Ships of the American Flag GB 2019 -2021
    January 2015
Posted by TheMongoose on Saturday, August 22, 2020 3:08 PM
Well between advice from  plasticjunkie, MC, and Tomcat I've managed to finish a flag in 3 attempts :-) a very good measure for me. For whatever reason the aluminum foil i used needed white glue or future to keep the decal in place. Both worked well. Here it is displayed with a bit of a furl to it. Glued on square to the line as well. This time i took some accelerator on a micro cue tip and applied it to the wire first. Then some glue on the flag before mating the two up.
In the pattern: King George V (on-hold for paint), the Tamiya 1/350th version & Academy's 1/35 AH-1Z Viper !
    June 2018
Posted by DRUMS01 on Sunday, August 23, 2020 12:17 AM
Mongoose: nice flag!
Steve, I did not want to say that at the start, but you mentioning the over application of weathering was what I was after. I wanted to see if anyone else thought they were a little too much as I was on the fence thinking so as well. Perhaps some soft dry brushing of the red and gray on the main guns will tone it down just a little.
Thanks for the remarks as my eyes are not what they use to be.
Ben
I am a Veteran; to all other Veterans thank you for your service. Retired now and living well
PROJECTS:
- 1/350 USS Alabama (GB) - DONE
- 1/16 1910 Thomas Flyer (WIP)
- 1/78 AC-119 Stinger Gunship (GB-Pending)
    July 2014
Posted by modelcrazy on Sunday, August 23, 2020 11:11 AM
Ben, I'm glad I didn't offend as I thought I might when I hit send. Some drybrushing should do fine. I have found over the many kits of practice that even if I believe I went too far with weathering, it can always be fixed with layering, drybrushing and such.
Chris, Great! I'm glad you got it to work. When I use the decal I will use white glue to attach it to some foil as well. I will work with it to get it to wave the way I want depending on what I envision the wind to be. Sometimes it's just hardly moving.
    January 2015
Posted by TheMongoose on Sunday, August 23, 2020 9:52 PM
The USS Enterprise CVN-65 is complete! I finished up the base today. Borrowed my son's wide angle lens for the cell phone so I could get some better pictures without being 10' away hahha. Wishing i had a better camera after seeing how hard it is to get good focus with all these grey tones And dark lighting for night shots Tho. I started April 1st and estimate about 400 hours or so invested to get here. New for the final reveal, You'll see the sailors on deck for the commemoration of nuclear power and the base. The base is made up to look like it has rubber blocks on the wood frame. I scored and carved it to try and make it look like it had been used well. The edges and scores got gloss and satin varnish to replicate the shiny surface you get when rubber is cut open. Buried in the sailors is one with red hair, I've gone to adding a redhead to every build i do with figures as my signature :-)
Ive got alot of pics And It's a big ship so here's my top 10 and you guys can ask for more in detail if you'd like.
MC let's use this 1st one for the front page.
I added some mirrors inside so you could see the 'blind" walls i built.
    January 2015
Posted by TheMongoose on Sunday, August 23, 2020 10:09 PM
Ha, jokes on me I couldn't do it in 1. Gotta post the night shots!
    July 2014
Posted by modelcrazy on Monday, August 24, 2020 8:00 AM
Chris, man that is filppin awesome.
You did an outstanding job on the weathering, lighting, crew, aircraft..... Lots of work but every bit worth it.
    August 2019
Posted by HooYah Deep Sea on Monday, August 24, 2020 11:26 AM
Ben,
In answer to your query on railings on top of the conning tower, no, there were not any there. They were in the area of the Mk49 mount, which is actually not a solid platform but a ring with added support members.
"Why do I do this? Because the money's good, the scenery changes and they let me use explosives, okay?"
Posted by Gamera on Monday, August 24, 2020 6:29 PM
Mongoose: WHOA!!! That looks AMAZING!!! LOVE IT!!! Heart
Ben: She's coming along great!!!
    June 2018
Posted by DRUMS01 on Monday, August 24, 2020 7:59 PM
Thanks for the confirmation Hoo YA, and for the kind words Gamera.
Mongoose: WOW! that is one fine carrier! I commend you on the fine work and results.
I had some time to work on the Arizona today so I jumped in feet first and began work on the splinter shields for the 5" / 25 AA guns.
Just to recall how I got to this point, the kits splinter shields were molded into the deck, far too thick (2-3 ft of steel in scale), and the Eduard PE detail set had all of them available to make a more accurate kit. I followed the Eduard instructions to remove all of the splinter shields from the superstructure deck. Next I realized that the wood deck I purchased from the far east was made for the kits splinter shields. This meant I had large gaps between the Eduard PE shields and the wood floor. It also had gaps where the stairs were molded into the kit and various other items (see picture).
Of course this would not work so I searched and found my current deck supplier who not only had a more accurate planking and deck color but also a solid floor which allows me the opportunity to use the PE parts.
So with everything removed from the deck and the new wood installed I was wondering exactly how I would get the PE in the correct shapes. Remember that failure to shape the splinter shields correctly will be compounded when adding the handrail on the sides of the ship. After some time, I came up with a solution. Use the old wood deck that was pre-cut for the old shields as a guide to shape the new ones (brilliant!).
To validate the shapes and placement I also use a scaled up print of the ships drawings.
The splinter shields come from Eduard with the channel bracing attached to the end of the shield (see below).
The problem for me was that some of the bracing pieces ware already separated from the shield while still on the PE sheet. During my attempt at shaping the shields more fell off. So I tried attaching them first and then shaping the shields but they also fell off. Considering the bracing parts are smaller than a babies fingernail sliver and gluing them to the shield would have been difficult and possibly messy, I chose another method to simulate the bracing on the shields; extra fine precision solder. It has the same thickness and width but it is very forgiving to trim after placing it on the shields final shape. So now all I had to do was cut, glue, and trim 112 pieces of solder, ensuring that they are all correctly spaced and parallel to each other (!!!)  :crazy:
After three attempts, countless errors, and some colorful words, I have finished all of the splinter shield metal work. Next is the painting, then fixing to the deck, adding the guns, etc. Here are my much reworked splinter shields. Overall I am happy with the results. By the way, if any of you have successfully bent the Eduard splinter shields while using the Eduard bracing please share a photo and let me know the secret for any future attempts.
Well, that is is for this update. Slowly getting there, but this was definitely the last major hurdle. Thanks for following along.... comments encouraged.
Ben
PROJECTS:
    January 2015
Posted by TheMongoose on Monday, August 24, 2020 8:38 PM
Thanks guys!
After staring at the pics and getting some constructive feedback I decided Einstein's equation just didn't pop like it should. Played around with background color to see if guys weren't dress whites white enough lol, tried adding more guys, discovered staggering them and getting rid of the lines your eye sees the way I placed them was the biggest impact. Still added 200 sailors to this! I think it shows better here. Your thoughts?
MC if it's not too much bother an you think it looks better can you exhange this for the one I picked for page 1 yesterday?
    May 2020
Posted by Keyserj on Monday, August 24, 2020 8:42 PM
Ben: 112 pieces of solder??? That is some real dedication. Yes
Mongoose: That carrier looks friggin spectacular. Just curious though, what is up with the deck under the figures in pic 2? Is it some sort of adhesive strip?
"Why don't you knock it off with them negative waves?"- Oddball
John
On the bench: 1/35 Trumpeter m1132 ESV Stryker
    January 2015
Posted by TheMongoose on Monday, August 24, 2020 8:43 PM
Ben that's awesome! Actually I think your solder solution probably looks better because it has more depth to it. Kudos that level of patience. Oh and by the way..."After some time, I came up with a solution. Use the old wood deck that was pre-cut for the old shields as a guide to shape the new ones (brilliant!)." BUY THAT MAN A GUINESS Beer
    August 2019
Posted by HooYah Deep Sea on Monday, August 24, 2020 11:29 PM
Ben, Also remember that there are a lot of discrepancies in the 1/350 scale kits that have been addressed in the 1/200. But there are still discrepancies that should be fixed. All of the hatches should be closed under normal circumstances unless you are going to put her 'in port'.  Also, it has been determined that the support structure for the aft 1.1" tubs is square rather than round. And, don't forget the pedestal for the director for those 1.1" guns.
    July 2014
Posted by modelcrazy on Tuesday, August 25, 2020 9:36 AM
Excelent Ben, the solder looks great Yes
Chris, no problem. I'll cahnge it out.
    June 2018
Posted by DRUMS01 on Tuesday, August 25, 2020 10:56 AM
Thank you John, Steve, and Mongoose...... That soldering almost drove me crazy. I can only imagine what it would be like replacing all of the fine details on the Akagi aircraft and bracing. All in all, that is some fine work you have gave either completed or got going on.
Hoo Yah Deep Sea: I agree with the elivated aft gun tubs. I am going to remove my previous work and rework the support braces. If your refering to the small circle platforms on the front of the Emergency Cabin Platform for the Mk 19 Directors which were never mounted, I am researching to determine if they were added on the Arizona prior to June 2014 (?).
As for the doors, mine is indeed going to be docked or anchored. I am still determining if I want to delopy one or two little boats as well.
Thanks for your help on authenticating an accurate build. I am fixing many items from the kit, but I'm sure that some things will be missed. She will not be a "perfect" replica, but she will be really close to authentic.
Ben
PROJECTS:
    August 2019
Posted by HooYah Deep Sea on Tuesday, August 25, 2020 1:28 PM
Ben, that pic that I attached previously was taken in January, 1941, in Bremerton. As you can see, it has the 1.1" tubs and the MK 49 support mounts on the superstructure. Not visible behind the aft 1.1" tub would be the aft MK 49 pedestal.
    June 2018
Posted by DRUMS01 on Wednesday, August 26, 2020 12:15 AM
Thanks Hoo Ya for pointing that out. it was At this time I got all the previous corrections done except the Mk 49 platforms attached to the Emergency Cabin Platform. Neither Eduard, Tom's Model Works, or the kit provided those platforms so they will be made from scratch. I do not anticipate any major issue getting them on there.
Until then, here is another incremental update...
1) removed old braces on rear 1.1 AA tubs (they were out of scale) and replaced it with the .015" precision solder. Lightly sanded the round facing of the solder flat the replicate the rectangular bracing (hard to see). Painted tub and tub platform then attached to lower aft deck.
(Here are the large braces, now removed)
(New braces) Note the water tight deck doors open
2) Painted all 5" AA gun splinter shields and attached them to the superstructure deck.
3) Created stairs from main deck located at the left rear of the conning tower. It goes from the main deck up to the Emergency platform. Painted and attached it to the Conning Tower base.
4) Folded several PE ammo containers that locate under the new stairs, in front of the Conning Tower base, and the starboard side of the tower base. Painted and attached them to the deck.
5) Added the forward 1.1 AA gun tubs to the deck with a couple people.
6) Attached two of the previously built 5" /25 AA guns in the forward positions. And yes, I will need to do some minor touch-up but nothing major.
6) Folded four water tight deck doors, painted and added to the superstructure deck. I wanted to show them open so the stairs could be seen upon close inspection. This means I also had to add the support strut for the doors (thin guitar wire from spares).
7) painted the details that were added to the sides of the superstructure (fire hoses, wire conduit, doors, etc.
It may not sound like much, but it was very time consuming. I am happy to be this far along today.
Till next time.
Ben
PROJECTS:
    July 2014
Posted by modelcrazy on Wednesday, August 26, 2020 8:54 AM
Yes Ben, some very time consuming stuff. I geting less and less likely to build the Arizona as she was and just go with the destroyed version a month after the attack. There's just too much to fix. Easer to break.
Also I'm going to get back on the Akagi after I complete the Apache on the bench. I have less than a year now to get'er done.
Posted by Gamera on Wednesday, August 26, 2020 9:15 AM
Mongoose: That's friggin' amazing. Thanks for the new photos- it's a lot easier to see the crewman doing the E=M/C2 on the deck!
Ben: Wow, oh wow. That's just amazing too- all the extra work you're putting in there. And the results look fantastic!
    January 2015
Posted by PFJN on Wednesday, August 26, 2020 11:53 PM
Its great to see how everyone is progressing.  My ship is going kind of slowly right now, but I did get a chance to mix up some thinned putty/Bondo Spot Glaze and coat the areas where you could see "stepping" of the layers.  Hopefully I can try and sand the surfaces out tommorrow and finish touching the surfaces up.
One area I am not sure of how I am going to proceed on yet involves the few doors present on the ship.  On the ship they are just shown as raised rectangles, which is fine for me.  But since some are on the areas where I have had to add putty I'm not sure if it would be easier to sand them off and hten re-add some new doors made from Styrene strips or if I should consider buying some Photo Etch doors.  My fear is that if I add photo etch doors in some locations, I should probably replace all the existing doors to match Indifferent.
I'll have to think it over for awhile.
Pat
Ship
1st Group BuildSP
    January 2015
Posted by TheMongoose on Thursday, August 27, 2020 6:26 AM
Interesting dilemma Pat. My 1st thought would be keep it consistent on any 1 side. If you have to do PE on the back hangar bay then strip all the doors to be consistent. I don't think everything on a side needs to be Pe but all similar pieces would. Of course it'll be an eyeball thing so you won't really know till you do the 1st one. For what it's worth there's a thought :#)
    June 2018
Posted by DRUMS01 on Sunday, August 30, 2020 8:05 PM
Hi everyone, little baby steps for me this time....
- While in the The Puget Sound Naval Shipyard in January 1941, the USS Arizona continued its modifications. One of the items added was the "birdbath" MG platform on the top of the main mast. Another thing added was the small round platforms for the Mk 49 gun directors. The actual directors were not installed but the platforms were added to the Emergeny Cabin Platform of the superstructure (thanks Hoo Yah for bringing that to my attention). The kit and all of my PE details from Eduard and Tom's did not provide them so I made them. It was easy punching out two round disks from plastic sheet and modifying a couple extra pieces of PE to replicate the bracing; here is the results:
While working on the small stuff, I began mounting the small boats onto the jigs that hold them on the deck. I also started adding the small items to the main and upper decks, items like the water proof doors, reels, vents, some stairs, etc. Here is where I'm at so far:
My next step is starting the work in the front anchor areas (windlass, chain, stays, locker, etc.).
I will also begin work on the water.
- I was wondering if I have to use etching primer on the foil to have the paint stick or will the resin water do the same thing?
- After it dries can I paint over it without any reaction to the foil or resin?
- Also what is best used to tint the resin (for making various layers of sea blue)?
HELP ANYONE....
Ben
PROJECTS:
    January 2015
Posted by TheMongoose on Monday, August 31, 2020 8:56 AM
Looking excellent drums! I haven't tried the foil method yet so unfortunately can't help,out there :-(
    July 2014
Posted by modelcrazy on Monday, August 31, 2020 9:09 AM
You shouldn't have any problems painting over the resin. They make a die for resin but I used enemel to color my resin and it worked just fine. the issue with mixing any color is the creation of bubbles. I didn't know it at the time but you can make your own vaccum chamber, fairly inexpensively which would pull out the bubbles prior to pouring. There should be enough time from mixing, vaccumming and pouring before it sets up.
    June 2008
Posted by lewbud on Monday, August 31, 2020 1:39 PM
Pat,
Don't think I've seen a printed ship in that scale.  That's kind of cool.
Mongoose,
Congrats!  The Enterprise looks fantastic!
Ben,
The work your doing on ARIZONA is amazing.  Looking forward to more.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    December 2003
Posted by scottrc on Tuesday, September 1, 2020 7:31 AM
Mongoose, you did a fine job on the Big E.  CongratsToast
Ben, I never knew that old kit can be turned into a master build.  Keep up the great work and photo documentation.  I may have mentioned it, but that kit was the first kit I ever did PE on, just the rails, catapults, and other simple stuff, but all the compound curves on the decks were quite a baptisim.
I have done nothing for the past few weeks on my models.  Too much going on outside to be inside.
Scott
    July 2014
Posted by modelcrazy on Tuesday, September 1, 2020 9:52 AM
I hear ya Scott, I'm very busy working for the next several months
    June 2018
Posted by DRUMS01 on Tuesday, September 1, 2020 2:26 PM
Work?,... what is work? Is that were you are a humble minion, are a boss, have a boss, get bossed, and get paid for it? I thought when I retired that I would be able to kick back and fully enjoy my hobbies (or do nothing) and get paid for it. Now my spouse is the CEO and I'm the minion. Happy wife.... happy life.
Back to modeling, I was researching more on the clear acrylic resin over foil and found that many people have done so with good results (thanks Steve). I've also seen methods to tint or color the resin which is poured in layers not to exceed 1/8 inch. They make concentrated color tints for acrylic resins so any color could be possible. One issue with mixing tint or color into the resin is the creation of bubbles which can be hard to remove from the resin, depending on the thickness of your resin. Steve mentioned the use of a vacuum device to remove them.
As Steve and others have indicated, it is also possible to use acrylic paints to paint over the resin after it dries (versus tinting). I'm sure you can even use both the painting and tinting methods together for a wonderful effect.
One trait when pouring liquid resin is that it likes to settle in the deeper contours of your relief and leave very little product on the peaks. Depending on what your trying to achieve, this can be good or bad. Most applications of liquid resin tend to lay very flat, like smooth, calm water.
One nice effect of pouring colored resin over foil is the mirrored depth effect. It is my expectation that in order to gain the depth you desire, I will need to pour at least 2-3 layers, but the results should be really nice; just look at the aircraft Steve posted in the previous messages (WOW!). That is what I will be attempting on my foil.
The first thing I did was seal the base or area you want to hold the liquid resin. I am using a picture frame from my local HL. They normally come with a hard fiber board removable backing. You cannot rely on the fasteners on the back of the frame to hold the resin. I sealed the backing using Locktite GO-2 all purpose clear gel adheasive. It performs like super glue or CA cement but is thick and dries absolutely crystel clear. In my experience it will seal a gap up to 1/8 inch easily. This is the cement I used on my wood deck as well. It does not discolor the deck; can be applied or spread by brush; is self leveling, and gives you 5 minutes to adjust it before starting its cure / tack time. It is fully dry in less than a couple hours.
I used the Locktite to cement the foil to the picture mat board and the mat board to the inside of the frame. To ensure the frames integrity I also placed a continious bead of the Locktite around the edge (between the frame and the foil). After all, I did not want my resin to seap under the mat board and foil.
Instructions for the resin have you carefully pour the resin in the center of the area and spread it out slowly using a craft stick (like a popsickle stick, toungue depressors, paint stir sticks, etc). If any part of your display is lower than everywhere else, that is where is will gather or settle. The tint will appear darker the thicker it is applied. For this base I chose to purchase a pre-tinted resin made by JTT & Partners. They are a common supplier for scale railroaders. I really liked the blue/green hue of the tint. You can find it at most hobby stores. My final layer will be a straight clear.
Enough said, here is my first pour. As you can see, the foil is not perfectly flat and balanced. That will disappear over the next couple pours.
Much more to come on this to include a possible different method of applying white caps or sea foam. I also have another update for the forward deck and anchor area that I will post separately.
Finally something totally different and just for fun, a post of a ship I built nearly 20 years ago (before all the crazy PE stuff), I believe most of you will know what she is.
Ben
PROJECTS:
    June 2018
Posted by DRUMS01 on Tuesday, September 1, 2020 6:52 PM
And now it is time to have fun with the ships anchor assembly. Being somebody who never served a day in the navy, some of the terminology had me at a disadvantage. Be honest, how many of you know what a Capstan, Wildcat, Windlass, Hawspipe, Pawl, Riding Chock, Bitter End Ring, Spillpipe, or Devils Claw are? These are just some of the parts I needed to understand to ensure I made an accurate anchor chain assembly for my USS Arizona.
I feel it is easier to show you the parts than try to explain them:
The kit only had a mild relief of the metal anchor flash plates (chain guide) molded into the deck with a half molded thin representation of a chain and a Windlass with not much more detail. The models Hawse Pipe (area where the anchor chain feeds from atop the flash plates to the outer hull) and chain tail pipes were without detail. The kit did not have any representation of the chain stoppers or Devils Claws either.
What is a Devils Claw you ask? The devils claw or chain stopper holds the load of the anchor and chain when at anchor, taking the load off the windlass, and the Devils Claw is for tensioning the anchor chain when the anchor is stowed, preventing it from moving when under way. Normally the Devils Claw or Chain Stoppers are attached to a chain link on one end and to a Two Eye that is part of the flash plate on the other.
Regarding the terminology of the Windlass, Wildcat, or Gypsy heads; A Wildcat is the part of the Capstain assembly used to engage individual links of chain, the Windlass is the vertical type of pully used with the Wildcat to guide the chain through the chain tail pipe or spill pipe then into the chain locker of the ship, the Gypsy Head is the horizontal equivalent to the Windlass. Both a Windlass and Gypsy Head have a Wildcat, totally clear now... right? This model only has a basic Windlass and a half molded supporting gypsy winch.
I have to bring up the Bitter End as I thought it was neat. It appears that the term "to the bitter end" really originated as Naval terminology. The end of the chain down in the chain locker is called the Bitter End. It is normally permanently attached to the ships bulkhead. So deploying a ships chain to the bitter end is using all of the chain, cool finding right?
To fix all of these issues on the model Eduard provided many of the parts in PE, 29 individual parts actually. Prior to adding any of the parts, the Eduard instructions had me remove the chain relief; drill out and shape the holes for the Hawes pipes and chain tail pipe; remove the partial relief of the Pawl; and drill the holes for the two front Hawse pipes including through the front of the ship.
Once prepared I added the deck and a new anchor chain flash plate. The Eduard mega pack also provided a scale anchor chain. Following the Eduard instructions I added everything back with the exception of the Hawse Covers and Devils Claw (chain stopper).
Image of a chain with chain stoppers the the two eyes
According to the Eduard instructions each chain has two chain stoppers (represented by the small "V" chain over the main anchor chain). From what I can find in photos, the Arizona usually had one per chain like the photo above. Likewise, in the photos I could find, the Hawse Pipe Pipe openings did not have covers on her deck either. Perhaps they were added later?. Other than the chain stoppers, here is my reworked anchor chain assembly. The brass pieces are the two eye connectors for the Devils Claw or Chain Stoppers. They will be painted when the stoppers are added. The chain was dry brushed using rust color paint and the flash plate was colored with Tamiya weathering pastels to simulate rust.
Till next time....
Ben
PROJECTS:
    August 2019
Posted by HooYah Deep Sea on Tuesday, September 1, 2020 8:39 PM
Ben,  sorry to rain (actually just a little dribble) on your parade but .  .  . the first drawing you posted is for a civilian ship. The U.S. Navy doesn't do it that way, not that it will change what you've done on your model, because that looks great.
With the anchor pulled all the way into its housed position, chain stoppers are attached. Usually two are used per chain run. The Canoe Club does not use riding chocks and pawls. On the stopper, one end is anchored to the deck, and on the other end is what is called a 'pelican hook'. It is the pelican hook that engages the chain as it actually folds over the top of the chain and then a long link hooks the holding bar and the whole thing is secured by small line.
Though I personally love your weathering of the chain, no Boatswain's Mate worth his salt would permit the chain to be rusty and would have his guys (Deck Department, First Division) paint that chain. Correct color - black.
In this picture of ARIZONA in drydock, you can see that three stoppers are used on each chain.
I'm here, any time, for any Navy questions you may have.
