Larry Wolf Memorial Close Air Support Group Build 2021 Needs YOU!
    May 2004
Posted by cbaltrin on Friday, April 2, 2021 6:49 AM
plasticjunkie
Now that you mentioned it, there isn’t a completed build page either. Has anyone tried to pm him? Doesn’t sound good.
I emailed him a few weeks ago. no reply.
On the Bench: Too Much
    November 2008
Posted by plasticjunkie on Friday, April 2, 2021 7:07 AM
cbaltrin
plasticjunkie
I hope he’s ok.
 GIFMaker.org_jy_Ayj_O
    May 2004
Posted by cbaltrin on Friday, April 2, 2021 7:59 AM
Ditto on that.
    June 2017
Posted by fotofrank on Saturday, April 3, 2021 1:32 PM
The Tigercat received Mr. Color Navy blue paint today. This model is the biggest model I've painted in a very long time. The paint was thinned 1/1 with Mr. Color Leveling Thinner and I still used almost the entire bottle. I think I have enough paint left in the bottle to even out the color a little better tomorrow.
Any news on lewbud?
OK. In the stash: Way too much to build in one lifetime...
    March 2008
Posted by Caveman on Sunday, April 4, 2021 12:39 AM
Nice work guys.  I hope to get to my 111 soon.  I think Lewbud started a new job recently, maybe that's taking up his time.
Posted by jeaton01 on Sunday, April 4, 2021 12:42 AM
I sent him a PM, but he hasn't replied yet.
The F7F looks good, Frank.
John
Posted by jeaton01 on Sunday, April 4, 2021 10:34 PM
I've been making slow progress on the A-18, not much of which has been picture worthy.  However, the fuselage is together now and the wings and empennage also.  I started working on fitting the engines and have decided the ones in the kit are more the size of an R-985 than an R-1820 so I'll have to wait a few days for some engines from Starfighter Decals.  The vacform canopies are also fitted and masked.  There is another window in the fuselage just forward of the aft cockpit on both sides that looked like trouble, so I cut out an oversized area and put in some plastic from a CD case and polished it out level with the resin fuselage.  The broken landing gear has been fixed with music wire and the prop blades have been installed on the hubs.
There was some mold mismatch to work on on both nacelles, this is the worst.  Fixed with CA and dental alginate and sufficient work with a heavy file.  The resin is very hard but not brittle.  The seats are PE which I soldered together.
The window work and the interior bits.  Much resin was removed from the cockpit floor befor things were happy.  I can't imagine much will be visible.
The darker resin engine is from the Special Hobby Grumman FF-1 kit and is about .020 smaller than the proper scale size of the engine, right at .75 inches.  The kit engines are .600 and look lost in the cowls.  I can use them somewhere else that needs a 9 cylinder radial like an R-985 or R-975.
John
Posted by Bish on Monday, April 5, 2021 3:53 AM
I started my Stuka a couple of weeks ago so time for my first progress post. This is my 7th 72nd Ju 87. While i do like the Fujimi kit, this new Airfix one is clearly a step up in detail. I know the Fujimi kit is a little oversize, i have not yet compared this one to scale plans but i will at some point. Going over the kit, there are a few things i think they could have done better, but to some degreee these are largely personal preferance. As its a Stuka, i do tend to be a bit picky.
I will be ading some Eduard PE and Quickboost resin.
The first thing i checked when i got the kit was the supercharger intake. At least one of the marking options is a Trop Stuka, but unfortunatly Airfix did not include the larger Trop intake. This still leaves only the Italeri kit with this option. This is not an issue for this build as i won't be useing the kit markings, but i would pike to have the option of doing Trop Stuka's and unfortuantly the AM market has still not provided any option for this.
As usual, i started with the pit. The kit detail is very nice as it is, so the PE spruces up whats there.
The gunners seat should just be a frame, but as i am adding the gunner, its not an issue.
This was a bit odd. Never seen this reccess underneath before, i had to look it up. There should be a fairing over this. Its a nice option for a dio scene, but it would have been better is the fairing was included. All the pics i have seen in flight show this covered and i can't imagine they would leave it open and rick damage to the wiring. I will use some filler for this.
After paint and dry brushing, i added the pre coloure PE.
And then got the fuselage together. The centre piece with the seats wil fit up from underneath later.
More soon.
    April 2020
Posted by JBRaider on Tuesday, April 6, 2021 4:55 AM
I am hesitant to post my P-47 progress as Lewbud never responded after I requested to join in back in February.
Between work and home repairs I was able to get a lot done, just at a slow pace.
Cockpit was painted up and most of the major assembly went by quick, just not a lot in these 1/72 birds
I wanted to do the checkered tail but I didn't trust the Academy decals so I decided to try to paint them on. I went out of order by painting the checkers before the rest of the plane in case I messed it up and had to start over.
I started with XF 3 but went back over it with a little orange mixed in to match the decal color
Using my Infini cutting mat i cut out the squares and hit it with Flat black
Not perfect but I was really happy with the result. The rest of the primary colors went on last weekend.
Posted by Bish on Tuesday, April 6, 2021 6:22 AM
Thats looking really nice, you did a great job on the tail.
lewbud may just have missed your post, it can be a bit hectic hosting a popular GB and its easy to miss a post or two.
    June 2017
Posted by fotofrank on Tuesday, April 6, 2021 7:35 AM
JBRaider, the checkerboard tail is well done. I've been tempted to paint a checkerboard tail myself. Your paint job just might be the inspiration I need. Thanks for sharing.
    May 2020
Posted by Hutch6390 on Tuesday, April 6, 2021 3:07 PM
JBRaider
I wouldn't be happy with that, I'd be positively delighted!  Great job, well done!
Vell, Zaphod's just zis guy, you know?
TakkaTakkaTakkaTakkaTakkaTakka
    April 2020
Posted by JBRaider on Wednesday, April 7, 2021 4:54 AM
Thanks Bish
Frank, after seeing some of your work I know you wouldn't have any trouble with checkers.
Thanks Hutch!
Having the Infini cutting mat made it so much easier since all of the squares were a consitent size
    July 2008
Posted by castelnuovo on Sunday, April 11, 2021 12:40 AM
Well, it is done now
The other bombs came with the kit so I though what the hack, lets include them. If lewbud returns the 5th pic can go to the front page.
Cheers...
Posted by Bish on Sunday, April 11, 2021 5:18 AM
Time for another update. I got the cockpit fitted which go in from underneath. It was a very tight fit and i had hope to dry fit. But i couldn't remove it for risk of breaking somthing so i ended up clamping it in place as it could have done with some sanding down. One very nice touch on this kit is the addition of the pilots target viewing window. Its attache to a box structure which i had not seen before. I can find any pic of a B pit where you can see it. But i did find an image in a new book i recently got which show in from a training manuel. What is mssing is the external cover to the window which always seems to be closed when on the ground. Fortunatly the Eduard set has that part.
The recess around the centre bomb carrier was fille. Not perfec as there are a couple of small openings. But once the bomb is attached this should not be noticed.
And then all the final touches to get it ready for priming. The instructions only have you fit the siren mount but the kit does include the sirens. The only image of the aircraft i am doing is a profile in an Osprey book which only shows the mounts. But as i have no photo of it and there is no saying the sirens were not *** and later removed. As i have no Stuka with the siren, i felt it was well over due. So i fitted it. I also added wing guns and pitot from Quickboost.
Now its all together, i can see that IMHO, this is the best 72nd Ju 87B. Clearly the detail is far better than the 30+ year old Fujimi kit. Other than sliding in the pit, the fit is very nice, just a touch of filler along the wing join with the fuselage. The addition on the window under the fuselage is a nice touch. There are just a few small things which stop this kit being perfect. A cover for the window and a larger Trop filter would be great additions. Its also missing the IFF antenna from under the fuselage. oddly Eduard does not include it even though they do on the set for the Fujimi kit and hopefully i have a spare Fujimi one in the spares box.
The one thing i really don't like is how Airfix mold the open canopy with the pilots section molded onto the fixed centre piece. Will have a pic of that next time.
Posted by Bish on Sunday, April 11, 2021 5:19 AM
Nice build there castel, thats some load you have there.
Posted by jeaton01 on Sunday, April 11, 2021 4:53 PM
After some fiddling I got the R-1820G's mounted on the A-18.  There is not a lot of clearance between the prop tips and the nose.  It reminds me of the Grumman F5F in this regard, as well as in the size of the nacelles relative to the fuselage.  The engines from Mark Tutton, Starfighter Decals, are excellent, as well as very reasonable in price.
http://goldeneramodel.com/mymodels/a18/013a18.jpg
http://goldeneramodel.com/mymodels/a18/014a18.jpg
John
    May 2004
Posted by cbaltrin on Sunday, April 11, 2021 5:56 PM
Looks good John , should be a beauty when done.
    March 2017
Posted by Armor_Aficionado on Monday, April 12, 2021 6:44 AM
First images of my WIP on the A-10 Warthog:
Posted by jeaton01 on Monday, April 12, 2021 5:26 PM
Thanks, CB.
Here it is after some more filling and sanding, and a good coat of insignia blue as a base for the Alclad aluminum.
John
    May 2004
Posted by cbaltrin on Monday, April 12, 2021 7:23 PM
Insignia blue for alclad base eh? Interesting...
jeaton01
Thanks, CB.
Posted by jeaton01 on Monday, April 12, 2021 8:25 PM
There's nothing about black that's magic, in my mind.  Also, what you see when you look at a shiny object is what it is reflecting, and on a good day that's blue sky.  I've used different dark blues in the past with good results.
John
    April 2014
Posted by lostagain on Tuesday, April 13, 2021 8:09 AM
Ben and Jarrod great result with the C-119
68GT, super finish on the A-10, very slick.
Omar Good work forcing the A-10 into shape.
AA, Yes! An A-10. You can never have enough A-10s!
 Castelnuovo Corsair II – Great work with your bird, and a massive load nicely presented – reminds me of the RAAF publicity photos of the F111 with all its ordinance spread out in front.
Eaglecash, Super detail in the Frogfoot cockpit there
Phillie Phan, Super result with the bug
Dodgy, you know I am watching how you go with the Boomerang
Fotofrank – Great finish on the Panther, an attractive plane, looking forward to seeing your magic on the Tigercat. AN d that is looking great too – the faded finish is a thing of beauty.
Dwsrazor – always interesting opening up an old kit! Like the tadpole shape of the Breguet
PJ – Fantastic result with the F-84! Super work with the metallic finish. That decal work looks very involved and scary (to me).
Tomcat – you have certainly picked a challenge with the Invader – that will keep you busy!
Bish – Stuka is coming together nicely and quickly.
JB Raider – super painting work on the P-47
John - interested inthe metal on blue too
My offering is the Russian Frog Vultee Vengeance dive bomber. I think the kit shows its age, like some of the other offerings in this GB. I have taken some big lumps out of the cockpit and replaced with a little detail.
Then painted it up and installed it.
    June 2017
Posted by fotofrank on Tuesday, April 13, 2021 3:07 PM
Headed out to the paint bench in the morning. The paint masks are a mix of Montex and homemade. A friend has one of those stencil machines and he made the WM's that weren't on the Montex stencil sheet. This is a first for me. Everything will be painted on -- no decals. Well, maybe one or two small decals, but that's it.
    July 2008
Posted by castelnuovo on Tuesday, April 13, 2021 11:48 PM
Would Douglas SBD-2 Dountless qualify for this GB? It is from Academy, Midway version.
    June 2017
Posted by fotofrank on Wednesday, April 14, 2021 2:10 PM
After the F9F Panther and the F7F Tigercat that is in the finishing stages, I had been looking for a follow-up build. Since the Panther and the Tigercat are both Korean War, I wanted to stay with that theme. I found this kit the other day:
Maybe not the best kit. Raised panel lines and I'll have to source period ordinance but I think the kit will build up really nice. So this Skyraider will be my third contribution to this Close Air Support Group Build.
    May 2004
Posted by cbaltrin on Thursday, April 15, 2021 3:54 PM
U r a brave man FF Stick out tongue
    March 2017
Posted by StugIIIG on Friday, April 16, 2021 8:33 AM
Hi, I'd like to join this GB. I have an old Airfix P38H in 1/72. Picked it up at a garage sale a few years back for $2. Problem is it's missing a propeller and....the snoot. I'll be doing a "flying model" so I'll probably use acetate circles for the props there. The snoot, well, I have some milliput on the way and guess i'll try my hand at sculpting. If anyone has a spare from this kit, be glad to take it.
Anyone know of a source for pics of the P38H with bombs attached? An hour on the internet has produced exactly one, only in shadow, shot of this plane with a bomb attached.
JohnA
    May 2004
Posted by cbaltrin on Friday, April 16, 2021 9:19 AM
StugIIIG
Built the MPC boxing as a kid. Memories! Good luck with your sculpting!
Posted by jeaton01 on Friday, April 16, 2021 5:20 PM
I don't know if this is an H or not but it is a good view of a P-38 with bombs on the pylons.
John
