RAF 100th Anniversay GB
Posted by Bish on Friday, February 16, 2018 2:28 AM
Eric, Airfix are re-releaseing some of their older kits i.e. pre 2006, in the new boxes. So it does pay to check. Unfortunatly there numbering system is not as clear cut as Dragons or Tamiyas. And yes, the turn around begain when they were bought up by Hornby in 2006.
But a few years ago, Hornby did anounce it was having finacial problems, even at the end of last year things were still not setteled. I just hope they can ride things out.
    July 2004
Posted by stikpusher on Friday, February 16, 2018 4:04 PM
Yes, but like most of the other model companies, Airfix has reboxed some of their older kits in the newest style boxings. The only thing new about them is the box, decals, and perhaps the instruction sheet as well. You have to research if it is an old or new tooling.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2013
Posted by Greg on Saturday, February 17, 2018 11:54 PM
Bit of an update on my 1/48 Eduard Tiffy....
A page back Jack mentioned the belly not having been pure black, but more of a dark grey blue. I decided to do a bit of streaking over the black. I grabbed the first grey/blue I found, and it happened to be RLM 74. Close enough. I enhanced the shadows to enhance viewing. It's not this stark in reality, and the not-parallel streaks don't stand out much. Surprise
Thanks Jack. If I messed up the idea, it isn't your fault!
The topside is all slicked up after decals. And I think I am passing on the stencils on this model. I'm going to try a coat of semi-gloss prior to Flory wash this time, so maybe tomorrow is take off masks day!
Thanks for looking.
    January 2017
Posted by mawright20 on Sunday, February 18, 2018 5:24 AM
Greg, what kind of foam is that your using for a mount?
Posted by Bish on Sunday, February 18, 2018 5:45 AM
Greg, i reather like what you have done to that.
    May 2013
Posted by Greg on Sunday, February 18, 2018 1:50 PM
mawright20
It is a foam cradle made for working on model trains. I have a couple, bought mine ages ago from MicroMark. They seem to work great for 1/48 scale model planes as you have noticed.
Click here to take a look.
    May 2013
Posted by Greg on Sunday, February 18, 2018 1:53 PM
Bish, thanks for looking and for your comment.
    May 2013
Posted by Greg on Sunday, February 18, 2018 9:27 PM
It is always a treat to have no major disasters upon mask removal, isn't it?
This is neither my best nor worst, nothing bad enough to do over.
If there is anyone near here who knows as little about WWII aircraft as me (unlikely) the extra pieces are because this is to be the "car door" version of the Typhoon.
Edward provided masks for the closed door version, I had to cut some of the masks myself. Guess what, the Eduard masks worked better. Geeked
    July 2004
Posted by stikpusher on Sunday, February 18, 2018 11:08 PM
That looks great to me!
       - Plankton
LSM
    February 2010
Posted by EBergerud on Monday, February 19, 2018 1:02 AM
Greg The cradle is clever. What scale is it - you can get them in HO, O and N? Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    March 2017
Posted by Armor_Aficionado on Monday, February 19, 2018 2:08 AM
Well, I’m a bit disappointed once again with the Airfix 1/48 Hurricane Mk. I. For a company that puts so much really nice detail into their molds, that doesn’t transfer over into engineering the fit very well.  I had already had problems previously with the Albion refueling truck, and was initially impressed that the Hurricane appeared to be a great improvement over that.  Then I had some issues with fitting the wings together (had to shave down the main wing spar in places to get it to fit), and in the otherwise very nice machine gun bays, the final parts to put in (the diagonally situated structural members) both had to have some cutting done to them to be able to get them to fit, but nothing that couldn’t be easily fixed.  Now, though, trying to fit the fuselage over the completed wings/cockpit assembly is a nightmare!  The fit is just not there at all.  I had to shave down the outer sides of the aluminum tubing that surrounds the cockpit (luckily this will not even be visible) just to get the fuselage to fit over it, and when I finally got it seated, the result is still crap.  Took a ton of glue to get it to hold, will require a ton of putty to fill the atrocious wing root gaps.  Compared to the Tamiya 1/48 Spitfire Mk. I I just completed, also for this diorama, it’s like racing a Yugo against a Ferrari F1 car!  Seriously, the Tamiya you practically just shake the box, dump the parts out and it falls together - presto, done!  The Airfix is like a theatre of pain.
https://pin.it/veuvknll7oq3lg
https://pin.it/orq3zkcsdjqcby
Posted by Bish on Monday, February 19, 2018 6:45 AM
Thats come out very nice Greg, should be pleased with that.
Posted by Bish on Monday, February 19, 2018 6:53 AM
That does not sound very good AA. The only build review i could finmd was of the Sea Hurricane and that does not mention any issues. So i wounder if you have a dud or a kit from an early production run.
    May 2013
Posted by Greg on Monday, February 19, 2018 11:37 AM
EBergerud
Eric, far as I know it is available in one size which is said to be for HO and N. The larger trough is for HO, smaller for N. I've never seen one for O scale.
I have two, they come in handy for all sorts of things. Geeked
Posted by Gamera on Monday, February 19, 2018 11:38 AM
Greg: Looks great! The canopy looks perfect to me.
AA: Oh wow that blows. Sounds like a bad kit but then again I've had a few good quality ones that just seemed jinxed. Nasty seam there on the wing root. Have you any putty that you can remove with solvent so you don't have to sand off all that detail?
I'm stuck now in stenciling hell. About half of them are applied so far.
    May 2013
Posted by Greg on Monday, February 19, 2018 11:43 AM
AA, sorry to hear of your fit troubles. I've yet to build an Airfix kit and your problems put a damper on my enthusiasm. You can handle those wing roots. They are not pretty, but I've seen worse and I'm sure you have too.
Bish and Stik, thank you for your encouraging words.
    March 2017
Posted by Armor_Aficionado on Monday, February 19, 2018 3:04 PM
Yeah, I’ve got Squadron green putty, it comes off okay with solvent, not perfect but it’ll do the job.
    February 2010
Posted by EBergerud on Monday, February 19, 2018 4:40 PM
I subscribe to Phil Flory's site. He has a six part (about three hours) video build on the Airfix Hurricane I (new tool kit natch). He found some small errors but describes the fit as "fantastic" and found the build fun from start to finish. He did say to make sure the connecting pins are not too long. Of course Flory makes his living making models. I've got the Hurricane I (sold the Italeri/Tamiya version to get it) and I think I'll give it a try down the road. Flory's inbox review of the kit is available for view on YouTube. There are at least two video builds there too that I intend to check out.
Eric
    July 2004
Posted by stikpusher on Monday, February 19, 2018 8:04 PM
Armor, sorry to hear that the Hurricane is giving you such a fight. A couple guys at IPMS have built that kit, and it sure looks great in the end...
Some minor progress today-
just showing the clean up of the plugs on the original tail mounts
and I spent a little time airbrushing on some Gray Tamiya Liquid Surface Primer on the cockpit interior parts
I’ll let that dry over nite and start working on painting in there tomorrow...
       - Plankton
LSM
    May 2013
Posted by Greg on Monday, February 19, 2018 10:23 PM
Gamera
Thanks, G. Smile
Stik,
I wondered how those plugs would end up. Thx for showing us. Look great.
Don'tcha just love how Tamiya pulls out detail?
    July 2004
Posted by stikpusher on Monday, February 19, 2018 10:55 PM
Greg, this is my first time using their gray primer. And yes, it sure does help the detail pop out so far. I am looking forward to seeing how it looks with some paint on it tomorrow.
       - Plankton
LSM
Posted by Bish on Tuesday, February 20, 2018 2:00 AM
Those plugs cleaned up nicely Stik. Be nice to see the paint go on the pit.
Posted by Gamera on Tuesday, February 20, 2018 7:45 AM
Looks good to me SP, you're making solid progress.
    May 2013
Posted by Greg on Tuesday, February 20, 2018 11:34 AM
Curious, Stik, if you've tried Stynylrez primer yet?
I was stuck on Tamiya, an online friend here sent me a bottle of Stynylrez. Haven't turned back and haven't used Tamiya in a while now.
Not trying to say Stynylrez is better or push you towards it, I'm just curious.
    January 2016
Posted by iSteve on Tuesday, February 20, 2018 1:26 PM
stikpusher
Brandon and Steve, both of your builds are looking great so far!
And as for me, we are off and running! I have finished adding the PE for the cockpit interior aside from the seat harness, which is from a pre painted set and will add after painting. So far, so good...
here are the drilled out gun ports
And the birdshot added inside for nose weight.... hopefully this should be sufficient....
Tomorrow I will get it primed. I will likely work on other areas over the next few days such as the wings, tail booms, etc.
Thanks Stikpusher! Your build is coming along nicely - looking forward to the end result.
    January 2016
Posted by iSteve on Tuesday, February 20, 2018 1:44 PM
Greg
Brandon, your biplane looks very cool and it isn't even done yet. Yes You are very brave, I'd be afraid to start one.
Steve, interior looking good!
Stik, good to see you under way.
And me, worms.........
Thanks Greg! Your Typhoon is looking much like mine will soon. I've found it the most effective (and easy) way to do camo. I cover the masked parts with wax paper, though, to protect it from the overspray I think I'm never going to get but always do. :)
    January 2016
Posted by iSteve on Tuesday, February 20, 2018 1:46 PM
Gamera
Steve: The cockpit work is impressive. Wouldn't worry too much about the decal being a little off, can't imagine there will be much to see with the cockpit closed up and I didn't even notice till you pointed it out.
Thanks Gamera! The decal in the cockpit is the least of my worries right now. Wait until you see my seatbelts.
    January 2016
Posted by iSteve on Tuesday, February 20, 2018 1:58 PM
Armor_Aficionado
Wow, sorry to hear AA. I've built that kit and fit was the least of my worries, save for the lower engine cowl. Wings and cockpit went on easily with negligible gaps at the wing roots. I even bought another one because it was such a fun build. Hope that's the last of your fit problems.
    July 2004
Posted by stikpusher on Tuesday, February 20, 2018 3:46 PM
Thanks guys. I can’t wait to get the cockpit done!
Greg
No I have not tried that stuff. I don’t recall seeing it at any of the local shops, and I am more than satisfied with the primers that I already have onhand: Humbrol, Tamiya, and Gunze. I don’t use primer that much anyways. Usually just in situations like this where I have multi media as my base. If I am working in straight styrene, I don’t prime.
       - Plankton
LSM
    May 2013
Posted by Greg on Tuesday, February 20, 2018 10:52 PM
iSteve
Thanks Steve. I got both lazy and lucky with the camo. I should have masked it and wax paper is a great idea.
Stik, the primer (Stynylrez) is made by Badger and I've only seen it online. Reason I like it is it is not oil based. It has no odor and it clings as well at Tamiya far as I can tell. Ok, end of Badger advertisement. Headphones
