Hey stik, great work on your Corsair. I'm a sucker for planes with shark mouths!
My Skyhawk sits in the same state. Its undersides are painted white, but I haven't done anything beyond that. Today, I focused on my A-7A. I don't know what markings I'm going to use yet. I have Superscale's VA-153 Blue Tail Flies, but I might build my airframe in some markings that weren't seen in theater.
Anyway, today I spent time cleaning up the closed avionics panels and IFR assembly.
Fit's not too bad. I'm sure after some primer and paint things will look OK.
Besides the panels, I figured out what to do with the intake trunk. I poured some latex paint into the assembly last night and let it set up. It didn't completely cover and there's some translucence, but I'll spray some white down into the trunk when I paint the underside.
For the rear of the trunk, I took a random compressor face I had in my spares box and shaped to fit inside the trunk. Then I glued it to a piece of roughly shaped styrene sheet.
Once painted and installed, it looks better than the molded blank rear "wall."
Then I moved my attention to the Corsair's office. The kit's seat fits between two "rails" in the cockpit.
The problem I ran into was that I decided to use a resin seat that's too wide to fit between the rails. So, I figured I had to thin the rails and seat to make things fit. One rail had some sort of bottle molded to its top.
To avoid sanding a flat spot on bottle when sanding to thin the rail(s), I cut off the bottle...temporarily.
After I thinned the rails, I also took some off of the seat's sides that would be hidden by the rails.
After that, things fit pretty well.
Once satisfied with the fit, I glued the bottle back onto the top of the rail and finished assembly of the cockpit. Here's everything ready for installation.
Before I can close up the fuselage, I need to build up the wheel wells. That's next...
That's it for now. Hopefully my next post will have some progress on both the Skyhawk and Corsair to share.
Again, feel free to comment, quesiton, or criticize. Drop your two cents into the bucket.
Thanks for lookin'!
-O
