Posted by JacknewbIII on Tuesday, April 17, 2018 1:34 PM
Thanks again for the tips folks. I am dissapointed in the silvering on the decals to put it mildly. Mostly on the tails and if I were not participating in this build I would not be posting the pics because it just doesnt look great. Either way I am nick naming this bird "Lessons learned"! Moving forward its is gloss first then decals. Either way this was a great little kit and I made a few major errors that I can improve on with the next build. I know the wash might be overkill but I got the Tamiya brown and had to see what it looked like on white. Thanks for letting me participate in another GB!
    October 2009
Posted by JacknewbIII on Friday, April 20, 2018 10:21 PM
I should have added that the tricks using the futures mentioned above did help quite a bit on the front decals but for some reason they didn't impact the ones in the rear as much. I have had trouble with the futures coming out a bit thick from the AB and picked up some of the water based alclad gloss to try on the next project. I also saw someone hand brushing the futures prior to decals which is another option I am trying soon.
Posted by Gamera on Saturday, April 21, 2018 7:50 AM
Actually she looks pretty darn good! Nice work!!!
The only decal I can see silvering on is the 'MARINES' logo on the booms and aircraft numbers on the fins. Decals with that much clear material are a pain to get right sometimes.
    June 2014
Posted by BrandonK on Saturday, April 21, 2018 9:42 AM
Jack, it looks really good to me. I have had the same issues and learned from it and moved on. I understand that decalling takes special prep beforehand. When you get the surface smooth, then you are ready for decals. Thanks for taking us along, it looks great.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    April 2005
Posted by taxtp on Monday, April 23, 2018 7:10 AM
Looks OK to me Jack, and great choice of subject.
Cheers
Tony
I'm just taking it one GB at a time.
    April 2014
Posted by lostagain on Tuesday, April 24, 2018 10:03 PM
Jack,
I like this scheme, well finished!
    February 2006
Posted by DantheMan85 on Thursday, April 26, 2018 12:02 PM
Thanks BrandonK.
Thanks Lostagain: Great job on the AH-1S.
Jack: Nice work on the bronco.
Work has been slow on the Tomcat, just about everything but the main fuselage is done. The nose wheel well is a tight fit and there is a gap where the bottom of the cockpit meets up with the wheel well. And up front where the two half's come together there's a nice gap.
 27 by Daniel Smith, on Flickr
 29 by Daniel Smith, on Flickr
This is the best cockpit I've painted.
 30 by Daniel Smith, on Flickr
 31 by Daniel Smith, on Flickr
I painted the wings first before gluing the fuselage half's together.  Those gaps will need some styrene strips to fill those gaps.
 32 by Daniel Smith, on Flickr
 34 by Daniel Smith, on Flickr
 35 by Daniel Smith, on Flickr
 37 by Daniel Smith, on Flickr
 42 by Daniel Smith, on Flickr
While cutting out the canopy the hobby knife scratched the clear plastic, I was able to sand away the scratch starting with 1,000 grit and working up to 12,000 grit paper. Now the fine scratched need to but polished out.
 44 by Daniel Smith, on Flickr
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
Posted by Gamera on Thursday, April 26, 2018 12:09 PM
Nice work. Great job on filling those seams.
    June 2014
Posted by BrandonK on Friday, April 27, 2018 9:28 AM
Dan, seems like those make me crazy when building a kit. One would think that the fit on these kits would be closer than that, but you tackled it just fine. It looks like a TC for sure now. I can't wait to see the scheme you choose.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2006
Posted by DantheMan85 on Friday, May 4, 2018 6:45 PM
Thanks Gamera.
Thanks BrandonK.
Progress on the Tomcat is speeding up, all the seems and gaps have been filled and sanding. Vertical trail, stabilizers, weapon rails(inside the tunnel) have been glued on. I plan to mount the model on a dowel rod. To make painting easier.
 46 by Daniel Smith, on Flickr
 48 by Daniel Smith, on Flickr
 50 by Daniel Smith, on Flickr
 51 by Daniel Smith, on Flickr
 52 by Daniel Smith, on Flickr
 53 by Daniel Smith, on Flickr
There's a nice gap around the nose wheel well.
 54 by Daniel Smith, on Flickr
The scheme I'm going with is overall FS16440 Gloss Gull Gray, Model Master spray can #1929.
 55 by Daniel Smith, on Flickr
 56 by Daniel Smith, on Flickr
Up Coming: ?
    June 2014
Posted by BrandonK on Friday, May 4, 2018 9:37 PM
I can clearly hear "Danger Zone" while I look at this Tom Cat. I can also see the ones from the movie The Final Countdown. Good stuff. She looks great Dan, well done.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2006
Posted by DantheMan85 on Friday, June 1, 2018 6:55 PM
Thanks BrandonK. I finally have to coats of Gloss Gull Gray on the Tomcat now. Some of the rough area's I wet sanded with 2000 grit sandpaper. Have quit a painting list for the airbrush.  Canopy, canopy frame, marker lights, air bag, leading wing edge etc. On top of that my small airbrush air compressor has stopped working, hopefully I can get the F-14 in gloss and deals by mid to late June. Wink
 65 by Daniel Smith, on Flickr
 66 by Daniel Smith, on Flickr
 67 by Daniel Smith, on Flickr
 68 by Daniel Smith, on Flickr
Up Coming: ?
    October 2009
Posted by JacknewbIII on Friday, June 1, 2018 9:03 PM
Dan I actually have one of these same kits in progress right now and am using your build to re-motivate myself. Yours is looking really good so far keep it up!
    June 2014
Posted by BrandonK on Friday, June 1, 2018 10:29 PM
Dan, that looks really good, you are almost there. Too bad about the aircompressor, that sucks. We'll hang out and wait for your finally.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2006
Posted by DantheMan85 on Tuesday, June 5, 2018 7:41 PM
Thanks Jack: I know what you mean. The nose section was by far the worst, poor fits in the nose wheel well area.
Thanks Brandon.
After my small air compressor stopped working I decided to upgrade to one with a tank on it, picked out a Porter Cable 6 gallon unit from Home Depot. With a extension pipe I added my water filter and pressure valve. It worked great. Take two minutes and 39 seconds to full charge up to 150 PSI, it is a load unit but depending on the amount of airbrushing only need to charge it up maybe ounce a day.
Picked up the Neo Iwata airbrush about a month ago, it works great.
For the first set of colors to be airbrushed on I masked up those areas with tamiya tape, then covered the over spray areas with 3M blue tape. The colors where, Model Master Enamel Flat Black #1749, Insignia Red #1705, Testors Steel #1180, Tamiya X-2 White & XF-2 Flat White.
 69 by Daniel Smith, on Flickr
 72 by Daniel Smith, on Flickr
 71 by Daniel Smith, on Flickr
 70 by Daniel Smith, on Flickr
Just about everything else is finished or near to it. Tamiya X-22 Clear was sprayed on the pilot's and there ejection seats.
 74 by Daniel Smith, on Flickr
 73 by Daniel Smith, on Flickr
Decals for the air to air missiles are just about done softening up.
 75 by Daniel Smith, on Flickr
Fuel tanks and exhaust.
 76 by Daniel Smith, on Flickr
Landing gear & air break.
 77 by Daniel Smith, on Flickr
Up Coming: ?
    June 2014
Posted by BrandonK on Tuesday, June 5, 2018 10:01 PM
That's funny, that is the exact compressor I started ABing with. I found it too loud and went to an Iwata compressor, but I still use the other one for on the cars.
Looks like you are nearly there. I am excited to see the final reveal.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Wednesday, June 6, 2018 7:32 AM
Yeah wow Dan, great job on fixing all those seams- looks perfect from here. And sharp work on the figures and the ordinance!
    February 2006
Posted by DantheMan85 on Saturday, June 16, 2018 7:34 PM
Thanks BrandonK & Gamera.
Touch up painting is just about done, glued on the landing gear and the air break today.
 86 by Daniel Smith, on Flickr
 85 by Daniel Smith, on Flickr
 84 by Daniel Smith, on Flickr
 82 by Daniel Smith, on Flickr
 88 by Daniel Smith, on Flickr
 89 by Daniel Smith, on Flickr
 90 by Daniel Smith, on Flickr
The cockpit is a tight fit, will need to make some adjustments.
 91 by Daniel Smith, on Flickr
 92 by Daniel Smith, on Flickr
Up Coming: ?
    June 2014
Posted by BrandonK on Sunday, June 17, 2018 11:38 AM
That is such a good looking build. I can't wait to see the decals go down.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2006
Posted by DantheMan85 on Monday, July 2, 2018 9:19 PM
Thanks Brandon.
All the decals are one, they layed down very well.  The large red and white decals on the tail, and the teeth on the nose is taking the longest to soften up. Cool
 93 by Daniel Smith, on Flickr
 94 by Daniel Smith, on Flickr
 95 by Daniel Smith, on Flickr
 96 by Daniel Smith, on Flickr
Up Coming: ?
Posted by Gamera on Monday, July 2, 2018 9:36 PM
Dan: Oh wow, she looks soooooo good!!!
Funny, you remind me I've got a set of those 'Miss Molly' decals I picked up years ago just because they're so cool looking. I don't even have a F-14 to put them on!
    June 2014
Posted by BrandonK on Tuesday, July 3, 2018 9:08 AM
Dan, I have to agree, it looks sooooo good. I love the Sundowners schemes. That is a great looking TomCat and I can't wait to see it done. I think you are close.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2006
Posted by DantheMan85 on Monday, July 16, 2018 6:18 PM
Thanks Gamera & BrandonK.
I'm happy to say that the Tomcat is finished. After decals I applied three coats of Testors 1261 glosscote. Then brushed on Tamiya XF-86 flat clear on the wheels and inside the cockpit. The figures with the ejection seats where a tight fit. Then I glued on the air to air missiles. I forgot to pull out the glove vanes, I'll post some pictures Tuesday.
Thanks BrandonK for hosting this group build. Big Smile
Next up for me is Academy 1/48 F-15E Eagle. Cool
 98 by Daniel Smith, on Flickr
 99 by Daniel Smith, on Flickr
 100 by Daniel Smith, on Flickr
 101 by Daniel Smith, on Flickr
 102 by Daniel Smith, on Flickr
 103 by Daniel Smith, on Flickr
 104 by Daniel Smith, on Flickr
 105 by Daniel Smith, on Flickr
 106 by Daniel Smith, on Flickr
 107 by Daniel Smith, on Flickr
Up Coming: ?
    June 2014
Posted by BrandonK on Tuesday, July 17, 2018 9:14 AM
Dan, that is a stunning work of art. She looks like she is ready for her maiden launch off the deck. What an amazing Tomcat. Well done, Sir!!
I'll update the front page.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
