Monogram Mafia IV Group Build
    November 2008
Posted by plasticjunkie on Monday, July 10, 2017 10:46 PM
Thanks for the info stik, I'll look into that for sure.
GM - I like MM enamel gloss and Alclad clear gloss.
 GIFMaker.org_jy_Ayj_O
    September 2012
Posted by GMorrison on Monday, July 10, 2017 11:00 PM
Thanks!
Modeling is an excuse to buy books
    July 2004
Posted by stikpusher on Tuesday, July 11, 2017 12:53 AM
plasticjunkie
Here's a nekkid one for you where you can see the metal and putty work...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2003
Posted by Duke Maddog on Tuesday, July 11, 2017 1:46 PM
Thanks Carlos, consider them both entered. I like that they are both in one box too!
    May 2004
Posted by cbaltrin on Saturday, July 15, 2017 8:08 AM
Working on the wings ths weekend. Installing sleaves for proper guns (aka heaters). Working on the stabilizer joint as well--Don't really want to add any filler here..
On the Bench:
  • Italeri F-100D 1/72
  • Revel 1/72 HH-3 Jolly Green Giant
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
  • Monogram 1/72 F-4J
    November 2008
Posted by plasticjunkie on Saturday, July 15, 2017 8:57 AM
stikpusher
plasticjunkie
Been doing a little research and seems like most 262s were taped up as above at the factory then had their paint jobs done over the putty/tape lines. Read somewhere best way to replicate the effect is to either sand raised lines or fill in recessed ones then use a brush to apply some paint to simulate the above effect then paint over with the RLM colors.
Thanks again stik for saving me from doing a hair pulling task.
Cb
Those guns are shaping up, great job!
    July 2004
Posted by stikpusher on Saturday, July 15, 2017 11:35 AM
Frees & Mark (Duke), your selections have been added to the roster. I'm looking forward to them!
CB, excellent work on the heaters! Right down to the angle across the leading edge parallel to the ground.
PJ, yes sanding off the panel lines and then painting a thin line of primer for underneath the warpaint woukd probably give the most realistic look to achieve the proper results.
       - Plankton
LSM
    May 2004
Posted by cbaltrin on Saturday, July 15, 2017 4:41 PM
Working on the engine now
On the Bench:
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
    October 2016
Posted by DasBeav on Monday, July 17, 2017 8:39 PM
Starting on my Ju 87. After taking a 3 week break from modelling where I just golfed and binged watch Orphan Black, I am ready to be "made". Started last night by gluing some stuff together and "scratching" some rudder pedals. (The cockpit needed "something") Tonight I will lay down some primer and hopefully get to painting the "pit" tomorrow...
 Sooner Born...Buckeye Bred.
    May 2004
Posted by cbaltrin on Tuesday, July 18, 2017 5:38 AM
Looking good dasbeav. Are those the kit  wheels?
On the Bench:
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
    January 2012
Posted by Cdn Colin on Tuesday, July 18, 2017 8:09 AM
OK, so I started my P-47 on the 10th.  I'll post pictures once I've figured out a hosting site.
I build 1/48 scale WW2 fighters.
Have fun.
    September 2012
Posted by GMorrison on Tuesday, July 18, 2017 10:08 AM
Fotki has a free-for-30, no card # required. I tried it and am happy with it. I just signed up for $ 24/ year for 100 GB storage. Fast, no ads.
    August 2016
Posted by Keyda81 on Tuesday, July 18, 2017 10:35 AM
Started on the F-117 last night.  Not a whole lot of progress to report.  Just some work on the cockpit.
    July 2004
Posted by stikpusher on Tuesday, July 18, 2017 12:45 PM
Keyda, you're off to a good start. I don't think that I've seen too many of the Monogram 117's built.
One thing, the Mafia GB badges are only supposed to be displayed after being earned for the completion of the two builds within six months. Part of our "being made" status for all of the previous Monogram Mafia GBs.
       - Plankton
LSM
    October 2016
Posted by DasBeav on Tuesday, July 18, 2017 9:51 PM
cbaltrin
Thank you. And they are the kit wheels. A little flash but not to bad for a 50 year old mold.
    May 2004
Posted by cbaltrin on Wednesday, July 19, 2017 7:32 AM
Rescribed some lost detail on the wings and attaching the left wing now...
On the Bench:
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
    August 2016
Posted by Keyda81 on Wednesday, July 19, 2017 9:20 AM
stikpusher
Oops, lol.  I was trying to fix my signature after the whole photobucket fiasco, and didn't realize I put that one in there!  Took it out for now.
    November 2008
Posted by plasticjunkie on Sunday, July 23, 2017 12:36 AM
Good job on your builds guys. I finally started on mine today. I decided to make the 262 NMF and putty lines  and abandoned as part of a small dio a la Bish. More on that later.
Got things glued up and clamped.
got the tiny pit together which has sparse details but the canopy will be closed in the dio so little will be seen any way.
Clamps are off and seams partially sanded and polished. Still need to run some PPP to putty up the panel lines I scribed earlier.
That's all for now......
    May 2004
Posted by cbaltrin on Sunday, July 23, 2017 11:39 AM
The 262 is looking good PJ.  Better get it done and  airborne before my P-47 is done Whistling
On the Bench:
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
    May 2004
Posted by cbaltrin on Sunday, July 23, 2017 11:42 AM
All major airframe components are attached. AMS has set in however and I have started rescribing lost detail around the wing roots. I told myself I was not going to do this... Oh well. Also adding some wingtip lights.
On the Bench:
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
    November 2008
Posted by plasticjunkie on Sunday, July 23, 2017 12:30 PM
cbaltrin
you may just finish first cb. The wife tasked me for more painting in the bedroom and new flooring to install.Confused
    July 2004
Posted by stikpusher on Sunday, July 23, 2017 4:30 PM
PJ and CB, those are both coming along nicely!
       - Plankton
LSM
    April 2014
Posted by B_one fixer on Sunday, July 23, 2017 7:30 PM
Made some progress on the big tomcat. Work keeps getting in the way and I found some time to build today.
    November 2008
Posted by plasticjunkie on Sunday, July 23, 2017 7:43 PM
[quote user="B_one fixer"]
Great to see someone besides  me doing a Tomcat. Looks good so far.
    August 2016
Posted by Keyda81 on Sunday, July 23, 2017 8:46 PM
Nice work everyone!
I was able to work on the F-117 a little bit today.  Got the wings together, and in place.  Letting everything dry, and if I get a chance I'll glue the fuselage halves together tomorrow.
    February 2014
Posted by silentbob33 on Monday, July 24, 2017 10:17 AM
Getting caught up after cub scout camp and lots of good stuff here. Great progress everyone
On my bench: Hasegawa 1/32 Fw190-F8 crash diorama
    May 2004
Posted by cbaltrin on Monday, July 24, 2017 12:49 PM
plasticjunkie
Which F14 u building PJ? Dont see it on the roster. I Might have to do one as well!
On the Bench:
  • Monogram P-47D
  • Monogram F-14A
  • Monogram P-51D
    August 2016
Posted by Keyda81 on Monday, July 24, 2017 6:16 PM
Bit more progress today on account of the crappy weather.
    July 2004
Posted by stikpusher on Monday, July 24, 2017 6:52 PM
B_one, the Tomcat is really shaping up nicely! Are you doing sub assemblies complete with markings like the tail fin?
Keyda, now your build looks like a 117! That black arrowhead shape.
       - Plankton
LSM
    November 2008
Posted by plasticjunkie on Monday, July 24, 2017 7:40 PM
cbaltrin
plasticjunkie
Hi CB. I recently completed a Hasegawa cat as a comission seen in this thread:
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/175809.aspx?page=1
It's not letting me post it as a direct link for some reason.
At the moment but I have another 10 or so cats on deck. I have done at least 9 cats both in 1/72 and 1/48, Revell, Hasegawa, Fujimi and Hobby Boss as comissions.
Hope you do jump in with a kitty!
