Ships of the American Flag GB 2019 -2021
    December 2003
Posted by scottrc on Wednesday, April 22, 2020 1:15 PM
modelcrazy
Wow Scott, nice progress there. I had to look close at both pictures to notice a difference.
Steve, thanks,
Hard to tell if these old battlewagons are coming or going.  I had to, on a couple of times, double check which direction I had the bow pointed in fear of placing something on backwards.
Gam, thanks man.
Chris, the Enterprise is looking fantastic.
Ben, you look like you are having a lot of fun with those boat kits. They look great.
    June 2014
Posted by BrandonK on Wednesday, April 22, 2020 2:42 PM
Small update. I have most of the paint work completed. I have had to handpaint some of the smaller bits, but at 18-24 inches away you can't tell. Everything you see in the pic is painted, no decals. I have yet to apply any of those. The deck was a pain to mask and paint, but it looks the part now.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    January 2015
Posted by TheMongoose on Wednesday, April 22, 2020 4:27 PM
WoW love the painted deck. The lines look really crisp. BK it's definitely worth the time to do isn't it!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    January 2015
Posted by TheMongoose on Wednesday, April 22, 2020 4:35 PM
Can you guys give me some help with these shafts? I'm trying to get rid of the flassh without making them square...I stopped because even trying to use the flexifile isn't doing it. Holding it in my hand I can't seem to get enough curve to the sandpaper to do anything but put a flat spot on it. Any good lessons learned for this one?
Chris
    August 2014
Posted by goldhammer on Wednesday, April 22, 2020 5:33 PM
I generally will scrape the heavy mold seam with a #11 blade, then a few swipes with a sanding stick, around a 240 grit or medium then a fine.
    January 2015
Posted by TheMongoose on Wednesday, April 22, 2020 6:28 PM
Well I have to say I've really had trouble getting a picture that shows what this technique really looks like. The iPhone just isn't doing it, even using the app I have to adjust white balance and shutter speed it doesn't pick up the shades of gray well. That said, here is how it has turned out. In person it looks terrific. Not overdone, just shadowed so when you look at it you want to look closer to see what's drawing your eye to it.
Here's the preshading in base color +20% white.
This is probably the best two to show finished look
Then some others.
I think this set is cool. While trying to show highlights of shading I used the 'negative' edit option. This really shows the shading that is done well I think.
And finally this one looks pretty good when you blow it up. In the middle I toned down the preshading because on the real ship the corrosion and staining on the weld lines did not look as pronounced.
As the build continues I'll try to get some better shots. I have all the weathering to do yet so there's another set coming.
    August 2014
Posted by goldhammer on Wednesday, April 22, 2020 7:31 PM
Light and angle make a huge difference.  Looks great.  Interesting technique you figured out.  Really impressed.
Posted by Gamera on Wednesday, April 22, 2020 8:39 PM
Brandon: Ohhhh, that looks really good!!!
Mongoose: It looks great to me! And kudos, that much masking and I would have screwed something up somewhere. As to the props can you hold a piece of sandpaper between your fingers to get the right curve to it as you sand?
    June 2014
Posted by BrandonK on Wednesday, April 22, 2020 9:30 PM
TheMongoose
I would tackle that with an exacto blade in a scraping motion and follow it up as needed with some sand paper folder over and used like a file. An much patience.
And your shading looks amazing. I know the camera only pics up parts of it, so with the naked eye it would be even better.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2018
Posted by DRUMS01 on Wednesday, April 22, 2020 11:29 PM
MONGOOSE: I know that everyone has thier own ideas with regards to ensuring a round shaft stays round when removing seams. When looking at your photo I would think of cutting the round shaft where it meets the flaired part that blends into the hull. From there I would drill a hole in the flaired part not too deep, perhaps 1mm and then use either brass or alimunim rod for the actual shaft. As long as you match up the diameter of the brass to the plastic it should work perfect and stay in true round, fit through any shaft guides, and into the back of the prop. I know Hobby Lobby has them as do many on-line stores. Heck, even many hardware stores, Lowes, or Home Depot may carry them (?).
If you are set on using the kits plastic shafts, all of the above are good ideas.
PS: Thanks Scott, Steve, and others for viewing my updates and providing the constructive remarks.
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    September 2012
Posted by GMorrison on Wednesday, April 22, 2020 11:47 PM
A phenom of photos of ships that have a lot of overhang They usually are taken on sunny or open sky days, and the light reflected from the surface of the sea really affects the color.
You've done unusually nice coloring. Maybe feather out that white on the undersides of the sponsors a little.
    January 2015
Posted by TheMongoose on Thursday, April 23, 2020 7:35 AM
Some good ideas there for the shafts. They are really tough to hold without flexing. Surprised given they are almost 2.5mm dia. In this case i got to hit the easy button Yeah on 1 suggestion. Bought a bag of misc brass last year and it had thin wall tubing that fit perfect!
Got to use that lesson on cutting brass with a razor blade as well. Drilled a few holes and the project is off running again.
GMorrison I see what you mean. I'll give that a go When I do the weathering.
Posted by Gamera on Thursday, April 23, 2020 7:38 AM
Mongoose: The tubing looks good to me. Lots easier than trying to sand a plastic part down nice and round.
    July 2014
Posted by modelcrazy on Thursday, April 23, 2020 10:17 AM
Great idea Ben and it looks like Chris put it to good use.
The Enterprise color looks really good, the negitave filter threw me off a little at first. I agree with GM though.
BK, that looks superb. Hand painting, or sprayng always looks better than decals.
Steve
    June 2018
Posted by DRUMS01 on Thursday, April 23, 2020 11:00 PM
Chris: I'm glad the brass rod worked for you, and you had some available.
BK: I really like the decals (just kidding) the paint work on your carrier.
Nothing worth posting from me just yet as I'm still working on the little boats for the Arizona. Tomorrow, should all go well, I am going to fling some primer and pre-shading on the Arizona.
QUESTION: Has anyone here used Scaledecks wood decking on a model? It does not have an adheasive back instead it is a felt type. What is the very best adheasive to use?
I do not want wrinkles, warping, or edging to be an issue with this deck, so your input will be really helpful. They recommended epoxy, white glue, or plastic cement, but I heard the plastic cement did not work and epoxy it usually messy and difficult to work with. Does anyone know if Gorilla multi purpose adheasive would work? How about any spray adheasives?
HELP.....
Ben
LAST COMPLETED:
NEXT PROJECT:
    January 2015
Posted by TheMongoose on Friday, April 24, 2020 6:54 AM
DRUMS01
HELP.....
Ben
I cannot speak to the deck specifically but I've used several spray glues - 3M and Elmers. My experience there would say they are messier than epoxy. They stink to high heaven so outdoors is the best way to spray them. The spray is hard to control.  in my opinion sprayglues are for broad, general, and not detail oriented work. Seems no matter what I've covered the glue got on it anyway. Just thinking out loud here, To use it i think you'd have to tape up the whole finished side of the deck and not uncover it until after the deck was applied.
    July 2014
Posted by modelcrazy on Friday, April 24, 2020 7:43 AM
I would think Elemer's (polyvinyl acetate PVA) would work if thinned I would think.
yellow wood glue is like white glue but made for adhering to wood better.
Gorilla glue (polyurethane glue) would work as well but harder to apply thin. It's activated with water so maybe thin it and work quickly.
Gorilla can't be removed where the PVA can, but you might run the risk of it removing itself.
Epoxy's seem like they would be difficult to work with.
I would stay away from CA's and plastic glues for this application. Spray glues, as mentioned by Mongoose, is difficult to apply cleanly.
I've never worked with the deck product and sounds like I would like it. It will be easier to get straight than the typical pre-adhesive decks as the glue time will allow you to move the deck to the perfect location. The downside would be adding weights or clamps for adhesion.
Personally, I would go with the yellow PVA wood glue, thinned with water. But someone else such as GM may have a better recommendation.
Steve
    June 2018
Posted by DRUMS01 on Friday, April 24, 2020 7:43 PM
Personally, I would go with the yellow PVA wood glue, thinned with water. But someone else such as GM may have a better recommendation. Steve
That was my conclusion as well, unless I heard something different. Thanks for the input everyone....
Sneak peek on the little boats (work in progress). Large boat still has PE handrail and life ring. I am debating on adding ships wheels to the two larger boats (not completely sure just yet). Still have to trim out and paint the black water line. I do like the wood inserts though (the middle boat wood has already been weathered). The little ones are the length of a dime.
Ben
LAST COMPLETED:
NEXT PROJECT:
    July 2014
Posted by modelcrazy on Saturday, April 25, 2020 12:39 AM
Those wee boats are so cute, I just want to squeez their cheeks
Steve
    January 2015
Posted by TheMongoose on Saturday, April 25, 2020 10:43 AM
    July 2014
Posted by modelcrazy on Sunday, April 26, 2020 1:49 AM
That's outstanding Chris
Steve
    January 2015
Posted by TheMongoose on Monday, April 27, 2020 8:04 PM
Thanks Steve!
looks like we all must have gotten outside this weekend and steered clear of the bench lol
Here is today's project. This is the bulkhead, starboard side, amidship, on the hangar deck. The fire doors close into the pocket just left of center.
This should add something to catch people's eye when they look into the bay.
    August 2014
Posted by goldhammer on Monday, April 27, 2020 8:29 PM
As to wiring, if you are doing a pedestal base mount you can run the wiring up through a hollow pedestal.
    August 2009
Posted by JOE RIX on Monday, April 27, 2020 11:17 PM
Everyone has been doing some amazing stuff lately. I'll try to catch up later as there is quite a bit that has been going on.
For now though, I have had the wind taken out of my sails on my build. The other day I was filling and sanding on the forward superstructure when I happend to take a close look at it from a forward view. That is when I noticed that the upper deck was completely tilted to one side. How I missed this earlier is totally beyond me. Yup, a full on "You've got to be kidding me!!!" moment. It appears to be a kit fit issue and not a product of my efforts.
This is not something that I could fix as it all welded together. I was completely bummed as I cannot accept this and just keep going. That would simply bug me forever. So, I gave myself a moment to gather myself and then proceeded to ebay to see if I might luck out and find another kit. Fortunately, there was one and I am currently the winning bidder. It will finish that way tomorrow morning by gum. I'm kind of alright with this as it gives me the opportunity to address a couple of other issues that have come along while assembling this kit. One of them being the uneven drilling of the bridge windows you see in the pics.
I am determined to finish this to a better expectation than what I was getting so far. In the meantime while waiting for the new kit to arrive, I'll not only work on what I can but, I've also got a 1/700 USS Laffey DD and 1/700 USS Baltimore I might start on. These are much better molded and engineered kits that might result in less stress and more enjoyment.
Thanks for hangin' with me. I will overcome!
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    September 2012
Posted by GMorrison on Tuesday, April 28, 2020 12:32 AM
I was going to suggest filing the railing/ shields level; but the whole thing including the verticals is pretty ascew.
I'd bust it up and start over. Nothing to loose.
Posted by Gamera on Tuesday, April 28, 2020 7:28 AM
Ben & Mongoose: Ohhhhhhh, those are so cool guys!!!
Joe: Can you get a razor saw in there and carefully cut the parts apart?
    December 2003
Posted by scottrc on Tuesday, April 28, 2020 8:09 AM
Joe,
I had this happen to me on the 1/700 Trumpeter HMS Warspite.  I did manage to break everything apart by scribing the weld seams with a sharp exacto blade and rebuilt it.
I also had this happen to me on the first Japanese battleship I built many years ago.  It had a lopsided pagoda because it started to settle as teh glue dried and I never noticed it until I was done.  I havn't built a Japanese battleship since.
When building ship superstructures, the old saying measure twice, cut once goes in hand with measure and test fit twice, glue once.
Scott
    January 2015
Posted by TheMongoose on Tuesday, April 28, 2020 8:27 AM
Joe for a little humor you could make up one of Modelcrazy's rough seas dios and roll her to starboard 30 degrees. Bet no one would notice that lean then!
    July 2014
Posted by modelcrazy on Tuesday, April 28, 2020 9:11 AM
Joe I hope you get it. I see it on eBay (I won't bid on it).
scottrc
Absolutly, once it goes askew it compounds as you go up. Now I always look at all sides for levelness, tack glue it, look again, glue both sides, look again, then glue the rest. I can't imagine trying to get the pagota mast of the Fuso level.
Chris, looks good. Now after you and Ben I'll have to be more conscientious of what's seen behind doors and windows.
Steve
    July 2014
Posted by modelcrazy on Tuesday, April 28, 2020 9:37 AM
As for me, I've been plugging away at all the small PE parts. I completed the 15 quad 40 Bofors mounts, finished the cranes (no pics yet), one more catapult to do, working on the superstructure mast, Mk37 gun directors x 4, Sk2 Radar dish and Mk8 gun director radars x 2 (done). It's taking me forever Tongue Tied
I ordered some 5"/38 twin gun mounts from Alance Modelworks because I wasn't happy with the ones I made up. The perascopes just didn't look good to me so I when ahead and bit the bullet.
Steve
