Shelf of Doom GB II - 2018
    August, 2015
Posted by crown r n7 on Wednesday, May 16, 2018 5:58 PM
Jack I like the mix of blues and that interior is electric.
Bish thank you I’m trying some panel lighting. When I spray clear flat I hope to get that bleached lookbut I have another a6m5 in the works
 Nick.
    April, 2005
Posted by taxtp on Wednesday, May 16, 2018 9:22 PM
Jack the shade of blue you've chosen is stunning. THe engine wiring looks very good too.
Keavdog Nice clean work on the Kfir. I believe its not a great fitting kit so there's some good work in there.
Nick good progress on the Zeke. It's looking very good.
This is one of those models that I keep forgetting to photograph. Yeah I painted the instrument panel on this one.  I realised a while ago that I don't have any aircraft models on the shelf with solid olive drab on the upper surfaces. I also found with P-47s, that some had Olive Drab, some had RAF Dark Green. I want to display both side by side, so this is the first half of the pair. Here it is with it's base camo on. I'll expose the chipping and clear coat it for decalling and weathering next.
Cheers
Tony
I'm just taking it one GB at a time.
    May, 2015
Posted by Griffin25 on Thursday, May 17, 2018 12:00 AM
Tony the slight color variation and panel lines look great. Did you accomplish that with preshading and a coat of the olive drab base color only? It looks like more was involved because it really pops. Looks really cool.
Griffin
    March, 2017
Posted by Armor_Aficionado on Thursday, May 17, 2018 12:23 AM
AAAARRGH!  Not once, anywhere in the instructions, did I see any warning ro put weight in the nose of this kit to prevent it from being a tail stander!  So of course, now that it‘s almost done, I get the unpleasant surprise.  So now to figure a way to get weight in the nose without wrecking the model...
https://pin.it/4ezoubaotoj5dp
    August, 2015
Posted by crown r n7 on Thursday, May 17, 2018 9:37 AM
Tony wait untill you gloss clear coat it , the colors will deepen !
 Nick.
    March, 2017
Posted by Armor_Aficionado on Thursday, May 17, 2018 2:10 PM
A-ha!  Success!  It‘s one of those rare occasions when an earlier error actually paid off, to help solve a more serious error later.  So when I was first starting to assemble the model, I forgot to put the jet exhaust tailpipe in before gluing the fuselage halves together. (See Part #9, first photo). To get it in there, I had to cut the front, sealed end of the pipe off and slide it in and glue it in place.  But that was to be my salvation later!  Now I had a way into the fuselage.  I used the smallest split-shot lead sinkers I could find, butveven then still had to split them into at least quarters, if not smaller.  Then I dropped a bunch of them down through the tailpipe until I had enough to weigh the nose down, and followed that by inserting a very thin liquid cement applicator tube through the pipe (Model Master liquid cement with the ultra-thin metal applicator tube) and pouring as much cement as needed to hold the lead in place.  She‘s looking good now!
https://pin.it/y6dxcbts632c7h
https://pin.it/snqfe2m6zmbyu2
https://pin.it/wpz3swlluengy5
https://pin.it/hm4pjheoilc7po
    April, 2005
Posted by taxtp on Thursday, May 17, 2018 7:26 PM
Griffin25
Hi Griffin,
Thanks. My standard for upper surfaces is to preshade, then base colour, then lighten the base colour and thin it down, spray light coats into the middle of panels as best I can.
For lower surfaces, I just preshade and base coat, because it's shadow so I don't want as much contrast.
Cheers
Tony
    April, 2005
Posted by taxtp on Thursday, May 17, 2018 7:28 PM
crown r n7
Yup, they did as they always do :) I'll decal it this weekend and post some photos in its current 'dark' state.
The chipping worked OK, I won't do it every time but for selected builds I know I've got this technique in my pocket.
Cheers
Tony
    April, 2005
Posted by taxtp on Thursday, May 17, 2018 7:34 PM
Armor_Aficionado
That's a shame Eric, it's a pretty little model. Are there any stores that you can add under the wings ? If you put weight in the front part of the store, it should be in front of the main undercarriage and may help to solve your problem. I did it on a Hawker Hunter once.
Cheers
Tony
    March, 2017
Posted by Armor_Aficionado on Friday, May 18, 2018 3:40 PM
Alright, calling this one DONE!  It wasn’t great:  the WORST decals I’ve ever seen, thanks to Revell of Germany; some major fit problems with the front canopy section, which resulted in a cracked canopy (although the rear canopy piece fit perfectly - weird!); and the aforementioned tail-standing issue, but for a kit I only piad, I think, a dollar for, I’m relatively pleased.  I really like the Hawk as a subject, so maybe I’ll try one again, just with a better quality kit.
https://pin.it/5tze5uzi5h26sg
https://pin.it/3ywnyiz5eri3fy
    April, 2005
Posted by taxtp on Saturday, May 19, 2018 4:42 AM
Very nice Eric, it looks great, and a terrific save at the end too. I'm planning to do a 'project' on Hawks, which means 5 of them in 1/72 and a big one in 1/32. Yours has got me fired up to get going with it, the first one is in the Commonwealth GB.
Well done, and thanks for your contribution here. I'll put a photo on the front page tomorrow, I'm just on my way out the door now.
Cheers
Tony
    May, 2015
Posted by Griffin25 on Sunday, May 20, 2018 6:47 PM
Good job Eric.  How many have we saved from Doooooom? 5?
Griffin
    April, 2003
Posted by keavdog on Sunday, May 20, 2018 7:49 PM
Some progress on the KFIR... I really hate this model and it's one of those cursed kits where everything goes wrong.  The paint (duck egg underneath and tan on top) has been pebbling really bad.  Not sure if its a reaction to the tamiya primer, but I swear I've sprayed enamel over tamiya primers.  Anyhow... I'll continue the cammo this week and maybe get to decals.
Thanks,
John
    July, 2014
Posted by modelcrazy on Sunday, May 20, 2018 9:05 PM
Hang in there John, You're almost there.
I pulled the Comet out and wanted to knock it out. I have so much on my plate now I don't know which way to turn. At this point all of them will end up on the shelf of doom LOL.
Onward! The tracks are in pieces but I'm sure I can manage.
Steve
Steve
ON THE BENCH
1/72 Revell Eurofighter Typhoon Twin Seater
1/72 Airfix BV-141
1/48 Tamiya Mk.1 Swordfish
1/350 Tamiya Prince of Wales
In Que
1/72 Airfix Dakota Mk. IV
    April, 2005
Posted by taxtp on Sunday, May 20, 2018 10:28 PM
I've updated page one with Eric's Hawk. Nice job again Eric !
Thats 6 models we've rescued from the Shelf of Doooooooooom !
Nice work on the Kfir and Comet respectively John and Steve.
I've also managed to get the decals onto my P-47, I'll have some photos soon.
Cheers
Tony
    September, 2011
Posted by falconmod on Monday, May 21, 2018 8:09 AM
Finished this little guy this weekend!
John
On the Bench: 1/72 Ki-67, 1/48 Airfix P-51D
1/72 LS Dinah III, 1/72 Hasegawa T-33A
    July, 2014
Posted by modelcrazy on Monday, May 21, 2018 8:25 AM
John, that is so cute
Steve
ON THE BENCH
1/72 Airfix BV-141
In Que
    May, 2015
Posted by Griffin25 on Monday, May 21, 2018 10:07 AM
Awesome!
Griffin
    April, 2005
Posted by taxtp on Monday, May 21, 2018 11:39 PM
I think nifty is the right word. You are certainly kicking some goals with this GB John, thanks so much for clearing another model from the Shelf of Doooooooom !
That's seven models now that aren't spending an eternity on that shelf.
Here's the photo of my P-47 that I promised.
It's not too far away now.
Cheers
Tony
    December, 2002
Posted by Bish on Tuesday, May 22, 2018 2:06 AM
Nice job there John, i am going to have to get myself one of those eggplanes one of these days.
'I am a Norfolk man, and i glory in being so'
On the bench: Hasegawa 1/72nd Ju 188A
                      Fine Molds 1/72nd Me 410
    December, 2002
Posted by Bish on Tuesday, May 22, 2018 2:12 AM
taxtp
Cheers
Tony
That look relaly nice Tony, loike the markings.
I have been doing some work on my Tiger dio while trying to resist throwing my MiG for the Commonwealth GB into the bin. Hope to get some pics up at the weekend.
    April, 2005
Posted by taxtp on Tuesday, May 22, 2018 6:38 PM
Thanks Bish, I'd like to see how its coming along.
Cheers
Tony
    May, 2013
Posted by hogfanfs on Tuesday, May 22, 2018 7:33 PM
Wow! Gentleman, I step away for a few days, and I come back to some outstanding work!
AA, nice finish on the Alpha Jet!
 Bruce
    August, 2015
Posted by crown r n7 on Tuesday, May 22, 2018 7:34 PM
John how precious!
Tony sharply dressed thunderbolt.
 Nick.
    May, 2013
Posted by hogfanfs on Tuesday, May 22, 2018 7:39 PM
Ok, a quick update on the Type 4. I finished the dot filter with Wilder oil paints. I'm really liking how these Wilder product work. Granted, I still need to get used to them.
Here are a few pictures.
Next will be a pin wash, but I figured I would get the tools and exhaust installed. Then do some chipping and a few mild rust spots. More to come...
 Bruce
    April, 2005
Posted by taxtp on Tuesday, May 22, 2018 9:33 PM
Looking good Bruce. I'm very interested in your weathering process.
Cheers
Tony
    November, 2008
Posted by mrmike on Tuesday, May 22, 2018 11:22 PM
Same here, the streaking looks great!
    August, 2015
Posted by crown r n7 on Wednesday, May 23, 2018 6:11 AM
Bruce that wash is looking real good.
here are my latest pics with a pin wash with master touch oil paint.
 Nick.
    May, 2015
Posted by Griffin25 on Wednesday, May 23, 2018 8:07 AM
Bruce and Nick both of your projects are looking great. Two different subjects with excellent painting and weathering teqniuqes.
Griffin
    April, 2003
Posted by keavdog on Thursday, May 24, 2018 9:10 PM
Bruce - looking really nice!  Nick, sharp!
Aint she pretty all dressed up in sausages
Fresh out of the spray booth - let it set up a couple days and more sausages and then the green.
Thanks,
John
