75th Anniversary of 1942 (World at War)
    September 2003
Posted by checkmateking02 on Saturday, July 22, 2017 7:17 PM
Great start, stik.  You made quite a difference in the appearance of the seat; much, much better now.
I had no idea the cannon entered the cockpit like that.  Another good piece of information to know.
    July 2004
Posted by stikpusher on Saturday, July 22, 2017 7:21 PM
Thank you CMK. A little work can make a huge improvement!
Yes, the breech of the hub cannon was mounted behind the motor into the cockpit. But apparently Airfix got the shape wrong on their kit. They have it circular instead of square. That might be for the E models, I'm not sure. I think I have something in my spares bin that will work.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Saturday, July 22, 2017 7:26 PM
I've built some -G's in 1/72  years ago, and the cannon didn't show up in the cockpit, so I found this very interesting.
    July 2004
Posted by stikpusher on Saturday, July 22, 2017 8:11 PM
checkmateking02
Yeah, the breech is pretty prominent in there.
       - Plankton
LSM
    July 2014
Posted by modelcrazy on Saturday, July 22, 2017 10:42 PM
Thanks Check.
I’m done with the Zero. The color looks greener against the white background but the Japanese did use a grey green on their Zeros. This was a nice kit although there was quite a bit of small flash that needed to be cleaned if one were to look close. For the price, I would recommend it and I liked the option to fold the wingtips however, I will stick to a Hasegawa or Tamiya kit for next 1/72 Zeke. I think I have 3 more Hasegawa Zero’s in the stash, all model 52s.
The different weathering process I tried was a thick oil wash rather than my usually oil pin wash. I also used oils for the fuel and smoke stains.
Steve
    April 2006
Posted by jgeratic on Sunday, July 23, 2017 12:10 AM
Steve, the Zero looks fanatastic - nice to see what can be done with these new Airfix kits. Yes
regards,
Jack
Posted by Bish on Sunday, July 23, 2017 1:39 AM
WOW Stik, thats a blast from the past. I built that back in the 80's, going to be fun watching this.
Posted by Bish on Sunday, July 23, 2017 1:41 AM
checkmateking02
As Stik says it is rather prominant, but as you can see in the pic, its not obvious that its the gun with the housing around it.
Posted by Bish on Sunday, July 23, 2017 1:42 AM
Steve, awsome job on the Zero. I can see what you mean about the different shade of grey.
    July 2004
Posted by stikpusher on Sunday, July 23, 2017 5:38 PM
Just some minor progress today before work.
Here are the markings from Aermaster that I will be using
Then I did a little work in the cockpit. I filed the hub cannon housing to shape it more like the actual item, and I scratched up some rudder pedals. They are not exact, but they look better than what was there, and will hardly be visible once the cockpit is sealed up...
Just about ready for paint in there...
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Sunday, July 23, 2017 9:48 PM
Bish
 checkmateking02
Back in the '80's I was on a 109 kick and built quite a few, but had trouble locating an "F."  I still have them in storage, but I think the only "F" available was from Heller, or maybe it was Jo-Han.  It's been years since I looked in on them; maybe time for a visit.
Looking good, stick.  Always like the lines of the 109.
    September 2003
Posted by checkmateking02 on Sunday, July 23, 2017 9:51 PM
Unlike over at the Midway GB, these photos came through fine as jpegs.  I'll use one of the first two here, and the other one over there.
Thanks again for participating in this GB.  It's always a pleasure to see what rolls off your production line!
    July 2004
Posted by stikpusher on Sunday, July 23, 2017 10:34 PM
Cmk thanks. The 109 is a good looking aircraft. Fought from the first day to the last day of the war.
       - Plankton
LSM
    July 2004
Posted by stikpusher on Monday, July 24, 2017 3:06 PM
I did a bit more detail work on this today. I drilled some lightening holes, thinned down the heel rests with my Dremel, and added some foil top straps...
then with some wire, I made some anchor points for the seat harness decal. I did not add side anchor points as those will not be visible.
and lastly, I began drilling out the exhaust stack ends...
that's all for now...
       - Plankton
LSM
Posted by Bish on Monday, July 24, 2017 3:47 PM
checkmateking02
O you deffinetly should. There a bit more choice for the F there's days, but its still doesn't seem as well covered as other variants, especially the G.
Posted by Bish on Monday, July 24, 2017 3:49 PM
Some nice work there PJ. Nice to see an old kit getting a touch up.
    September 2003
Posted by checkmateking02 on Monday, July 24, 2017 5:10 PM
Very accomplished, stik!  You've got some finely detail work going on.  Well-done!
    July 2004
Posted by stikpusher on Monday, July 24, 2017 5:28 PM
checkmateking02
Thank you Check. I'm trying to keep it simple and quick here, just with basic improvements. I want to get the cockpit wrapped up ASAP, as that is usually the biggest speed bump during main construction.
       - Plankton
LSM
    September 2016
Posted by ManCityFan on Tuesday, July 25, 2017 8:24 AM
Steve, nice job on that Zero.  The color looks right, and the weathering is spot on.
Stik, good job on the detail in that 109.  Even if you can't see the rudder pedals when it is done, you will know it's there.
D
Dwayne or Dman or just D.  All comments are welcome on my builds.
    July 2004
Posted by stikpusher on Tuesday, July 25, 2017 3:17 PM
Thank you D. They just might be visible, so it's a case of better safe than sorry.
I am really quite motivated to finish this one up for some reason. So here is today's progress report...
First off the trademark stamp, circa 1978. I still have the IPMS Update issue in my library with the review of this kit. Back then it was THE 109 kit in 1/48.
Then some more shots of my scratch work in the cockpit, and the molded on sidewall detail pre painting. Not too bad. And the canopy hood armor plate. I sanded that down to a more scale thickness compared to its original look
Then I airbrushed on a coat of Tamiya Dark Gray, XF-24, thinned with lacquer thinner to give it a little more "bite" on the wire and foil I added. XF-24 looks to be a close match to RLM-66... at least as Model Master has produced the color. After washes and dry brushing it won't really matter.
That's all for today....
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Tuesday, July 25, 2017 10:41 PM
And that is looking very sharp, stik.  Very fine!
    July 2004
Posted by stikpusher on Tuesday, July 25, 2017 11:09 PM
Thank you check! This is really turning into a fun little build. Just what I needed.
       - Plankton
LSM
    February 2006
Posted by DantheMan85 on Wednesday, July 26, 2017 7:25 PM
Stikpusher: Great start to the Bf 109.
Modelcrazy: Great finish on your Zero, a job well done.
Bish: Nice paint job on the Panzer II, I like the building. Have fun with those little track links.
This 1/144 Junkers Ju 52/3M is by far the smallest model I've ever worked on. Not that many parts, should be a quick build.
 7 by Daniel Smith, on Flickr
 8 by Daniel Smith, on Flickr
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    July 2004
Posted by stikpusher on Wednesday, July 26, 2017 7:35 PM
Small model of a build of a large aircraft... cool!
       - Plankton
LSM
Posted by Bish on Thursday, July 27, 2017 2:09 AM
Thanks Dan, and o yes, i have been having lots of fun with those. Big Smile
Nice little Tante Ju there.
    September 2003
Posted by checkmateking02 on Thursday, July 27, 2017 3:11 PM
When the paint bottle towers over the model, that's pretty small!  Looks good; very petite, Dan.
    July 2004
Posted by stikpusher on Saturday, July 29, 2017 4:21 PM
Well, here are my latest update photos from the past few days.
First up, a basic dark wash
Then some dry brushing with a medium to light gray
Then the bright color detail painting
I need to do some follow up pin wash work and a final flat coat, followed by some bare metal light dry brushing in a few spots, but this is almost ready to close up. I just was quite a bit busier on my days off than I had thought I would be and have not had the time that I had wanted to be at my bench...
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Saturday, July 29, 2017 5:27 PM
That is looking very good, stik.  The detail is really popping out.
    July 2004
Posted by stikpusher on Saturday, July 29, 2017 11:21 PM
Thanks check. Under the single piece closed canopy, it will be more than adequate.
Close enough is good enough in this case.
       - Plankton
LSM
Posted by Bish on Saturday, July 29, 2017 11:32 PM
Thats coming along nicely Stik.
