Aces on the Wrong Side of History GB - 2018
    August 2015
Posted by crown r n7 on Thursday, July 5, 2018 8:07 AM
Chad thankyou I sprayed x-22 on the decals getting ready for weathering,working on pilot now
Steve many thanks my friend the 190 looks right on the money nice camo .
Clint thank you sir  btw Ive had good results with tamiyas decal solutions
SS thank you for your comments the xf-86 should lighten it some I hope not to much.
Nick.
Posted by Bish on Sunday, July 8, 2018 9:28 AM
Got the Stuka un wrapped from its masking and ready for decals. I did the camo then masked off for the yellow markings, i am going to use the decals for the yellow V on the wing.
Next up, decals and weathering then a white wash.
''I am a Norfolk man and i glory in being so''
On the bench: Revell 1/72nd S-100/AMT STAP/ Youngs Miniatures 1/10th Templar Bust
    April 2015
Posted by Mopar Madness on Sunday, July 8, 2018 10:20 AM
Nice Bish.  Stukas definitely have a face only a mother could love!
Chad
God, Family, Models...
At the plate: 1/144 Revell Snowberry
On deck: 1/48 Tamiya Fw 190A4
In the hole: 1/48 Hasegawa Fw 190A4
    August 2012
Posted by Rambo on Sunday, July 8, 2018 11:02 AM
Camo turned out great Bish
Clint
Posted by Bish on Sunday, July 8, 2018 1:09 PM
Cheers guys. Chad, agreed, probably why i love em Big Smile
    August 2012
Posted by Rambo on Sunday, July 8, 2018 5:47 PM
I've taking some vacation time and took all week off, sadly not much time at the bench it was used to finish my front porch. What I did get done was masking the canopy and getting it installed. From the looks of it some of the masks that came with it are just a tiny bit small in places but slight over spray should be easy to remove.
BF 110 E 15
BF 110 E 14
Clint
    April 2015
Posted by Mopar Madness on Monday, July 9, 2018 10:26 PM
Masking a Bf 110 canopy is no small feat!
Chad
    August 2012
Posted by Rambo on Tuesday, July 10, 2018 12:17 AM
MM: Still time consuming but them pre cut masks make things alot easier.
Clint
    April 2013
Posted by SchattenSpartan on Tuesday, July 10, 2018 4:56 AM
Bish, that base camo looks really good. I'm looking forward to seeing that Stuka with the whitewash on it.
Clint, almost all the Eduard masks I've used so far have problems with being a little bit too small in some places. They're not a perfect fit, but they still make masking canopies so much easier, especially big ones like on the 110.
    July 2014
Posted by modelcrazy on Tuesday, July 10, 2018 9:51 PM
I would have had this done now but I screwed up. Instead of applying decal setting solution to the fusalage and right wing cross I applied Testers thin cement Bang Head. Yeah....I was a little miffed. Luckly I caught the mistake quickly. It took me a second to figure out why the solution was melting the decal and paint. Anyway, fighting the urge to just toss the thing into the trash I set it aside, thought about it, scrapped off the fues cross and reapplied the paint. I masked the red stripe with a post-it note and peeled off the black Gruppe mark!
I'm going to Boise this weekend for 2 weeks and I'll see if I Have some extra 1/72 German decals in my decal box when I get there. The kit does'nt come with swastikas so maybe I can also find some of those as well. I really don't want to buy a whole new set.
    August 2012
Posted by Rambo on Tuesday, July 10, 2018 10:17 PM
Wow at least you caught it right away hope you find what you need.
Clint
    August 2015
Posted by crown r n7 on Wednesday, July 18, 2018 11:58 AM
Bish nice work on the stuka.
Clint that masking is tedious but you make it look easy.
Steve awesome 190 I did the same thing but on the under side of the zero's cowling let it dry some 0000 steel wool and repiant.
 I have been away from the bench for a few weeks. here are my latest pics. next comes clear flat and a light coat of gloss.
Nick.
    April 2015
Posted by Mopar Madness on Wednesday, July 18, 2018 12:55 PM
 I love that streaking under the fuselage!
Chad
    August 2015
Posted by crown r n7 on Wednesday, July 18, 2018 1:39 PM
Chad thank you it’s thinned oil paint.
Nick.
    August 2012
Posted by Rambo on Wednesday, July 18, 2018 2:33 PM
Crown: Great weathering
Clint
    August 2012
Posted by Rambo on Wednesday, July 18, 2018 6:23 PM
Got the 110 primed with Tamiya grey primer. Then preshaded using Tamiya nato black. The underside RLM76 was then sprayed using Lifecolor acrylic paint. The RLM76 was then masked and Tamiya white was sprayed followed by Lifecolor RLM04 yellow. The underside was all masked and RLM75 was sprayed alos using Lifecolor. This is where it sits now, tomorrow I will mask the 75 and spray the 74 then more masking and the molting will be put down. The size of the 110 will be like molting two 109s so not looking foward to it. This was my first time using Lifecolor paints I've had some tip dry that I never get with Tamiya but I'm going to blame that on the high wet temps. I started with thinning 50/50 with its own thinner that still seems to be a bit thick so next time will bump it to 40/60 paint/thinner. The color match is really good with the Lifecolor paint but I've had a chance to play with some Mission Model paint at a friends. It was just the best to use, so my plan is now to use up my few bottels of Lifecolor I got and start replacing them with Mission Model paints. I will still be using my Tamiya for IJN stuff and all my armor builds since I am very happy with my building process there. The only reason I went away from using Tamiya on German aircraft is wanting paint already color matched even tho I custom mix Tamiya for my armor but there is less colors for armor then for aircraft... Maybe I'm just crazy... anyway thanks for sticking with me here lol
BF 110 E 16
BF 110 E 17
Clint
    August 2015
Posted by crown r n7 on Wednesday, July 18, 2018 6:41 PM
Clint looking good !
Nick.
    April 2015
Posted by Mopar Madness on Wednesday, July 18, 2018 8:33 PM
Those 110’s really are beautiful birds. Yours is coming along nicely!
Chad
    August 2012
Posted by Rambo on Wednesday, July 18, 2018 8:47 PM
Thanks guys. MM they are beautiful I'm looking for the eduard F night fighter right now Imo the best looking 110
Clint
Posted by Bish on Thursday, July 19, 2018 3:57 AM
Thanks Nick.
Great work on that, you have a really nice effect on those panel lines.
Posted by Bish on Thursday, July 19, 2018 3:58 AM
The 110 is looking good Clint, look forwardto seeing the results of the mottling.
    August 2012
Posted by Rambo on Thursday, July 19, 2018 5:30 PM
Thanks Bish hopefully this weekend.
Clint
    August 2015
Posted by crown r n7 on Friday, July 20, 2018 10:10 AM
I managed to finish the flyer .
Nick.
    July 2014
Posted by modelcrazy on Friday, July 20, 2018 4:27 PM
Excelent Job on him Nick.
    August 2012
Posted by Rambo on Friday, July 20, 2018 4:34 PM
Great job on him Crown
Clint
    August 2015
Posted by crown r n7 on Friday, July 20, 2018 8:41 PM
Thank you Steve and Clint finished up the canopy tonight some little odds and ends to do.
Nick.
    August 2015
Posted by crown r n7 on Monday, July 23, 2018 9:58 AM
My Tamiya A6M5 is done. Painted with Tamiya xf-11 and xf-12. Weathered with masters touch oil paints. The decals are from the kit using Tamiya decal setting solutions.The pilot is also from the kit representing LT(jg) Tetsuzo Iwamoto with 80 victories?
Thank you for all your comments and for being in this GB.
Nick.
    July 2014
Posted by modelcrazy on Monday, July 23, 2018 10:26 AM
Looks beautiful Nick Yes
    May 2013
Posted by hogfanfs on Monday, July 23, 2018 10:58 AM
Nick,
Absolutely stunning work!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    August 2012
Posted by Rambo on Monday, July 23, 2018 11:23 AM
Great job Nick
Clint
