The Race Into Space GB, October 2018 - July 2019 (Ended)
    November 2010
Posted by Eagle90 on Saturday, November 10, 2018 10:36 AM
modelcrazy
Eagle, that S1B looks so great
Thank you sir.  It is a great kit Airfix did.  Can't wait to do the Saturn V's.
    November 2010
Posted by Eagle90 on Saturday, November 10, 2018 10:37 AM
hypertex
Update on my Lunar Module Eagle:
This is my fourth attempt at turning an RCS thruster skirt. I'm almost there, but I'm not sure I've got the shape quite right. This is turned by hand from aluminum rod.
That is AWESOME!!!!!!  Spectacular work!
    November 2010
Posted by Eagle90 on Saturday, November 10, 2018 10:39 AM
Gamera
Bobby: She looks friggin' fantastic!!!
Hypertex: Looks amazing to me. I'm really impressed what can be done on a lathe.
Anyway great to see people getting stuff done that's more useful than watching horror movies like me... Embarrassed
Thank you sir.  I'm getting ready to paint the base Semi Gloss Black.  Hope that works.  LOL!
    November 2010
Posted by Eagle90 on Saturday, November 10, 2018 10:45 AM
[quote user="Bakster"]
[quote user="Eagle90"
[/quote]
Eagle, it looks really good! Question: How are you painting it? Are you using an airbrush? Or are you hand painting? Just curious. It looks great!
[/quote]
Hey Bakster,
Thank you for the kind words.  The Airfix kit is a really nice one.  Reccommend them to anyone thinking of doing the Space kits they have.
I'm airbrushing all on this one.  The taping off the odd patterns was the most time consuming.  But I AB'd the black, satan white, and the little bit of silver ( I think I actually used flat aluminum).  I'm using rattle cans for the clear gloss coats.
    May 2011
Posted by Real G on Saturday, November 10, 2018 12:16 PM
Hypertex, that is bazonkers!!!  RCS thruster?  You mean you are going to turn 16 of them?  Or is it to replace a missing part?  Hope it’s the latter.
Eagle90, that Apollo 7 is looking great!  Love the first stage, so different from all the other typical single cylinder ones.
“Ya ya ya, unicorn papoi!”
    November 2010
Posted by Eagle90 on Saturday, November 10, 2018 2:02 PM
Real G
Thank you!  And I agree.  It does set it apart from the other rockets.
    July 2014
Posted by Bakster on Saturday, November 10, 2018 2:29 PM
Eagle90
Excellent. Nice work.
GAF
    June 2012
Posted by GAF on Saturday, November 10, 2018 10:15 PM
Gamera>  Nah, it's okay to post the video!  I've derailed a couple of threads in my time.  Wink
Eagle90>  That is a gorgeous S1B!  Looks like you'll have your astronaut wings soon!  Considering how small the model is you did a great job at masking.
Hypertex> That's just some serious work!  I must admit, I wish I had a lathe (and a workshop).  I went to Harbor Freight just day before yesterday to price one and it was $650.00.  Bit out of my price range for the amount of use I would get out of it.  The RCS nozzle looks about right.
Project Report:
After the engineer for the previous tower support structure was reassigned, a different approach was recommended to reconstruct the framework.  Using some new rod material, the main legs were glued to the bottom of the nozzle skirt one at a time and allowed to dry.  Some tacky glue was used so there would be some play once all legs were attached.  Once that was accomplished, the legs were fitted to the top of the capsule cover and taped into position so that final adjustments could be made to the shape and length of the tower.  Measurements using the Mk. 1 EPS (Eyeball Positioning System) proved satisfactory.  In the following photograph you can see the resulting new support legs, and the old structure.  The old support structure will be cannibalized for parts as needed.
Mission Director (GAF)
Today in Space History:
1968 November 10 - . 19:11 GMT - . Launch Site: Baikonur. Launch Complex: Baikonur LC81/23. LV Family: Proton. Launch Vehicle: Proton-K/D. Zond 6 - . Payload: Soyuz 7K-L1 s/n 12L. Mass: 5,375 kg (11,849 lb). Nation: Russia. Related Persons: Bushuyev. Agency: MOM. Program: Lunar L1. Class: Manned. Type: Manned spacecraft. Spacecraft Bus: Soyuz. Spacecraft: Soyuz 7K-L1 . Duration: 5.79 days. Decay Date: 1968-11-17 . USAF Sat Cat: 3535 . COSPAR: 1968-101A. Apogee: 400,000 km (240,000 mi). Perigee: 200 km (120 mi). Inclination: 51.5000 deg. Period: 15,562.22 min.
Test flight of manned circumlunar spacecraft. Successfully launched towards the moon with a scientific payload including cosmic-ray and micrometeoroid detectors, photography equipment, and a biological specimens. A midcourse correction on 12 November resulted in a loop around the moon at an altitude of 2,420 km on 14 November. Zond 6 took spectacular photos of the moon's limb with the earth in the background. Photographs were also taken of the lunar near and far side with panchromatic film from distances of approximately 11,000 km and 3300 km. Each photo was 12.70 by 17.78 cm. Some of the views allowed for stereo pictures. On the return leg a gasket failed, leading to cabin depressurisation, which would have been fatal to a human crew. The 7K-L1 then made the first successful double skip trajectory, dipping into the earth's atmosphere over Antarctica, slowing from 11 km/sec to suborbital velocity, then skipping back out into space before making a final re-entry onto Soviet territory. The landing point was only 16 km from the pad from which it had been launched toward the moon. After the re-entry the main parachute ejected prematurely, ripping the main canopy, leading to the capsule being destroyed on impact with the ground. One negative was recovered from the camera container and a small victory obtained over the Americans. But the criteria for a manned flight had obviously not been met and Mishin's only hope to beet the Americans was a failure or delay in the Apollo 8 flight set for December. The next Zond test was set for January.
1985 November 10 - . Launch Site: Baikonur. Launch Complex: Baikonur Jubilee.
  • Buran Analog BST-02 flight 1 - . Crew: Stankevicius, Volk. Nation: Russia. Related Persons: Stankevicius, Volk. Program: Buran. Class: Manned. Type: Manned spaceplane. Spacecraft Bus: Buran. Spacecraft: Buran Analogue. Maximum speed 480 kph. Maximum altitude 1500 m. Time 12 minutes.
  • Cosmonaut Igor Volk was at the controls; takeoff was from the Zhukovskiy test flight centre near Moscow. Two flying labs, based on Tu-154 transports, were used to prior to this to duplicate anticipated Buran handling and test systems software. They conducted 140 flights before Buran's first flight, including 69 automatic landings at Zhukovskiy and at the Jubilee airfield at Baikonur.
    June 2018
Posted by DRUMS01 on Sunday, November 11, 2018 2:21 AM
hypertext; nice mill work I think the shape is near perfect.
What scale is this again?
v/r,
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    October 2010
Posted by hypertex on Sunday, November 11, 2018 7:35 AM
DRUMS01
v/r,
Ben
Ben, I'm building the 1/48 scale Dragon kit of the LM.
Real G, yeah, I'm planning to turn 16 of those RCS thrusters. Maybe there's something wrong with me! Smile
Thanks, everyone for the kind compliments. I must admit I really am a newb when it comes to turning parts on the lathe. I actually use a woodworking lathe, which doesn't have a tool holder, or tool carriage, or cross slide, etc. So I must hand turn everything. I've had the lathe since about 2004 or so, when I took up woodturning as a minor hobby. So it was a bit by luck that I had that thing still sitting around when I got back into modeling--I almost got rid of it!.
But yeah, I wish that harbor freight mini lathe was a bit cheaper--but I've got my eyes on it. I figure that if I were to abstain from purchasing new kits for an entire year, I would be saving about enough money to purchase one. Do I have the will power? Not since Airfix announced their 1/24th scale Hellcat, sigh.
Anyway, well done to those who are making great progress on their builds, I am jealous because I don't have much to show you yet, although I have been working hard on it.
Veterans: I would like to give a shout out to all the veterans on this Veteran's Day. Thank you all for your service.
    November 2010
Posted by Eagle90 on Sunday, November 11, 2018 2:28 PM
Well, I think that's a wrap for the Saturn IB.  What a fun kit.  The taping of the booster stage was a challenge, but other than that, what a great build...and a great GB!  Enjoy!
The work here will keep me intrigued for some time.  Great work everyone!
GAF...thank you for hosting an awesome GB!
    January 2015
Posted by PFJN on Sunday, November 11, 2018 2:48 PM
Congratulations Big Smile
Is this our 1st completion for this group build?
PF
1st Group BuildSP
    July 2014
Posted by Bakster on Sunday, November 11, 2018 3:41 PM
Eagle 90, that is outstanding work that you did. She is a beauty!
YesYes
    July 2014
Posted by modelcrazy on Sunday, November 11, 2018 5:22 PM
Beautiful build, just beautiful.   Great looking plaque as well.
Steve
GAF
    June 2012
Posted by GAF on Sunday, November 11, 2018 6:28 PM
Eagle90>  That is outstanding!  The Airfix Saturn 1B certainly looks great, and your base is a really nice touch.  Well done sir!  Congratulations on being our first completion.  In recognition, and in addition to grabbing a Group Build Badge, I am awarding you our first "Astronaut Modeler" badge.  You've earned it!
I'll get the photo up on the front page ASAP (if the one you've posted is A-OK.
And Front Page updated! Big Smile
Project Report:
Construction of the new LES support tower continues slowly.  Cutting those rods, then  sizing, filing and fitting takes a bit of patience.  Progress is being made, however.  Today I even put the pieces together to see how she stood, and it's not bad.  Still a lot of work to do before final assembly.
1966 November 11 - . 20:46 GMT - . Launch Site: Cape Canaveral. Launch Complex: Cape Canaveral LC19. LV Family: Titan. Launch Vehicle: Titan II GLV.
  • Gemini 12 - . Call Sign: Gemini 12. Crew: Aldrin, Lovell. Backup Crew: Cernan, Cooper. Payload: Gemini SC12. Mass: 3,763 kg (8,295 lb). Nation: USA. Related Persons: Aldrin, Cernan, Cooper, Lovell. Agency: NASA Houston. Program: Gemini. Class: Manned. Type: Manned spacecraft. Flight: Gemini 12. Spacecraft: Gemini. Duration: 3.94 days. Decay Date: 1966-11-15 . USAF Sat Cat: 2566 . COSPAR: 1966-104A. Apogee: 289 km (179 mi). Perigee: 250 km (150 mi). Inclination: 28.8000 deg. Period: 89.90 min.
    Two very serious astronauts get it all right to end the program. Docked and redocked with Agena, demonstrating various Apollo scenarios including manual rendezvous and docking without assistance from ground control. Aldrin finally demonstrates ability to accomplish EVA without overloading suit by use of suitable restraints and careful movement.
    Major objectives of the mission were to rendezvous and dock and to evaluate extravehicular activities (EVA). Among the secondary objectives were tethered vehicle evaluation, experiments, third revolution rendezvous and docking, automatic reentry demonstration, docked maneuvering for a high-apogee excursion, docking practice, systems tests, and Gemini Agena target vehicle (GATV) parking. The high-apogee excursion was not attempted because an anomaly was noted in the GATV primary propulsion system during insertion, and parking was not attempted because the GATV's attitude control gas was depleted. All other objectives were achieved. Nine spacecraft maneuvers effected rendezvous with the GATV. The onboard radar malfunctioned before the terminal phase initiate maneuver, but the crew used onboard backup procedures to calculate the maneuvers. Rendezvous was achieved at 3 hours 46 minutes ground elapsed time, docking 28 minutes later. Two phasing maneuvers, using the GATV secondary propulsion system, were accomplished, but the primary propulsion system was not used. The first of two periods of standup EVA began at 19 hours 29 minutes into the flight and lasted for 2 hours 29 minutes. During a more than two-hour umbilical EVA which began at 42 hours 48 minutes, Aldrin attached a 100-foot tether from the GATV to the spacecraft docking bar. He spent part of the period at the spacecraft adapter, evaluating various restraint systems and performing various basic tasks. The second standup EVA lasted 55 minutes, ending at 67 hours 1 minute ground elapsed time. The tether evaluation began at 47 hours 23 minutes after liftoff, with the crew undocking from the GATV. The tether tended to remain slack, although the crew believed that the two vehicles did slowly attain gravity-gradient stabilization. The crew jettisoned the docking bar and released the tether at 51 hours 51 minutes. Several spacecraft systems suffered problems during the flight. Two fuel cell stacks failed and had to be shut down, while two others experienced significant loss of power. At 39 hours 30 minutes ground elapsed time, the crew reported that little or no thrust was available from two orbit attitude and maneuver thrusters.
  • 1968 November 11 - . Launch Vehicle: Saturn V.
    • Paine gives Apollo 8 go-ahead for lunar orbit mission. - . Nation: USA. Related Persons: Low, George, Paine. Program: Apollo. Flight: Apollo 8. Spacecraft: Apollo CSM, Apollo LTA. Low's initiative had paid off; the final decision to go to the moon in 1968 was made with the blessings of all of NASA's decision-makers, the Apollo Executive Committee, STAC, and PSAC..
    November 2010
Posted by Eagle90 on Sunday, November 11, 2018 6:48 PM
PFJN
PF
Thank you!  I had a blast with this kit.
    November 2010
Posted by Eagle90 on Sunday, November 11, 2018 6:50 PM
Bakster
YesYes
Thank you..you are too kind.  The kit was great and this is an awesome GB!  I can't wait to see the rest of the builds finished.
    November 2010
Posted by Eagle90 on Sunday, November 11, 2018 6:52 PM
modelcrazy
Thank you!  I was hoping the base would turn out alright.  I'm glad I did it in black, I think that is what makes it.
Wow!  Lord Vader is impressed..I'm honored.
    November 2010
Posted by Eagle90 on Sunday, November 11, 2018 6:54 PM
GAF
Project Report:
WOAH!  I'm speechless.....thank you sir..very much!  My own badge!?  I will wear it with pride.  Again, thank you sir for a great GB!  Can't wait to see what your next one will be.  Wink
    June 2018
Posted by DRUMS01 on Sunday, November 11, 2018 6:57 PM
Eagle 90, simply a beautiful build! I cannot wait to see all the other completions.
While my build will pale in comparison to many here, I believe I am putting a fork in it to call it D-O-N-E as well. I present my 1/48 Monogram Apollo 11 Lunar Module "Eagle". I had alot of fun and actually learned some things along the way. Depending on how my other GB's go, I may return to build another here.
Thanks GAF for organizing and administering this GB, it was real fun. Thanks to everyone else for your friendship and encouragement. My next build will be modern armor....
After these photos I noticed I needed to dull down the lunar base. I will get that done but don't expect another photo (smile).
Until next time....
Ben
LAST COMPLETED:
NEXT PROJECT:
    July 2014
Posted by Bakster on Sunday, November 11, 2018 7:44 PM
Wow! You guys rule!
Ben, that lunar module with moonscape rules! That is so cool! The astronauts are awesome too! Seriously, you should be proud of what you created.
Man, you put a lot of work into that, and it sure paid off. Nice job sir.
Congrats!
YesYes
Two completions in on day. Incredible.
GAF
    June 2012
Posted by GAF on Sunday, November 11, 2018 7:48 PM
Drums01> I must admit you've set a high goal for others to follow! Eagle90 beat you to first by just a few minutes, but you've certainly made quite a splash with the scratch-building you've done!   That is just a work of art.  That LM is detailed out to the max!  Congratulations!
I must admit those astronaut figures turned out well, along with all the instruments for the lunar landscape.
As with Eagle90, I am proud to award you (in addition to a Group Build Badge of your choice) the second set of "Astronaut Modeler" wings.  I salute you, sir and a hearty well done!
I think the 4th image of the entire diorama would be best for the front page.  If  you would rather have another image, just let me know.
Eagle90 and Drums01>  I think both of you should consider submitting your models to FSM, at least to the Reader's Gallery.  Personally, I think it would be nice if FSM did a "spacecraft" issue for the 50th anniversary of the Apollo moon landing next year and included your works in it.  I think they're that good.
Gary
    July 2014
Posted by modelcrazy on Sunday, November 11, 2018 7:59 PM
Oh my, you're done too Drums? Wow, great job on the Lunar Module, that's fantastic.  What a great display! I'd be proud to show that. You did a lot of work and put a lot of time into it and it shows.
Gary, that's a great idea, giving a special badge for the first completed is so cool! Mind if I barrow that idea?
For my build, I assembled the Saturn V. I need to finish the escape tower, fill and sand the seams. I found the missing fin BTW. It was hiding in the flap of the box.
Steve
GAF
    June 2012
Posted by GAF on Sunday, November 11, 2018 8:10 PM
I'm glad everyone is enjoying the Group Build.  Some amazing work going on in here.  Smile
In addition to the build images, I said I would be posting up some other photos of space related subjects as we went along.  In that vein, here are some photos taken at the Historic Aviation Memorial Museum (HAMM) in Tyler, Texas.   http://www.tylerhamm.com/
They have some artifacts and models related to the space age, and here's some of them.
And a Russian High Altitude Pressure Suit.
Gary
GAF
    June 2012
Posted by GAF on Sunday, November 11, 2018 8:15 PM
modelcrazy
Oh my, your done too Drums? Wow, great job on the Lunar Module, that's fantastic.  What a great display! I'd be proud to show that. You did a lot of work and put a lot of time into it and it shows.
Modelcrazy>  Sorry if it came across as something for First Completion!  I was intending to give astronaut badges to everyone who finished.  Maybe a "Senior Astronaut" badge to those who finish more than one build!  Now that you've mentioned it, a "First Completion" badge would have been a good idea!  Darn it!  Sad
That SV is looking good!  Glad you found the fin where the modeling gods hid it! Big Smile
Gary
    July 2014
Posted by modelcrazy on Sunday, November 11, 2018 8:28 PM
GAF
No problem Gary, individual badges are also a great idea. I'm giving quotes from Nelson, Churchill etc for those who finish on my British ship GB. It's always nice to get a little something extra for ones work.
Steve
    November 2010
Posted by Eagle90 on Monday, November 12, 2018 8:46 AM
[quote user="DRUMS01"]
Thank you sir.  And may I say your Lunar Lander is spectacular!  Awesome job!
    November 2010
Posted by Eagle90 on Monday, November 12, 2018 8:48 AM
GAF
Gary
Wow!  Great pics!!!!  I have that same Russian High Altitude helmet!  My wife got it for me one Christams while we were stationed in Germany.
    June 2018
Posted by DRUMS01 on Monday, November 12, 2018 1:01 PM
Thanks GAF and Thanks Baksster....
I really did not think it was that good. Based on your remarks I have taken new photos once I corrected the moon surface and some painting. I also added the NASA meatball to the rear of the astronaut pack and also added a checklist to the left glove gauntlet of each astronaut. The photos are with a better black background and a little more effort applied.
LAST COMPLETED:
NEXT PROJECT:
    July 2014
Posted by Bakster on Monday, November 12, 2018 2:24 PM
Drums... I am smiling here. Those images are awesome! It looks real!
