Ships of the British Flag GB.
    July, 2014
Posted by modelcrazy on Tuesday, January 29, 2019 8:15 PM
It is really looking awesome Drums.
Steve
ON THE BENCH
1/72 Revell Eurofighter Typhoon Twin Seater
1/72 Revell MiG 29 UB Fulcrum
1/48 Tamiya Mk.1 Swordfish
1/350 Tamiya Prince of Wales
Yes, it's a lot!
In Que
1/72 Airfix Dakota Mk. IV
    May, 2013
Posted by hogfanfs on Tuesday, January 29, 2019 8:50 PM
modelcrazy
Bruce. I'm not a fan of EZ line. I know several people have great results with it but it's too fickle to temp changes for me. My main go to is streched sprue but that also has it faults, several of them.
I purchased some stuff called Uschi. It's a little pricy and I haven't used it yet, but it is extreamly elastic and watching some YouTube vids on it, it looks very easy to apply. My only complaint with it so far, which shouldn't be a complaint, is that it is very small. That makes it more to scale but harder to see.
Thanks for the info, Steve. I'm going to get some of this Uschi and see how it works.
 Bruce
GAF
    June, 2012
Posted by GAF on Tuesday, January 29, 2019 11:39 PM
Ben>  That is a great build.  Your craftsmanship is exemplar, sir.  Smile
Concerning mast lines, I might recommend something called Coats Transparent Thread.  It's polyester and can be found in the sewing section.  Here's the Amazon listing, but I wouldn't be surprised if Hobby Lobby or Michaels had it in stock.
https://www.amazon.com/Coats-Thread-Zippers-S995-9950-Transparent/dp/B001ELD3AS/ref=sr_1_4/140-4864222-5880040?ie=UTF8&qid=1548826340&sr=8-4&keywords=coats+transparent+thread
It comes in transparent and dark.  I use the dark thread for antenna wire, and looks fine on 1/72nd scale aircraft.  I don't know about its longevity, but it is polyester so I think it will hold up well.  Just a suggestion.
Gary
    December, 2002
Posted by Bish on Wednesday, January 30, 2019 2:07 AM
Ben, that is some amazing workyour putting in there.
'I am a Norfolk man, and i glory in being so'
On the bench: Hasegawa 1/72nd Ju 188A
                      Fine Molds 1/72nd Me 410
    December, 2002
Posted by Bish on Wednesday, January 30, 2019 2:10 AM
hogfanfs
Gentleman,
I have a general question about mast lines. I've heard recently that EZ-line tends to break after a few years? I bought some, but haven't attempted to use it yet.
So, what are you using for mast lines?
Bruce, i was useing EZ line for a while for aircraft antenna wires. I have a couple of aircraft that were not a few years ago and have had no issues with it braking. But i have noticed a couple where its starting to sag. I stopped useing EZ line for a couple of reasons and swityched to 1Ib fishing line, but i am not sure what to do for ships.
    June, 2018
Posted by DRUMS01 on Wednesday, January 30, 2019 10:31 AM
All,
Thanks for the motivating comments... I hope I can live up to your expectations when done.
When I get to the rigging, I plan on using the poly or nylon sewing threads. I have a Hobby Lobby, a fabric store, and a Michael's all in less than 3 miles; I will let ya'll know what I find as well as photos of my end result.
Ben
I am a veteran; to all others thank you for your service. I hope you found peace after your tour of duty, you have earned it...
PROJECTS:
- 1/48 C-130 - Staged
- 1/16 Kubelwagen (GB) - Started
- 1/350 HMS Roberts (GB) - Done
- 1/35 STRV -103 MBT (GB) - Done
- 1/48 X-15 (GB) - Done
- 1/48 Eagle Lunar Module (GB) - Done
    June, 2018
Posted by DRUMS01 on Thursday, January 31, 2019 4:34 PM
Here is a small update....
Handrails and front crane done. The front crane is part scratch built, part after-market P.E. and some kit P.E. It will look better after paint...
additional details and more handrails
Boarding stairs and more handrails (I will fix that gap). You can also see one of the 8 boat davits which I added (less P.E.)...
P.E. on the yard arm (I think that is what they call it) and sensors on observation tower
I also tossed the kit soft and thin plastic pieces for the front flagstaff and rear ensign staff and replaced them with metal. I hope by using metal, it will reduce the chance of rigging sag.
Based on some of the other photos I took, I have alot of touch-up painting to be done and some minor fixes. The remaining parts from the kit are basically the aft boat davits, the port and starboard lifts, and those darn radar / signal arrays (multiple P.E. pieces). There is some other after-market P.E. for the rear boat davits, signal junctions by the bridge, and real, real, real, small stuff.
Once that is done then I will begin my weathering in earnest.
Oh!, and we cannnot forget the rigging....
Ben
PROJECTS:
    June, 2018
Posted by DRUMS01 on Sunday, February 03, 2019 4:01 PM
After looking at the various pictures of the HMS Roberts. I do not see many with the large boom on the front of the ship. Specifically, I do not see any photos with the boom in this camouflage scheme. Should I keep it or remove it?  What does everyone think?
Ben
PROJECTS:
    July, 2014
Posted by modelcrazy on Sunday, February 03, 2019 5:09 PM
I'd probably leave it off if you didn't see any refrence of it, but that's just me.
Steve
ON THE BENCH
Yes, it's a lot!
In Que
    May, 2015
Posted by Griffin25 on Tuesday, February 05, 2019 2:54 PM
That PE looks sweet Ben! Great job bud. I'm guessing it was removed while in theatre, the boom.
Griffin
    June, 2018
Posted by DRUMS01 on Wednesday, February 06, 2019 12:46 PM
Hey Everyone,
Regarding string or thread for ships rigging. I found that the retail chain, Hobby Lobby (in the USA) has a crazy mix of sizes and colors. Depending on your scale, the jewelry/craft area has many nylon, metal, thread, cord, string, etc. that can be used for 1/72 and larger detailing. They had several metallic infuzed woven threads that look like a fantastic replacement for armor tow cables from 1/72 to 1/24.
For 1/350 to 1/700 ships, the only extra thin and resilient thread I could find was made by Sew-Ology (from Europe), item # 1254580, for $2.99. It is extremely thin (.1001= like a human hair), 100% nylon, and comes in a spool of 400 yards or 365 meters (that works out to a lot of model kits!).
They only stock it in clear / transparent, but I am sure one swipe with a permanent marker will make it any color you want (black, brown, metallic, etc.). It is very strong as I have tried holding 12 pounds on a tinsel of the thread for 24 hours with no problem. Since it is nylon and thin, it should set easily on scale masts and towers with most any CA glue. You will be seeing it on my 1/350 HMS Roberts, Monitor.
Ben
PROJECTS:
    May, 2013
Posted by hogfanfs on Wednesday, February 06, 2019 1:23 PM
Ben,
I'm looking forward to seeing your HMS Roberts strung up, so to say. And I'm going to have to take a trip to Hobby Lobby. Thanks for the info!
 Bruce
    June, 2018
Posted by DRUMS01 on Thursday, February 07, 2019 7:08 PM
Here are a couple teaser photos of the initial rigging. I still need to finish the colors and details. Yes, the nylon thread is very thin....
My special needs son is helping me on the wood base I've created. Nothing to fancy, just a routed wood base, the kit name plate painted to look like aged or antiqued copper, and the ship.
My next photos will show the final reveal.
Ben
PROJECTS:
    July, 2014
Posted by modelcrazy on Thursday, February 07, 2019 7:31 PM
Outstanding job Ben. I'm looking forward to your reveal.
Steve
ON THE BENCH
Yes, it's a lot!
In Que
    June, 2018
Posted by DRUMS01 on Sunday, February 10, 2019 2:28 PM
I am calling this one D-O-N-E. I present to everyone my version of the HMS Roberts WW2 Monitor. Please keep in mind that this is my first ship / boat in around 20 years.
The more of it I built, the more I appreciated those scale ship builders in our forum. It was challenging, but really fun. Thank you for allowing me to participate in this GB.
Till next time,
Ben
PROJECTS:
    July, 2014
Posted by modelcrazy on Sunday, February 10, 2019 4:08 PM
Cracking job mate Yes Bow Down
I REALLY like the weathering! The dry brushing worked like a charm.  The base complements it extreamly well. I'll get your beauty up in a few with your quote.
Thank you for joining in Ben, it's been a pleasure watching it come together. I hope you will consider my American GB coming August 1st.
One of the reasons I'm hosting all of these ship GB's is to hopefully help those who are willing, to expand their skills and step out of their comfort level. You have exceded that.
I'm assuming you prefer the first picture, but let me know if you would rather a diffrent one.
Steve
ON THE BENCH
Yes, it's a lot!
In Que
    December, 2002
Posted by Bish on Sunday, February 10, 2019 4:27 PM
Ben, no need to consider thats your first ship in years, its a beauty by anyones standards. Thats a great finish on an unusal ship.
    May, 2013
Posted by hogfanfs on Sunday, February 10, 2019 6:33 PM
Ben,
Absolutely a wonderful finish on the HMS Roberts. The weathering is fantastic, and well as the rigging. Outstanding job!
 Bruce
    May, 2015
Posted by Griffin25 on Sunday, February 10, 2019 6:56 PM
Ben that is an incredible looking build. What a beautifully detailed and weathered finish. That beauty needs to be under glass in a museum. Great job bud !
Griffin
    April, 2006
Posted by jgeratic on Sunday, February 10, 2019 10:08 PM
Ben, heck of a job, definitely to be proud of.  All that detail crammed in from stem to stern -Yes
regards,
Jack
    June, 2018
Posted by DRUMS01 on Monday, February 11, 2019 10:43 AM
Thank you very much everyone.... It seemed daunting for a car guy, and considering I did not build a ship in around 20 years. The P.E. was intimidating, but the more I got into the build, the more I really enjoyed it. Through this kit, I have come to gain new respect for our forums ship modelers (and have become one too!).
I look forward in joining the American ship GB later this summer. I've already purchased the 1/350 Banner kit of the USS Arizona. After looking at it, I have recently purchased a wood deck and some P.E from Tom's Modelworks.....
Till then, keep your main deck above water and wind in your sails....
Ben
PROJECTS:
    December, 2003
Posted by scottrc on Monday, February 11, 2019 10:54 AM
Cracking job Ben, real smashing!  You should be proud.
I look forward to building with you in the American ship GB.  I built the Banner 1/350 Arizona and its not a bad kit.  The deck housings require some little tricks to be done.
Scott
