The 2017/ 2018 Too Little Too Late Group Build
Posted by Bish on Monday, June 19, 2017 12:23 PM
Joe, thats looking sweet. Love that pit.
    April 2006
Posted by jgeratic on Monday, June 19, 2017 1:39 PM
Thanks rocker286 and Mustang, glad you approve the pimped up drop tank.
Mustang, that is some sweet detail in the pit and  gear bays.
Andy, actually pretty good looking results with the home made masks.  if you plan to do regular spraying of cross markings, you might be interested in Maketar products.  They usually have a 30% off sale once or twice a year.
http://shop.maketar.com/
MM, yes essentially with the gloss coat, you are creating a clear flim over the whole decal sheet.   I'd leave it at full 24hr to dry before trimming and soaking in water.  If using future pledge, probably best to wait 2 days.
regards,
Jack
    April 2015
Posted by Mopar Madness on Monday, June 19, 2017 2:25 PM
Thanks Jack!  I'll give it a shot.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    September 2014
Posted by rooster513 on Monday, June 19, 2017 3:03 PM
jgeratic
regards,
Jack
Those masks look very handy Jack! Have you used them before? I'll keep an eye out for a sale but I may have to pick up a set. 6 masks of each cross size is enough to do a few aircraft so the price isn't bad. I appreciate the help and advice you've given me...thanks buddy!
-Andy
    February 2014
Posted by silentbob33 on Monday, June 19, 2017 4:47 PM
Joe, that cockpit and wheelbay look amazing! I can't wait to see more. Rooster, your painted markings look pretty good! Certainly better than when I tried it on a Stuka a few years ago...
On my bench: Academy 1/35 UH-60L Black Hawk
    April 2006
Posted by jgeratic on Monday, June 19, 2017 6:15 PM
Hi Andy, yes have used Maketar for some British roundels and worked great, but were of the vinyl type - have to be careful when placing them as they are stretchy somewhat.  The kabuki tape ones are better quality though, no shrinkage from cutting and more rigid.
You can sign up for their newsletter, and that will notify you of any sales.
regards,
Jack
    September 2013
Posted by blackdog62 on Wednesday, June 21, 2017 1:07 PM
rooster thats looking really nice. free hand is somthing i enjoy always trying to get a little tighter.
    April 2015
Posted by Mopar Madness on Wednesday, June 21, 2017 4:42 PM
Okay, the canopy is masked and the wings are on.  It’s still fighting with me but I can see the light at the end of the tunnel.  More work will need to be done at the wing roots and the nose clip doesn’t line up properly so I'll re-contour with Milliput.
Chad
On deck: Who knows!
    November 2003
Posted by tempestjohnny on Friday, June 23, 2017 8:07 AM
I'm going to need a need more of these 190's and 152's. This kit is really nice.  Almost ready for paint
    April 2015
Posted by Mopar Madness on Friday, June 23, 2017 11:51 AM
Looks great!
Chad
On deck: Who knows!
    March 2012
Posted by mustang1989 on Sunday, June 25, 2017 6:51 AM
Chad: Man you are just moving right along with this bad boy!!!!! I couldn't build that fast to save my neck!!
Johnny: You've got yours to that point as well!!! Everything looks smooth and ready to go.
I'm really looking forward to seeing the paint fly on both of these beauties!!!!
 Forum | Modelers Social Club Forum (proboards.com)
    April 2006
Posted by jgeratic on Wednesday, June 28, 2017 6:16 PM
At the stage now ready to add primer and paint.
Above are the parts left separate for ease of painting, but here is the remaining details for backdating to the G-6/AS as well as improving some details:
Antennas on top were replaced with brass, as I have a bad habit of breaking plastic ones.  The loop antenna should also have a flatness to it when viewed from the sides, instead of being a ring.
On the starboard engine side, the upper access cover needs to be removed, so a simple fill in here.  The vent scoop on the clear canopy part also needs to be added - the kit part had this more to the rear.
I wasn't sure what type prop blades would be correct for this one.   I have read that initially the thinner blade of the G-6 was kept (which really didn't take advantage of the more powerful engine), but eventually would be replaced with the broader paddle VDM 9-12159.   I believe this the type provided in the G-10 boxing?  Since this is going to be an inflight display, simple answer is to not use any.
The wheels up position required adding some sort of swivel detail to the upper part of the struts.  The wheels themselves also had to be sanded for the doors to sit flush.
I've also embedded a brass tube into the lower fuselage to later accept a length of stainless steel wire for the whip antenna.
regards,
Jack
    April 2015
Posted by Mopar Madness on Wednesday, June 28, 2017 8:07 PM
Love it!  This makes me want to crack open one of my Eduard 190's.
Chad
On deck: Who knows!
Posted by Bish on Thursday, June 29, 2017 6:07 AM
Great work there jack, and really nice job pointing out the alterations.
I've just ordered a couple of the FM 109's, the G-10 and K-4, laregely down to watching your build.
Posted by Bish on Thursday, June 29, 2017 6:09 AM
tempestjohnny
Great looking 152 Johnny.
Posted by Bish on Thursday, June 29, 2017 6:16 AM
Mopar Madness
You seem to be getting the best of it MM.
    November 2003
Posted by tempestjohnny on Thursday, June 29, 2017 8:06 AM
Ok was,able to spend a bit at the bench this morning. Lichtgrun is painted.
    September 2014
Posted by rooster513 on Thursday, June 29, 2017 8:13 AM
Jack, that scratch work and attention to detail is turning out great!
johnny, good to see some paint going on that one. Looking really good so far!
-Andy
    April 2006
Posted by jgeratic on Thursday, June 29, 2017 1:40 PM
Johnny, good coverage of paint on your 152.
Thanks MM, Bish, and Andy.
I should add  some extra observations about the various antennas:
* main mast - many line drawings appear to indicate it's position right on the Erla canopy frame, while in photos it looks to be on the fuelage spine next to the canopy - I chose the latter.
* fuselage underside whip antenna - this is something that needs to be scratch built because FineMolds did not include one.  There is though a slight recess provided for it's location, and some G-10's did have it alongside with the FuG 16ZY under the port wing.
regards,
Jack
    March 2012
Posted by mustang1989 on Thursday, June 29, 2017 8:45 PM
Jack: Man that is some attention to detail that you are putting into that build of yours buddy. I am simply amazed at the level of research and accuracy. Looking forward to more updates as I'm learning new tricks every step of the way.
Johnny: I've always liked that shade of green on these late war aircraft. Very  nice work.
    November 2003
Posted by tempestjohnny on Friday, June 30, 2017 9:49 PM
Ok I think I'm getting the hang of flickr.
 20170630_085451 by John Hawley, on Flickr
Pic taken while paint was,still wet
    April 2015
Posted by Mopar Madness on Friday, June 30, 2017 9:57 PM
I really like those late-war colors!  I painted and camouflaged my 229 but I can't post until I get this Photobucket debacle worked out!  Keep up the great work on this 152!
Chad
On deck: Who knows!
    November 2003
Posted by tempestjohnny on Friday, June 30, 2017 10:25 PM
I'm with you on the photobucket mess. I'm trying flickr. Gonna take some getting used too
Posted by Bish on Saturday, July 1, 2017 5:31 AM
tempestjohnny
It tok me some time to figure it out. But with some patience and help from guys on here, i soon got the hang of it.
    April 2015
Posted by Mopar Madness on Saturday, July 1, 2017 4:58 PM
I'll call this an update but it's more of a test for my new image hosting site.  The camo is done and its ready for minor weathering.  The decals are ruined so I have to figure something out.  Suggestions of overspraying the decal sheet with gloss didn't work.  So, I'll either have to raid the spares or paint my own. Tongue Tied
Chad
On deck: Who knows!
    November 2003
Posted by tempestjohnny on Sunday, July 2, 2017 4:29 AM
tempestjohnny
I've been playing with Flickr for two days. Wasn't getting the hang of it. The site postimage.com was recommended. Easy to navigate, upload, and post
Posted by Bish on Sunday, July 2, 2017 6:04 AM
Glad your able to get pics up again Johnny. Liking the camo.
Posted by Bish on Sunday, July 2, 2017 6:05 AM
Looks good MM. At least you can just make up what ever set of markings you want.
    April 2015
Posted by Mopar Madness on Sunday, July 2, 2017 12:44 PM
Well, I'm calling this one done.  Nothing fancy, just a few decals and some mottled camo.  This was a fun build but I wouldn't recommend this kit unless you have some free time to burn.  Thank you all for the wonderful comments and support!  This was a great GB! Beer
Chad
On deck: Who knows!
Posted by Bish on Sunday, July 2, 2017 1:05 PM
I like that MM. Nice job on the scheme and nicley finished.
