Pride of the Luftwaffe GB
    August, 2015
Posted by crown r n7 on Thursday, October 12, 2017 7:15 AM
Can try a template
 Nick.
    July, 2014
Posted by modelcrazy on Thursday, October 12, 2017 9:21 AM
I like the sponge idea. I applied some putty last night and will work on the seams tonight. I'm encited to see how the painting is going to work out.
ON THE BENCH
1/700 Hasegawa DDG Kirishima
1/72 Hasegawa Nell
In Que
1/700 Tamiya Scharnhorst
Completing a kit is like cutting the head off a Hydra. Two more replace it in the stash.
    April, 2006
Posted by jgeratic on Thursday, October 12, 2017 9:53 AM
For that 1/144 mottle, another idea might be weathering powders applied with the tip of a fine brush.  It will require some mixing to come up with Luftwaffe shades.   Actually am surprised the market hasn't come up with such colours with the amount of choices out there.
regards,
Jack
    July, 2014
Posted by modelcrazy on Thursday, October 12, 2017 9:58 AM
So many great ideas. I'll have to try them all on a scrap piece and see how they work.
ON THE BENCH
1/72 Hasegawa Nell
In Que
    September, 2011
Posted by falconmod on Thursday, October 12, 2017 11:30 AM
I've used a paper template with very small shapes cut out then pressed up against (but not as close as like tape or post-it notes) the fuselage, then use your AB to shoot the correct color at it.   You still get a faint feathered edge which I think is better than the sharp or blotchy egde you would get with a sponge or brush.  imho
John
On the Bench: 1/72 FW190F-8, 1/48 ESCI Mirage III C
Italeri 1/72 Mirage 2000C, 1/48 Dragon Fw190A-5
    September, 2017
Posted by Pinkbooger on Thursday, October 12, 2017 11:54 AM
This is my first aircraft and there is a seam all the way around where the 2 fuselage pieces come together. Do you putty the whole thing or just visible gaps? do you sand the entire seam? How do you ensure that when you paint it you will not visually see that there was at one time a seam there where two pieces of plastic meet together?
"You underestimate the power of the dark side"
-Darth Vader
    July, 2014
Posted by modelcrazy on Thursday, October 12, 2017 11:59 AM
I sand the entire seam usually with 600 or higher grit, brush on a primer to check for evidence of a seam and wipe the primer off with denatured alcohol to remove the brush strokes if needed.
ON THE BENCH
1/72 Hasegawa Nell
In Que
    May, 2017
Posted by MrStecks on Thursday, October 12, 2017 1:25 PM
Hey Rooster, add me to the mix.  I'll be doing this Eduard Fw 190A-9.  Smile
Cheers, Mark
On the bench: Eduard 1/48 Fw190 A-9 ProfiPACK
In the queue: Tamiya 1/32 P-51 Mustang
    March, 2017
Posted by shamoo on Thursday, October 12, 2017 1:28 PM
MrStecks
Cheers, Mark
I’m looking forward to watching this one. I’ve been debating trying one of their profipack kits.
    November, 2008
Posted by plasticjunkie on Thursday, October 12, 2017 3:58 PM
Pinkbooger
This is when Tenax or Plast I Weld are supreme. I use the Touch N Flow applicator to apply these glues and squeeze the join together crating a small ridge created by the melted plastic that oozes out. I clamp the fuselage and let it dry a few hours. I then sand the entire seam with different grits until the join line is gone. Using this method, I rarely use any filler or putty.
Too many models to build, not enough time in a day.
    April, 2015
Posted by Mopar Madness on Thursday, October 12, 2017 4:19 PM
jgeratic
regards,
Jack
I've seen some nice mottling done with weathering powders too!  I don't know where I saw it, but I recall seeing an article by a gentleman who created a three tone camouflage of a 1/72 SM.82 with weathering powders. Looked amazing.
Chad
God, Family, Models...
At the plate: 1/48 Eduard Fw 190A-4
On deck: 1/72 Airfix Heinkel He111 H-6
In the hole: 1/700 Trumpeter Graf Zeppelin
    May, 2017
Posted by MrStecks on Thursday, October 12, 2017 4:29 PM
shamoo
MrStecks
Cheers, Mark
Yeah, looks to be a decent kit.  I picked this largely based on this review (though it's a few years old).     http://www.hyperscale.com/2012/reviews/kits/eduard8187reviewbf_1.htm
Cheers, Mark
    April, 2005
Posted by taxtp on Thursday, October 12, 2017 6:20 PM
Great work on the badges Andy.
I did a very quick search of my stash yesterday, as I thought I had an Airfix 1/72 109E
It didnt turn up, but I was surprised at what I found, all 1/72
Tamiya 109E-4/7 trop
Academy 109E
Revell 109G-10
Hasegawa 190D-9
2 * Tamiya 190A-3
I've already committed to the first one, but I'll be tempted to keep going, at least with the 109s. I'll let you know if I'm going to enter any more.
Given that the name of the GB is 'Pride of the Luftwaffe', am I right in guessing that aircraft operated by other Axis powers are not allowed ?
Cheers
Tony
I'm just taking it one GB at a time.
    January, 2006
Posted by DiscoStu on Thursday, October 12, 2017 6:53 PM
 I’d like to contribute the Eduard 1/48 Bf-109G-6.
 6928D048-650C-4842-A082-080D57A2089D by Stu George, on Flickr
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    September, 2014
Posted by rooster513 on Thursday, October 12, 2017 7:50 PM
taxtp
Academy 109E
Revell 109G-10
Hasegawa 190D-9
2 * Tamiya 190A-3
Cheers
Tony
Tony, other countries markings are ok. The GB is just spot lighting these two important aircraft. I'm not as concerned about the markings as long as it's a 109 or 190!
-Andy
    April, 2005
Posted by taxtp on Thursday, October 12, 2017 8:07 PM
Thanks Andy that opens it up for me. I'll get back to you on future plans.
Cheers
Tony
    January, 2016
Posted by Hunter on Thursday, October 12, 2017 8:13 PM
modelcrazy
I did think about the drybrush idea but not oils, I should try that.
Here is the little guy so far. I had to use a weak clothespin so I didn’t crush it. There are some seam gaps but it's so small just a dab of Mr. Dissolved Putty should take care of it.
Hello Steve,
Man for such a small kit it has some great detail to it. What is the total piece count for this kit? It is looking great friend. I'm jealous that you have already got started lol. I have 4 more days here at the station before I get to go home and get started on mine. I'm looking forward to the 1/72 build. This is how mine is going to look after I build it LOL
Image result for WWII photos of Bf 109 E3
Hunter
    June, 2010
Posted by 5-high on Friday, October 13, 2017 1:25 AM
I started my.n 3 days ago lol..hasga fw-190-D9 . I plan on using tamiya paints. I.ll have to custom mix every RLM color. Now to figure out flicker.Bang Head
    September, 2016
Posted by TheWaggishAmerican on Friday, October 13, 2017 7:49 AM
Ohhh!! I definently want in- I'll have to get back to you on what I'll be building, though- time to hit the LHS!
(Side note, would a 109 in foreign colors be acceptable, or are you keeping it Luftwaffe all the way?)
On the Bench- 1/48 Tamiya A6M2, 1/72 Airfix A6M2, 1/25 AMT Model T Delivery Van.
    July, 2014
Posted by modelcrazy on Friday, October 13, 2017 9:50 AM
Hunter
Hello Steve, Man for such a small kit it has some great detail to it. What is the total piece count for this kit? It is looking great friend. I'm jealous that you have already got started lol. I have 4 more days here at the station before I get to go home and get started on mine. I'm looking forward to the 1/72 build. This is how mine is going to look after I build it LOL
It would be great to see you build it as a wreck.
The kit has 12 parts, if you add the bomb, 16 if you use the stand and plaque. I won't use the bomb but may stick it on the stand to keep the gear from getting broken off.
ON THE BENCH
1/72 Hasegawa Nell
In Que
    September, 2014
Posted by rooster513 on Friday, October 13, 2017 10:11 AM
TheWaggishAmerican
WaggishAmerican, I'm ok with foreign markings as long as it's a 109.
-Andy
    July, 2014
Posted by modelcrazy on Saturday, October 14, 2017 12:40 AM
Here is where I'm at with my little 190. After this all dries I'll add the gray green to the top and work on the mottling.
The camera captured more blue in these pics than white.
ON THE BENCH
1/72 Hasegawa Nell
In Que
    January, 2016
Posted by Hunter on Saturday, October 14, 2017 9:14 AM
modelcrazy
Hunter
Steve....I am LMHO....I should have been more clear about the photo. I meant mine was going to look like a wreck after I got done building it...not a dio setting.Big Smile
Although, I do have a stand in mind. Be well friend
Hunter
    July, 2014
Posted by modelcrazy on Saturday, October 14, 2017 9:37 AM
Hunter
I know my friend, I was giving you jazz. Wink
ON THE BENCH
1/72 Hasegawa Nell
In Que
    November, 2008
Posted by plasticjunkie on Saturday, October 14, 2017 10:58 AM
Can't wait to see how the sponge mottling comes out! WOW that is tiny!! Geeked
    January, 2016
Posted by Hunter on Saturday, October 14, 2017 12:07 PM
modelcrazy
Hunter
LOL...you got sir!! Also, did you hand paint, or airbrush the camo green? It looks great.
Hunter
    August, 2015
Posted by crown r n7 on Saturday, October 14, 2017 12:37 PM
Looking good on that match box FW 190!
 Nick.
    September, 2016
Posted by TheWaggishAmerican on Saturday, October 14, 2017 12:53 PM
Alright, just got back from my LHS!
If you could, please put me down for a 1/48 Revell Bf 109 G-10, 1/72 Amodel Bf 109 W, and Airfix Bf 109E in Swiss service.
    January, 2016
Posted by Hunter on Saturday, October 14, 2017 1:22 PM
Nice haul Waggish...look forward to seeing them done.
Hunter
    April, 2015
Posted by Mopar Madness on Saturday, October 14, 2017 3:42 PM
That is a nice haul indeed.  I particularly like that 109 W!  Looking forward to progress pics.
Chad
SUBSCRIBER-ONLY CONTENT
