The Race Into Space GB, October 2018 - July 2019 (Ended)
    March 2010
Posted by mach71 on Sunday, March 31, 2019 6:15 PM
Looking great! And I just saw that your decals say Wright field, I've never seen those on the X-1. I know it was briefly based there before moving to Muroc field.
    July 2014
Posted by modelcrazy on Sunday, March 31, 2019 7:32 PM
Outstanding finish on you X1. The decals are looking great Surprise. I will sometimes have issues with applying Solvaset first. As soon as I have problems with the first decal, which is usually some small insignificant one, I'll go to water then finish with Solvaset.
Steve
    January 2015
Posted by PFJN on Sunday, March 31, 2019 8:20 PM
Hi,
I kind of hit a wall on my mini shuttle build a while ago, not being sure how to proceed on the cockpit windows.  As such, I had messed around with a couple ideas but hadn't made a lot of progress, and ended up kind of setting the kit aside (for the most part) as I worked on a couple other builds.  However, now that I am close to finishing up those other builds I have had a chance to get back to the mini shuttle, as shown below.
Initially I had considered just using decals for the windows and frames, but then decided to try making some frames out of thin strip styrene and using putty to fair their edges into the rest of the cockpit.  Unfortunately I ended us messing that up a bit, so using some of the styrene strips that I glued on as a guide, I ended up "carving away" some of the paint, putty and other material until I had some window outlines that I am mostly happy with.
I think that after a little more clean up I can paint the windows themselves and put on a final coat of white on the rest of the cockpit, and repaint the anti-glare patch infront of the cockpit.  Then I will try and give the whole model a coat of clear/Future and apply the decals.  Unfortunately along the way I have managed to break off both main landing gear, so I will also try and rebuild thoses tooTongue Tied.
Overall though I am hoping to finish up soon. Smile
Pat
123
1st Group BuildSP
    July 2014
Posted by modelcrazy on Sunday, March 31, 2019 8:41 PM
That's a good idea for the windows, good job. Yes
Steve
    July 2014
Posted by Bakster on Sunday, March 31, 2019 8:44 PM
mach71
Thanks, Mach. Yeah, I wondered about the Wright Field decal too. I didnt know it was based there. I figured or hoped Eduard got it right.
    July 2014
Posted by Bakster on Sunday, March 31, 2019 8:53 PM
modelcrazy
Thanks, Steve. I almost hate to dull the gloss with flat.
Thanks too about Solvaset. It's a learning moment for me. I hope I remember the lesson next time.  Tongue Tied
    July 2014
Posted by Bakster on Sunday, March 31, 2019 8:55 PM
Pat, like MC said, nice work on the Windows. It looks good!
GAF
    June 2012
Posted by GAF on Monday, April 1, 2019 12:07 AM
Wow!  You guys have been busy!  Glad to see things have picked up!
Mach71>  That Mercury capsule just keeps looking better and better!  I think Gordo is going to be awesome!  Guess the vinyl paint is working?  And thanks for the tip on fishing bobbers!  I had thought I might need some round balls for future pressure tanks, and that is a good idea.  Bobbers come in different sizes, and since ball bearings are hard to come by, I think I'll visit the local Walmart and check the fishing supplies!  I think semi-gloss is the way to go, though it really depends on the type of gloss coat you use rather than the paint.
Bakster>  Glad the decals got sorted!  She looks good.  I did not know you were using Solvaset when adding the decals!  I've always used that after the decals were in place, not before!
PFJN>  Hey!  Glad to see you back!  The shuttle is looking good, and that is a great job on the windows.  I think that works well.  It might be interesting after painting the windows to try some of the "window fluid" I've heard about.  Might be difficult to get that stuff to set right however.  Some thin clear plastic like from a book binder might do the trick!  Good work again!
My own work was rather slow today.  I puttied the nose cone and scrapped it smooth a bit.  Now waiting for it to dry to do some sanding, so that will come tomorrow.
Gary
Today in Space History:
1948 March 31 - .
  • XS-1 Flight 79 - . Crew: Yeager. Payload: XS-1 # 1 flight 45. Nation: USA. Related Persons: Yeager. Class: Manned. Type: Manned rocketplane. Spacecraft: XS-1. AF flight 23. Engine shutdown after launch. Propellants jettisoned, completed as glide flight..
1948 March 31 - .
  • XS-1 Flight 78 - . Crew: Lilly. Payload: XS-1 # 2 flight 34. Nation: USA. Related Persons: Lilly. Class: Manned. Type: Manned rocketplane. Spacecraft: XS-1. NACA flight 14. Stability and loads investigation. Plane attained mach 1.1..
1960 March 31 - . 16:42 GMT - . Launch Site: Edwards. Launch Complex: Rosamund Dry Lake DZ. Launch Pad: Edwards RW04/22. Launch Platform: NB-52 008.
  • X-15A SAS Gains test - . Nation: USA. Agency: NASA, USAF. Spacecraft: X-15A. Apogee: 15 km (9 mi). Maximum Speed - 2156 kph. Maximum Altitude - 15653 m. 3.5 to 5G pullouts to simulate reentry. Air dropped in Rosamund Dry Lake DZ..
1966 March 31 - . 10:47 GMT - . Launch Site: Baikonur. Launch Complex: Baikonur LC31. LV Family: R-7. Launch Vehicle: Molniya 8K78M.
  • Luna 10 - . Payload: E-6S s/n 206 ISL. Mass: 1,597 kg (3,520 lb). Nation: Russia. Agency: Korolev bureau. Program: Luna. Class: Moon. Type: Lunar probe. Spacecraft Bus: Luna E-6. Spacecraft: Luna E-6S. USAF Sat Cat: 2126 . COSPAR: 1966-027A.
    Lunar Orbit (Selenocentric). Development of system to permit the creation of an artificial lunar satellite for the investigation of circumlunar space; development of onboard systems for putting a station into a selenocentric (circumlunar) orbit. Orbit: Lunar Orbiter. The Luna 10 spacecraft was launched towards the Moon from an Earth orbiting platform. The spacecraft entered lunar orbit 3 50 x 1017 km, inclination 71.9 deg to plane of the lunar equator. on April 4, 1966. Scientific instruments included a gamma-ray spectrometer for energies between 0.3--3 MeV, a triaxial magnetometer, a meteorite detector, instruments for solar-plasma studies, and devices for measuring infrared emissions from the Moon and radiation conditions of the lunar environment. Gravitational studies were also conducted. The spacecraft played back to Earth the `Internationale' during the Twenty-third Congress of the Communist Party of the Soviet Union. Luna 10 was battery powered and operated for 460 lunar orbits and 219 active data transmissions before radio signals were discontinued on May 30, 1966.
    March 2010
Posted by mach71 on Monday, April 1, 2019 6:20 AM
GAF
PFJN,
Great job! I think Gary is right about the window liquid. I have used this in the past with very good results:
http://www.microscale.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=MI-9
Maybe paint the windows black then add a layer of kristol klear.
    July 2014
Posted by Bakster on Monday, April 1, 2019 8:55 AM
GAF
Oops! My bad. I said Solvaset but I meant Micro Set. I have Solvaset of the brain. No--it was Micro Set that I used and everything I have ever read was that you lay the solution down before putting on the decals.
    March 2010
Posted by mach71 on Monday, April 1, 2019 9:10 AM
Well I stayed up all night long to finish my Mercury capsule!
And I built the cradel too!
I only have the one photo so far:
Not bad huh! It looks almost real!
Devil
(April fools)
GAF
    June 2012
Posted by GAF on Monday, April 1, 2019 9:26 AM
mach71
Devil
(April fools)
Mach71>  I don't know.  Not enough rust in my opinion.  OTOH, that shuttle in the background looks pretty good!  Wink
Gary
Posted by Gamera on Monday, April 1, 2019 11:24 AM
GAF
mach71
Devil
(April fools)
Gary
I would have added a little more pre-shading for depth on the paint.... Big Smile
All joking aside great work all around guys!!!
    March 2010
Posted by mach71 on Monday, April 1, 2019 12:51 PM
Sorry guys, I couldn't resist.
Thats the MA10 capsule that was going to be Alan Shepards orbital mission. It's at the Smithsionian Udvar-Hazey museum at Dulles airport. As far as I can figure out that was the last Mercury built.
The shuttle is OV-101 Enterprise. It's since been replaced with Discovery and Enterprise has moved to The USS Intrepid in New York City.
I did get the 1st coat of semi gloss black onto the capsule. Its looking good!
Then I misted some gunmetal on the heatshield. Both are drying now.
I'll buff out the heatsheild and I think it will look good. I'm looking for the color in
the photo.
    March 2010
Posted by mach71 on Monday, April 1, 2019 2:38 PM
2nd coat is on and dry.
I buffed the heatsheild and re misted it.
Gordo is coming along. It seems the auto bumper primer has worked.
Gordo did not use the "hero" medal mirror on his mission, but I like it so it's saying.
Thats all for today, Things need to dry.
    July 2014
Posted by Bakster on Monday, April 1, 2019 3:53 PM
Looking good, Mach.
Speaking of Gordo Cooper. Have any of you guys watched a show called, Cooper's Treasure? Supposedly, Gordo was an avid treasure hunter. The premise is interesting and the guy that is following up on Gordos life work is finding artifacts and treasure. He may have even found one of Columbus' anchors.
https://www.foxnews.com/science/amazing-discovery-on-the-seabed-space-treasure-map-leads-to-mysterious-shipwreck-site
https://www.discovery.com/tv-shows/coopers-treasure/about
https://www.outsideonline.com/2319386/reality-tv-enters-gray-area-shipwreck-hunting
Posted by Gamera on Monday, April 1, 2019 7:58 PM
Mach71: Really nice work there on Cooper and I love the effect you got on the heat shield.
Bakster: Hmmmm, I haven't watched Discovery in a year or so, somehow that fly under my radar. I'll have to check it out Friday.
    March 2010
Posted by mach71 on Monday, April 1, 2019 8:32 PM
Bakster, thats really cool! I never knew that about Gordo.
Gamera,
I'm very happy with how the heatshield came out!
As I am about the black paint on the capsule.
It's more glossy than I expected, but I don't think shiny enough for decals.
GAF
    June 2012
Posted by GAF on Monday, April 1, 2019 9:18 PM
Mach71> You mean you didn't finish the capsule, and that's not a photo of your model?!
Sir, I am shocked and appalled that you would pull such a stunt!  I'm afraid that there will have to be an internal investigation over such a serious matter!  A serious matter! (Just as soon as I stop laughing).  Wink
But your real model is looking good!  I really like the black paint you choose.  I do know that the gloss / matte coat will be the deciding factor in the final appearance, so that's still a decision to make.
Meanwhile, as it is still April 1st, I didn't know Gordo wore lipstick on his flight!  You learn something new everyday!  Whistling
Bakster>  Well, I don't have too high an opinion of the show, so I'll skip further comment.
My own work has consisted of sanding and polishing the boost protective cover and nose cone.  Getting them prepped for paint this week.  I'm going to have to glue the heat shield to the capsule sometime and putty up the seam, but at the moment it's more convenient to work on the parts separately.  I need to fix the hatch also (that sounds rather ominous).
1866 April 1 - .
  • Captain John Carter, late of the Confederate States Army, arrives on Mars (called by the inhabitants Barsoom).  Taken captive by the green Martians, Carter manages to save Princess Dejah Thoris of Helium while fighting his way to leadership of most of the planet.  NASA finds his method of space travel to be infeasible for use by other astronauts, however.
1956 April 1 - .
  • Army Ballistic Missile Agency requested permission to use its Jupiter C missile to launch a satellite. - . Spacecraft: Man-In-Space-Soonest.
    The Army Ballistic Missile Agency requested that the Department of Defense grant permission to use its Jupiter C missile to launch a satellite, "in view of Vanguard delays and increasing evidence that the Soviets would be first in space--an event certain to inflict 'serious damage' to the prestige of the United States. The Army's proposal was rejected by the Department of Defense, presumably in line with the policy announced by the President on 29 July 1955, that the United States would remain strictly within its International Geophysical Year satellite commitment without using military missiles, thus clearly demonstrating United States intent to explore space for peaceful purposes. (Bowen, Threshold of Space, pp, 10-11.)
1960 April 1 - .
  • Mercury astronauts complete centrifuge training. - . Nation: USA. Program: Mercury. Seven Mercury astronauts completed training session at the Navy Aviation Medical Acceleration Laboratory, Johnsville, Pa..
1960 April 1 - . 11:40 GMT - . Launch Site: Cape Canaveral. Launch Complex: Cape Canaveral LC17A. LV Family: Thor. Launch Vehicle: Thor Able II.
  • Tiros 1 - . Payload: Tiros A (A-1). Mass: 120 kg (260 lb). Nation: USA. Agency: NASA. Program: Tiros. Class: Earth. Type: Weather satellite. Spacecraft: Tiros. USAF Sat Cat: 29 . COSPAR: 1960-Beta-2. Apogee: 696 km (432 mi). Perigee: 656 km (407 mi). Inclination: 48.4000 deg. Period: 98.30 min.
    A Thor/Able II booster placed NASA's Television and Infrared Observation Satellite (TIROS) weather satellite into the most accurate orbit yet achieved by any U.S. satellite. TIROS I opened a new era in meteorology by transmitting nearly 23,000 pictures of global cloud cover from 450 miles in space and providing the first glimpse of global cloud structure data. TIROS I completed 1,302 orbits before its operational life ceased on 29 June 1960. TV and Infrared Observation Satellite; returned 22952 cloud cover photos. Spacecraft engaged in practical applications and uses of space technology such as weather or communication (US Cat C).
1965 April 1 - . LV Family: Saturn I. Launch Vehicle: Saturn IB.
  • First stage of the Saturn IB first static firing at MSFC - . Nation: USA. Program: Apollo.
    The first stage of the Saturn IB booster (the S-IB-1) underwent its first static firing at Huntsville, Alabama. The stage's eight uprated H-1 engines produced about 71,168-kilonewtons (1.6 million lbs) thrust. On April 23, Marshall and Rocketdyne announced that the uprated H-1 had passed qualification testing and was ready for flight.
1980 April 1 - . LV Family: Shuttle. Launch Vehicle: Space Shuttle.
  • Shuttle ejection seat tests - . Nation: USA. Another series of tests of the shuttle ejection seat are held at Holloman AFB in support of the first shuttle orbital flights..
Posted by Gamera on Monday, April 1, 2019 9:29 PM
Lol, I think they left the part about Gordo's lipstick out of 'The Right Stuff'... Stick out tongue
And thanks Gary for remembering John Carter, first voyager to Mars... Big Smile
Read 'A Princess of Mars' a few years ago and it's a humdinger of a novel. Too bad Disney made such a stinking mess of the movie adaption- I still own it on Blu-Ray though.
GAF
    June 2012
Posted by GAF on Monday, April 1, 2019 9:42 PM
Gamera
I'm sure they left a lot of things out of "The Right Stuff", such as John Glenn's wig...
I didn't think the movie "John Carter" was that bad, but Disney sure "screwed the pooch" with the marketing.  Many think it was to late to make an adaptation of the book after all the Star Trek and Star Wars decades. Unfortunately, it had to wait for CGI to advance enough to tell the story. Me, I enjoyed it for what it was, an old-fashioned adventure from the creator of Tarzan.
Gary
Posted by Gamera on Monday, April 1, 2019 10:09 PM
Yeah the marketing was terrible. But it's one of those movies I find to be 50% brillant and 50% WTH were they thinking? I loved the design and CGI for the green Martians, the sets, even the idea of the red Martians having red tattoos. The whole art design really clicked with me, that's how Barsoom should look.
What blew it for me was changing the whole plot. The novel- guy goes to Mars, sees the most beautiful woman he'd even seen captured and goes forth to rescue the princess. The movie is more like a romantic comedy, throw the two leads together and then watch them bicker and fight for over an hour till the figure out they love each other. And the whole thing of turning the white Martians from simple con-artists to this universe destroying threat was just kinda silly to me.
    July 2014
Posted by Bakster on Monday, April 1, 2019 11:03 PM
Gamera
Gary doesn't like it apparently, but I find it entertaining. Nothing like a good treasure hunt to spark the imagination. Try it... maybe you'll like it, said Mikey. Or maybe you won't.
    March 2010
Posted by mach71 on Tuesday, April 2, 2019 7:04 AM
I was going for the cherry chapstick look! Smile
Gordo's lipstick will be toned down, Its just the 1st pass. There is a lot of work left to do on him and figures are not my favorite. I thought clear red would work, obviously not!
As for John Carter of Mars, I liked it. I never read the book, but as a period piece movie it worked. I'm not surprised that Disney took some liberty with the plot, it's what moviemakers do thinking it will be more relevant to modern audiences. I think they are wrong, but they are paying the bills.
GAF
    June 2012
Posted by GAF on Tuesday, April 2, 2019 8:14 AM
mach71
Mach71> Just a April Fools day jib, sir!  Pay it no mind.  I'm sure Gordo will get his make-up in line in time for launch.  Big Smile
Oh, and you need to read the first three books of the John Carter of Mars series as they connect in a continued story.  In fact, they are available online at the University of Virginia Online Library.
https://www.library.virginia.edu/collections
Just type in the name of the novel (A Princess of Mars, The Gods of Mars, The Warlord of Mars) and you will be able to access the text.  Not sure if the rest of the volumes are available, but worth a check.  Smile
Gary
    March 2010
Posted by mach71 on Tuesday, April 2, 2019 9:06 AM
Thanks for the link! I'll check it out.
Deke made Gordo tone down his lips:
Still much work to be done, but the end is finally on the horizon!
I might get this done in time!
    July 2014
Posted by Bakster on Tuesday, April 2, 2019 9:18 AM
mach71
Thank goodness.
Yes
    July 2014
Posted by modelcrazy on Tuesday, April 2, 2019 9:37 AM
I you want, add a little color around the pupil for an iris. Aso typically, excepet for one daytime show host, the upper eye lids cover half the iris.
Of course I stink at figures so I would'nt even attempt to paint one. Take my advise with a large grain of salt.
Steve
    March 2010
Posted by mach71 on Tuesday, April 2, 2019 2:27 PM
modelcrazy
Good call!
Thanks
I finally got some primer on the Escape tower.
I see a few seams to work on.
GAF
    June 2012
Posted by GAF on Tuesday, April 2, 2019 10:15 PM
Mach71>  Hey!  Gordo's looking a lot better now!  Glad to hear work has begun on the tower. And who doesn't have a few seams to work on?  Sad
Progress Report:
After sanding down the nose cone and boost protective cover, I gave the capsule a new coating of white paint.  Three light layers and set it aside to dry.   Unfortunately, the seam between the added plastic and the original nose cone was not quite flush, so I'm going to do a little more sanding and repaint.  Nothing I wasn't expecting.  I don't think I've ever gotten a seam completely smooth on the first try, and this 50 year old model has some bad ones.
Hope I can get this ready for mating to the heat shield tomorrow.
Mission Director (GAF)
1958 April 2 - .
  • Eisenhower proposed the establishment of NASA - . Nation: USA. Related Persons: Eisenhower.
    President Dwight D. Eisenhower, in a message to Congress, proposed the establishment of a National Aeronautics and Space Agency into which the National Advisory Committee for Aeronautics would be absorbed. The new agency would conduct the civilian space program through research in its own facilities or by contract and would also perform military research required by DOD. Projects primarily military in character would remain the responsibility of DOD.
1959 April 2 - .
  • NASA Astronaut Training Group 1 selected. - . Nation: USA. Related Persons: Carpenter, Cooper, Glenn, Grissom, Schirra, Shepard, Slayton.
    The group was selected to provide six pilots for the single-crew Mercury manned spacecraft. Originally a wide pool of candidates was going to be considered, but in December 1958 President Eisenhower ruled that military test pilots would form the candidate pool.. Qualifications: Qualified jet pilot with minimum 1,500 flight-hours/10 years experience, graduate of test pilot school, bachelor's degree or equivalent, under 40 years old, under 180 cm height, excellent physical condition.. Screening of military service records showed 110 military officers that met these criteria. These 110 were to be called in three groups for briefings on the Mercury program. Of the first two groups of 35 called, 56 volunteered for further physical and psychiatric tests. This provided enough candidates and the third group was never even called for a briefing or asked if they would like to volunteer. Of the 56 tested, seven were finally selected (no objective way was found to reduce the seven finalists to six).
    Of the seven astronauts, all eventually flew in space. Grounded due to a heart murmur, Slayton had to wait 16 years for his flight aboard the last Apollo mission. Glenn left for a career in politics after becoming the first American to orbit the earth, but returned to space aboard a shuttle over 36 years later in a NASA publicity stunt. Schirra was the only astronaut to fly aboard Mercury, Gemini, and Apollo spacecraft. Shepard was the only one to reach the lunar surface (after being grounded for a medical condition during the Gemini program). Grissom would die in the Apollo 204 ground fire.
1963 April 2 - . 08:16 GMT - . Launch Site: Baikonur. Launch Complex: Baikonur LC1. LV Family: R-7. Launch Vehicle: Molniya 8K78.
  • Luna 4 - . Payload: E-6 s/n 3. Mass: 1,422 kg (3,134 lb). Nation: Russia. Agency: RVSN. Program: Luna. Class: Moon. Type: Lunar probe. Spacecraft: Luna E-6. Decay Date: 1963-04-03 . USAF Sat Cat: 563 . COSPAR: 1963-008A. Apogee: 182 km (113 mi). Perigee: 167 km (103 mi). Inclination: 64.70 deg. Period: 87.98 min.
    Luna 4 was the second attempted Soviet unmanned lunar soft lander probe. The spacecraft, rather than being sent on a straight trajectory toward the Moon, was placed first in an earth parking orbit. The rocket stage then reignited and put the spaccecraft on a translunar trajectory. Failure of Luna 4 to make a required midcourse correction resulted in it missing the Moon by 8336.2 km on April 6, at 4:26 a.m. Moscow time. It thereafter entered a barycentric Earth orbit. The Soviet news agency, Tass, reported that data had been received from the spacecraft throughout its flight and that radio communication would continue for a few more days.
1969 April 2 - . 10:33 GMT - . Launch Site: Baikonur. Launch Complex: Baikonur LC81/24. LV Family: Proton. Launch Vehicle: Proton-K/D. FAILURE: First stage - 1 x RD-253 fire beginning at T+ 0.02 sec, rocket crashed near pad.. Failed Stage: 1.
  • M-69 s/n 522 - . Payload: M-69 s/n 522. Nation: Russia. Agency: RVSN. Program: Mars. Class: Mars. Type: Mars probe. Spacecraft Bus: 4MV. Spacecraft: Mars M-69. Decay Date: 1969-04-02 .
    Mars probe intended to enter Martian orbit and comprehensively photograph Mars, together with a landing probe. Further Mars launches during the 1969 launch window were cancelled when this attempt resulted in a major accident, which almost wiped out all of the leaders of the space industry. The Proton rocket lifted off, but one engine failed. The vehicle flew at an altitude of 50 m horizontally, finally exploding only a short distance from the launch pad, spraying the whole complex with poisonous propellants that were quickly spread by the wind. Everyone took off in their autos to escape, but which direction to go? Finally it was decided that the launch point was the safest, but this proved to be even more dangerous - the second stage was still intact and liable to explode. The contamination was so bad that there was no way to clean up - the only possibility was just to wait for rain to wash it away. This didn't happen until the Mars launch window was closed, so the first such probe was not put into space until 1971. This accident also severely damaged plans to divert attention from America's Apollo programme during the rest of 1969. 10-12 UR-500K launches had been intended to land on the moon lunar soil return and rover robots to supplement the N1 launches.
