Japanese Group Build VIII
    October 2008
Posted by bsyamato on Friday, July 5, 2019 12:25 PM
Not programmed another jap is slipped on the table
Add it Cliff :)
Posted by waikong on Friday, July 5, 2019 4:44 PM
Love that orange claude, enough of that IJAF green! :)
Ok, it's time for a ground target as I finally finsihed my 1/48 Tamiya jgsdf Type 10 heavy tank. Additional pictures with a short description of the build is here https://waihobbies.wkhc.net/index.php/14-models/ground/144-jgsdf-type-10-main-battle-tank
Thanks everyone for this great GB, I really needed some incentive to finish a build.
type 10
My website: http://waihobbies.wkhc.net
Posted by Gamera on Saturday, July 6, 2019 7:33 AM
Waikong: Nice!!! Great job there! Going to put you on the front page now. Good to see someone else use the Silly Putty approach to masking. And despite your comments I think the C.O. came out pretty darn well!!!
Bsyamato: No problem, adding her now.
Posted by waikong on Saturday, July 6, 2019 3:53 PM
Thanks Gamera, have to get myself the badge now
    January 2019
Posted by Edwin on Saturday, July 6, 2019 9:18 PM
Waikong, nicely done! First tank of this group build.
What camera are you using? Nice photos.
Posted by waikong on Monday, July 8, 2019 4:38 PM
Thanks Edwin, I use a Panasonic Lumix FZ200 with the smallest aperture and aperture priority mode, iso100. I think if anything, putting it into s soft light box helps a lot. I do set the white background as neutral on the computer to help correct the color, otherwise nothing else special.
    March 2017
Posted by Armor_Aficionado on Tuesday, July 9, 2019 4:55 AM
More progress on the cockpit details:
Posted by Gamera on Wednesday, July 10, 2019 7:38 AM
AA: Looks good! Almost ready to mount in the fusilage.
Posted by Gamera on Wednesday, July 17, 2019 10:56 AM
Looks good Bsyamato! Your usual nice work!
Btw: Steve/Modelcrazy is running a Japanese ships build in the future. You might hold on one or two ships for that.
Posted by waikong on Thursday, July 18, 2019 9:56 AM
Nice start on the Ki-44, but I can't seem to click on the pics to see a larger version.  Looks like the hosting site needs a login even to see the pics.
Posted by Gamera on Friday, July 19, 2019 8:07 AM
waikong
Hmm, had the same issue here.
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 6:27 PM
Whale, shooooot! It's been since 29 April since my last update!! Sorry, guys!
Not much done since the last update, but I do have the cockpit assembly mounted in the fuselage. This is actually coming out much better than I had anticipated, which is good! I'm doing more work on her tonight (Wednesday 24 July), so I'm hoping to have another update posted sometime later tonight. Let me know whatcha think......
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 6:30 PM
And in case you were wondering, the top of the control stick really is supposed to be green. All the pictures that I can find show this. I figured it would be black, or maybe wooden. But, nope, Tamiya had the correct color listed for it.
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:17 PM
Ok, got some more done on her tonight:
As you can see on the instruction sheet, parts D30 & D31 were supposed to be glued to the firewall first, then part D25 glued to that. After test/dry-fitting this several times, I finally determined that there was no way my shaky hands were gonna accomplish that. So, I glued D25, D30, & D31 together first. Way much better! After the glued set for a bit, I test-fitted the assembly to the firewall, and it fits very, very well, with no parts trying to fall apart while trying to assemble them. But, the assembly still needs paint, so it's gonna be like this until I can spray some semi-gloss black on it. Then it gets mounted.
The two horizontal stabilizers. Tamiya designed them so that the elevators connect to each other and move together. This is done with some small photo-etched hinges (zoom in on one of the pictures to see them). Normally, I shy away from photo-etch, as I can't see them that well, even with my Magnivisor, plus I shake a little bit, and that causes me to smear the glue when I apply the photo-etch. But, Tamiya made this really easy to do, as the stabilizer halves have small grooves/recesses for the photo-etch to sit in, plus they help with alignment, so plusses all around on this design. One aspect I'm puzzled about is the deflection of the elevators after everything is assembled. Very little max deflection at all in either direction - maybe only about 5 degrees or so. Not gonna worry about it, as when they're neutral, they're correct! So, no biggie. I will need to look at some photos to see if the max deflection angles are correct, just to satisfy my curiosity about it.
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:23 PM
bsyamato
Sorry for delay , the little Jpa cayuse is near finish and forget to take intermediate pictures:
After grey humbrol primer , painted the yellow and orange , then masked and green on
And decals after glossy coat and colored upper windows
Unfortunately i destroyed one of rotor basement serial number decal (obliviously white color..) so i need to leave it withouth till i found a good replacement.
No updates on the other two subjects but i started also the same nanzan kit that Zvezda 1980  and no reason to double here :)
Great job, BSYamato! Lookin' good!
Gary Mason
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:27 PM
bsyamato
Still alive and here some updates:
Claude on first final orange layer (humbrol orange 132+ yellow 188)
Also the cayuse is almost done, few retouches needed and a new missing decals from a new kit (that i need to buy Sad )
That Claude is awesome, BSYamato! For some reason, the color of the Claude makes me think of a Subaru Crosstrek! ANd, yep, I drive a Subaru Forester, and my wife has a Crosstrek. Looking forward to seeing these two progress.
Gary Mason
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:29 PM
Armor_Aficionado
Finally getting under way on the A6M5 Zero; initial cockpit construction:
Man, that is looking good, Armor! That Tamiya kit is just about as close as you can get to throwing in some paint & glue, closing the box, shaking it up, and out comes a completed model. I love this kit!!
Gary Mason
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:30 PM
Wooooo-Weeeeee, Edwin! That's nice! I might hafta copy you and stick a motor in the Zero that I'm building, too! Impressive!
Gary Mason
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:32 PM
falconmod
Got started  on the cockpit, prop and engine.
John
Nice!!
Gary Mason
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:33 PM
waikong
type 10
Great job, Waikong!
Gary Mason
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:34 PM
Armor_Aficionado
Did you make the seat cushion yourself, Armor? Great job!
Devil Dawg
    March 2005
Posted by Devil Dawg on Wednesday, July 24, 2019 9:36 PM
bsyamato
Immediatly broken original wells, too few dept, opened guns bullet holes and thinned cowling
Removed cockpit pins and thinned walls to put a new scratched cockpit. Also drilled engine exhausts
Last night started with new innes structures, also opened one of little doors in spitfire style
PS. also i started another japanese kit but it's a not usual material for me Embarrassed
Hasegawa Shoho. If i'll able to do something decent i'll add
Impressive so far, BSYamato!
Devil Dawg
Posted by waikong on Wednesday, July 24, 2019 10:43 PM
Thanks for your comments Gary. Your zero cockpit is looking nice. Those 1/32 Tamiya kits are great, but a bit spendy for me, :-)
Posted by Gamera on Thursday, July 25, 2019 10:46 AM
Gary: Good to see you again! The Zero looks fantastic! It's a great kit, wish I had just built mine right outta the box and she's be done if I hadn't taken the time to try to add a bunch of extra details. The kit looks great as is, as your model proves!
    July 2014
Posted by modelcrazy on Thursday, July 25, 2019 11:53 AM
Nice Zeek Gary! Love Zero's but I don't have that one Huh?
Steve
    March 2017
Posted by Armor_Aficionado on Saturday, July 27, 2019 8:35 AM
More progress on the Zero: adding details to the cockpit bulkhead walls, and built and mounted the engine.  I'll be ready to put the fuselage halves together and complete the cockpit as soon as I have the pilot figure painted and installed.
    March 2005
Posted by Devil Dawg on Saturday, July 27, 2019 4:54 PM
Gamera
Thanks, Gamera!
Devil Dawg
    March 2005
Posted by Devil Dawg on Saturday, July 27, 2019 4:55 PM
modelcrazy
Thanks, modelcrazy!
Devil Dawg
    March 2005
Posted by Devil Dawg on Saturday, July 27, 2019 4:56 PM
Armor_Aficionado
Nice work, Armor!
Devil Dawg
