Ships of the American Flag GB 2019 -2021
Posted by Gamera on Monday, September 2, 2019 10:41 AM
Again those are awesome guys!
Mongoose: Welcome and wow that looks sharp!
    July 2014
Posted by Bakster on Monday, September 2, 2019 4:29 PM
GMorrison
It's hard to know where that 16" rifle is in it's recoil sequence, but probably still had a bit more to travel. Rough estimate from the diameter of the barrel at the muzzle (say 24"), that recoil looks to be a bit less.
That suggests about 1/32" in the scale, which seems pretty minimal to me. The best tell seems to be that black sleeve around the base of the barrel.
Thanks for crunching the numbers, Bill. I wondered about this as well, searching out another image where the turret looks further back than what I posted. My final position for the turret might be extreme, but maybe not. Either way, it's good enough for my taste.
I mounted the turrets by tacking them from the backside using CA. While the glue was setting, I made final adjustments. Once dried, I added sprue-goo for good measure.
The vinyl tape are for locators. This should help get consistent dimensions while modeling the blast bags, as well as to help create demarcation lines.
At first, I was leaning towards using sprue-goo to repair the blast bags, now I am thinking not. Spacing between the turrets is tight and odds are I will make a mess of things. Instead, I will use apoxie-sculpt. This should allow me plenty of time to model the pieces, and this stuff is pretty forgiving to make corrections, or at least up until it cures. That's what is next.
    January 2015
Posted by TheMongoose on Monday, September 2, 2019 4:47 PM
Bakster I hear what you’re saying about being extreme on the recoil. Thinking about the scale and what you’re trying to show I think it may be best as it will be obvious it is in recoil and more people will note the difference without having to point it out to them. You sure are doing a bang up job on them!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    July 2014
Posted by Bakster on Monday, September 2, 2019 5:29 PM
TheMongoose
Thanks Mongoose. I didn't make it too clear, but I did find another image that showed the turret further back than what my first recoil image does, so GM was onto something. Where I mounted the turret is probably at the extreme end of that spectrum, but you hit the nail on the head on why I did it that way.
I tell ya--I always spot my errors when I post images. The spacing from the back wall of the blast bags to the vinyl tape is too long. I forgot to factor the thickness of the pieces already mounted. I need to move the tape closer by about 1/32. Unfortunately, I think that the turrets will be sticking out too far by about 1mm. My calculation error played into how deep I located the turrets. I guess it's nothing to cry over. Crying  LOL
    August 2014
Posted by goldhammer on Monday, September 2, 2019 6:18 PM
I think your barrel setback is just about right.
As long as all the other barrels are the same length, I really doubt any rivet counter will notice unless they have put a tape on both the1:1 and a micrometer on the finished product.
The way you're going she will be a show stopper.
    August 2014
Posted by goldhammer on Monday, September 2, 2019 6:21 PM
Had a great brunch with the Admiral and SecNav this morning.  Was great to meet him in person and a real treat.
Too bad I know that none of his talent stayed behind or rubbed off.Smile
    July 2014
Posted by Bakster on Monday, September 2, 2019 6:32 PM
goldhammer
Hey thanks, GH. I just rechecked things and to my amazement it checks correct. I saved the kit turret and I matched them side by side, everything I did matches spot on, and even the tape is correct. Wow, I guess it’s one of those days where I overthank things. Onward ho as they say.
Thanks for the vote of confidence too.
    July 2014
Posted by Bakster on Monday, September 2, 2019 6:37 PM
goldhammer
That is really cool GH. I wish we’d all organize a meet somewhere, like a class reunion. It would be so cool to meet everybody.
    July 2014
Posted by modelcrazy on Monday, September 2, 2019 10:59 PM
Thanks GH, It was great to meet both of you as well, and thank you so much for the kit. Since my old "The Sulivans" was damaged in battle and scuttled. It was great to get a new one on the ways, to rebuild as the USS Johnston. I'll get that and the Point Class Cutter on the list.
Steve
    August 2014
Posted by goldhammer on Monday, September 2, 2019 11:48 PM
Glad it went to a good home.  You'll do a great job on her, way, way better than my efforts.
    July 2014
Posted by Bakster on Wednesday, September 4, 2019 9:04 PM
I tried Apoxie Sculpt and I had issues. The stuff didn't stick to the frame well whilst I tried to fashion a shape. I quickly abandoned that idea. This stuff is over two years old I and think it's drying out. When I first bought the stuff, it was sticky as all get-go, now, not so much.
My first instinct worked best; I went with the sprue-goo. Like I feared I made some mistakes, but they were easily cleaned up. In the end the stuff worked pretty well. Heck, this stuff shrinks some and in doing so it created some interesting wrinkles and such that adds to the effect. Is it accurate and perfect, heck no, but for my purposes it is close enough.
Below: I used a sharp blade to score around the edge of the tape to unwrap them.
Below, as it looks. If I'd want to, I could sand to shape them further, but I'll probably leave it as is.
Next up are the smaller guns.
    September 2012
Posted by GMorrison on Wednesday, September 4, 2019 9:33 PM
I think that recoiled rifle looks just right. I'm not sure what you mean when you say turret, but I understand what you are making.
Sorry I didn't check in earlier, but a good way to make those weather seals on the barrels is white glue. It is easy to work with a toothpick, easy to fix/ remove, and paints ok.
    July 2014
Posted by Bakster on Wednesday, September 4, 2019 10:23 PM
Oh yeah--white glue should work for sure. I didn't consider using that.
GMorrison
I am using the term wrong then. I see that turret is the housing or mount for the guns. My bad, I am out of my element here. Thanks for the correction and I hope you guys keep enlightening me. I don't know all the proper terminology.
    July 2013
Posted by steve5 on Thursday, September 5, 2019 12:32 AM
your doing a great job steve , learning new stuff is the mantra of this forum !!
Posted by Gamera on Thursday, September 5, 2019 7:44 AM
Bakster: They look pretty friggin' good to me!!!
    July 2014
Posted by Bakster on Thursday, September 5, 2019 9:23 AM
steve5
Right you are, Steve. And thanks.
    July 2014
Thanks Gam.
    July 2014
Posted by modelcrazy on Thursday, September 5, 2019 9:31 AM
Gamera
Ditto
Yeah, terminology Huh?.
Yes, the guns are in the turret which sit on roller bearings in a Barbette. The US, Gremans and some British ships covered the barrel gun ports with Blast Bags, Bloomers, Gun Buckers or Weather Seals to prevent the over preassure of the gun blast from injuring the gun crew, they also prevented sea spray and rain from entering the gun ports.
The US numbered their main turrets (1,2,3 and so on fore to aft). The Germans and the British alphabetize them (British A,B fore, Q,R mid and X,Y aft. Z not used. Germans, Anton, Bruno, Cessar, Dora, fore to aft.)
BTW, when you get to it and if your up to it.....rigging.
There are stays, lanyards and LF antennas. Don't worry, it's not difficult once you know what your looking at.
Steve
    September 2012
Posted by GMorrison on Thursday, September 5, 2019 9:38 AM
Oh no worries. The guns and the house together are generally thought of as the turret, if the house is armored. You might be interested to know that with the three guns mounted, an Iowa turret weighed 48,000 tons, the weight alone kept them seated. When the Bismark sank, her turrets fell out.
    July 2014
Posted by Bakster on Thursday, September 5, 2019 9:46 AM
GMorrison
Interesting. So on the Bismark do you think they fell out because the ship flipped on its way down?
    July 2014
Posted by Bakster on Thursday, September 5, 2019 10:00 AM
This is awesome, Steve. I love how these things can turn into learning moments, not just for me, but for other people too. I love that diagram showing the various rooms and such. THANK YOU.
modelcrazy
BTW, when you get to it and if your up to it.....rigging. There are stays, lanyards and LF antennas. Don't worry, it's not difficult once you know what your looking at.
Buddy--you are a mind reader. This is something I planned to ping you guys on because--YES--I want to add rigging. My problem is is that I don't have a clue about it and thus far, I have not found any good visuals that I can try to match against, so--keep that on your burner plate. I have a long way to go before I get there but if possible--I'd like to do it. That would really complete the build.
You guys are great...
    September 2012
Posted by GMorrison on Thursday, September 5, 2019 10:26 AM
Bakster
GMorrison
Yes, and it also broke in half. She sank in 17,000 feet of water..
    July 2014
Posted by modelcrazy on Thursday, September 5, 2019 10:44 AM
Bakster
Correct. In fact, most large warships capsize on the way down due to their center of gravity and top weight, plus the fact that the hull has some boyancy as the ship decends prior to the bulkheads bulkling, loosing their watertight seal and breaking up the ship.
The Bismarck is still pretty much in tact because the Germans, it is believed, opened ths sea cocks to skuttle her. She would have sunk anyway but the Gremans didn't want the British to do it there for no buckling bulkheads due to water pressure and no major destruction to the hull. She did capsize while sinking, loose her turrets and damagde superstructure on the way down, re-righted, hit the downslope of a mountain and slid down to the bottom, again minimizing the damage, relatively.
Steve
    July 2014
Posted by Bakster on Thursday, September 5, 2019 11:46 AM
modelcrazy
Bakster
Interesting stuff for sure. Was it the Bismark that before sinking had it's rudder damaged that caused it go in circles?  Kind of like a sitting duck?
    September 2012
Posted by GMorrison on Thursday, September 5, 2019 11:59 AM
Yes there’s a good book written by the senior surviving officer. I think he was the captain of C turret.
They bought themselves a day after the port rudder was damaged when the Prince Eugen turned east and the Bismark went west.
During that time the crew engaged in a number of options and considered others, such as blowing off the rudder, adding a dummy third stack, getting a tow from a U boat or floating off the ships papers in a plane.
    July 2014
Posted by modelcrazy on Thursday, September 5, 2019 12:45 PM
GMorrison
The "Battleship Bismarck" excelent book.
Steve
    August 2014
Posted by goldhammer on Thursday, September 5, 2019 2:03 PM
GMorrison
GM-  Little overweight on a complete turret.  Think you got an extra "0" in there.Embarrassed
    September 2012
Posted by GMorrison on Thursday, September 5, 2019 2:21 PM
Yes, I think you are right that the number is wrong. That's the displacement of the whole ship, didn't read carefully.
Each of the three triple turrets, with guns, weighs 2,100 tons.
    July 2014
Posted by Bakster on Thursday, September 5, 2019 4:30 PM
So interesting. Love this stuff.
    December 2018
Posted by Ted4321 on Thursday, September 5, 2019 5:38 PM
Bakster
Me too.
For comparison, the Union Pacific Big Boy weighs 1,250,000lbs.
Amazing machine you're building.
T e d
