Ships of the British Flag GB.
Posted by Bish on Monday, October 15, 2018 6:36 AM
Looking really nice Steve. So do you brush paint all the fittings on the deck or do you mask it.
    July 2014
Posted by modelcrazy on Monday, October 15, 2018 7:49 AM
Cheers Eagle and Bish
Eagle, the "ballast" is to add weight so the model doesn't move as easily when on the shelf. They are very light when completed.
Bish, I brush the fittings. That's the major reason I use Vallejo on ships.
Steve
    November 2010
Posted by Eagle90 on Monday, October 15, 2018 7:53 AM
modelcrazy
I see.  That makes sense.  I think it will look very nice on the shelf when done.
Posted by Bish on Monday, October 15, 2018 8:00 AM
You musthave some steady hand there Steve, there a lot of l;ittle bits sticking through the deck to paint.
    December 2003
Posted by scottrc on Monday, October 15, 2018 2:48 PM
Steve, those wooden decks and all the PE details are going to be worth your time.  Let us know how the hose reels turn out.  I know I thought of doing them on a few carrier projects.
Eagle, welcome, that KGV kit is a really good one to start out on.  Fit is good and your don't have to build up all the small AA guns out of a dozen pieces (hee hee).
Well, I jinxed myself in my last posting when I praised how well this kit was going together.  I got the hull paint issue corrected and after stripping it down and getting a really nice flat, even coat laid on it, the hull slipped off the paint stand, bounced off the deck of my spray booth, and landed on the floor in a pile of cat fur.
I waited for the mess to dry, again stripped the hull of paint (I am really getting tired of the smell of Easy Off), and again laid a perfect coat of red oxide.
Then the fun began.  No matter how many times I test fitted the hull top and bottom before I painted, after both sets were painted with the best paint jobs I ever did, they would not fit up!
I trimmed, filed, and sanded until all mated well, then ran my liquid cement from the inside of the hull making sure none of it runs out and onto my paint job.
Everything looked grand, so I put is aside to go get some lunch.  When I came back, the seam on the starboard side seperated, then dried as hard as a rock.  ARGGH!
So I ended up cutting the two sections apart and using CA, glued them back together with constant pressure on the seams until the CA was cured.  I had a good adhesion between the upper and lower hull, but the CA frosted around the seam, so then I had to mask and touch up the areas that frosted. This is a part I really hate because I never seem to get the mask perfectly strait.  But for some reason, everything worked out.
Now I am putting the decks on, and typical Trumpeter, they are not fitting and needed a bunch of trimming.
I got the base all stained and ready to mount the hull.
And now I am fitting out all the deck housings and attaching them to the main deck.
    July 2014
Posted by modelcrazy on Monday, October 15, 2018 3:34 PM
Scott you are a trooper to be fighting that kit and still appear to have a good mood about. No doubt that all that hard work will end in a smashing jolly good build old boy....sorry something came over me for a sec there.
Steve
    May 2015
Posted by Griffin25 on Tuesday, October 16, 2018 3:39 PM
 Scott your painting looks top notch. Really like the way it's coming together bud.
Griffin
    December 2003
Posted by scottrc on Wednesday, October 17, 2018 3:59 PM
Thanks guys!
Funny thing about the Warspite is that is doesn't have yard arms and a lot of rigging as compared to other ships of this era.
    July 2014
Posted by modelcrazy on Wednesday, October 17, 2018 4:03 PM
When I was a lad I thought the yard arms on the WW1 warships were for sails because they were so prominent.
Steve
    December 2003
Posted by scottrc on Wednesday, October 17, 2018 4:25 PM
modelcrazy
Some truth to that due to many of the old salts in the Admiralty still had a hard time giving up tradition.
An anecedote was told about an argument Jackie Fisher had, when he lead the dreadnought program, was with the Admiralty insisting provisions for auxillary sail be made on the HMS Dreadnought.  This is a ship that was three times the gross tonnage of the largest sailing ship. The yards were used to dry the laundry.
I guess the same would hold true when sail was taking over oars.  1st rate 16th century ships had provisions for oars even though it would have had little effect in propelling the ship without sacrificing crew that was needed to work the sails.
    April 2015
Posted by Mopar Madness on Wednesday, October 17, 2018 8:22 PM
modelcrazy
Dumb question here but what are the yard arms for?
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2014
Posted by modelcrazy on Thursday, October 18, 2018 11:34 AM
Mopar Madness
WW1, mostly hold over from designers and flag lanyards. Pre and early WW2 flag lanyards, mid WW2 to present flag lanyards and real estate for electronics.
Steve
    November 2010
Posted by Eagle90 on Thursday, October 18, 2018 2:35 PM
Scott...your build is looking good!
Well, I got a little more done on the ship.  It is actually looking like a battleship!  Still, the painting will be the next big thing I think.  But we will get it done.  Enjoy!
    December 2003
Posted by scottrc on Thursday, October 18, 2018 4:33 PM
YesYes
Painting is the best part of building a 1/700 ship.  It takes so little paintBig Smile
    November 2010
Posted by Eagle90 on Friday, October 19, 2018 5:05 AM
scottrc
YesYes
True...for me, it's getting that little bit of paint into those small spaces.  LOL!  Embarrassed
    December 2003
Posted by scottrc on Friday, October 19, 2018 10:19 AM
Eagle90
scottrc
YesYes
Ultra fine needle in the airbrush at low pressure.  Steady hand, good lighting, and controlled breathing.
    July 2014
Posted by modelcrazy on Friday, October 19, 2018 10:38 AM
Eagle90
scottrc
YesYes
Steve
    November 2010
Posted by Eagle90 on Friday, October 19, 2018 11:56 AM
scottrc
Eagle90
scottrc
YesYes
Sounds like I'm back on the firing range!  LOL!
    November 2010
Posted by Eagle90 on Friday, October 19, 2018 11:57 AM
modelcrazy
Eagle90
scottrc
YesYes
Thank you!  I'll need the Force to guide me.  LOL!
    July 2014
Posted by modelcrazy on Sunday, October 21, 2018 10:17 PM
I worked some more on the deck and installed the barrels. The guns and hose reels are not glued on. The hose reels need hoses, the deck needs more things added and painted and of course the turrets need painting. It’s starting to move along now.
Steve
Posted by Bish on Monday, October 22, 2018 7:02 AM
Steve, that is looking very impressive.
When you say hose reels, i take it you mean those 2 objects next to the rear of those 2 turrets. What will you use for the hoses.
And i have not forgotten about the Sub. The decals are all on and pics taken, i just need to load them on the laptop. I have just been so focused of getting the decals on the Phantom this last week. I hope to have some sub pics up within a few days.
    July 2014
Posted by modelcrazy on Monday, October 22, 2018 9:04 AM
Cheers Bish,
Yes the hose reels are the two objects next to the turrets. There will be somehere around 14 or so of diffrent sizes scattered around the deck and superstructure when done. I bought some fishing rod thread to simulate the hoses. I'm hoping it's not too thin to simulate the hoses.
I can imagne the F-4 taking so much time, I saw the decal sheet you had. Whenever you get the pictures up are just fine, no hurry.
Steve
Posted by Bish on Monday, October 22, 2018 10:24 AM
Good thinking on the fishing line, will remember that.
Ye, its taken me since last Mon, but i should have them done tonight. And the Sub only needs masking and a flat coat and that will be just about done as well.
    August 2014
Posted by goldhammer on Monday, October 22, 2018 3:54 PM
MC - I'm going to have to withdraw from the GB.  Never got a start on her, and the house remodel is going to eat my time in a big way.  Got back together with my ex, and we are cleaning out and redoing the mobile home.  Way more involved than I thought it would be.
    November 2010
Posted by Eagle90 on Monday, October 22, 2018 3:54 PM
Well, I'm sure there are a lot of mistakes, but I think she's done!  I must admit, I had a fun time doing this kit.  I think I would like to try my hand at a 1/350 ship, but I also found myself thinking...hummmm, I whole line of these beautiful little WWII ships would look pretty cool lined up on the shelves.  Whistling.  Just sayin.  LOL!
It was fun and thank you modelcrazy for hosting an awesome GB and getting me out of my comfort zone and into a genre that WILL see me return.  Enjoy and I can't wait to see everyone elses builds.  I'm learning a lot from you all!  Keep up the great work!
Posted by Bish on Monday, October 22, 2018 4:32 PM
Thats a real nice looking ship there Boddy, well done.
    November 2010
Posted by Eagle90 on Monday, October 22, 2018 5:29 PM
Bish
Thank you sir.  It was fun to do!
    July 2014
Posted by modelcrazy on Monday, October 22, 2018 7:22 PM
GH, no worries my friend, I completly understand. Focus on your remodel and you'll be proud of it when it gets done. The GB is going on till Aug 1 2020 so if you feel you have time later, then just give me a holler, I'm not going anywhere.
I'm starting and American Ship GB Aug 1 2019 that goes 2 years and a German Ship Aug 1 2020, then Japanese. You have years to join again with something.
Steve
    July 2014
Posted by modelcrazy on Monday, October 22, 2018 7:44 PM
Awsome job Bobbie!! Yes Oops, too American, cracking job mate!! You aced that one Beer
Yeah, those little waterline kits look great on the shelf, just the right size for a small navy. Years ago I had several Japanese cruisers and just loved them....I wonder whatever happend to those???????.....Confused hum...anyway, I'll get you up on the wall and remember the US Navy starts next year Aug 1. A nice Bama, Washington or Yanky Iowa would partner right up to the bar with your British friend there.
Raise the Union Jack and let it wave proudly!!
Steve
    November 2010
Posted by Eagle90 on Tuesday, October 23, 2018 5:58 AM
modelcrazy
Thank you sir.  It was a really fun kit to do....and I think I will be keeping my eyes out for some others.....can't have it sitting there by itself now can I?
I like the quote!!!  Very fitting.  Thanks again!
