WIP: IDF Megach 3 (M48A3) circa 1973
Posted by HeavyArty on Monday, May 17, 2010 7:35 PM
This is my latest project for a customer.  It is an IDF Megach 3 circa 1973.  It is basically an M48A3 with a 105mm L7A2 (US M68) barrel. Here is the actual tank.
I started with the Tamiya M48A3 by taping off the motorization holes from the outside and filling the inside with a thin layer of casting resin.  Once cured, remove the tape and sand smooth.  It is a quick and easy way to deal with motorization holes.
Next, I lowered the roadweels by about 3mm since Tamiya's kit was based on a vehicle without and engine and it sits too high.  I simply cut off the small pin portion of the bumper attached to each roadwheel arm.  This allows the arm to move up about 3mm and the tank to sit properly.
Next, I cut off the kit barrel just past the slinky section on the dust cover and mated a Verlinden Israeli L7A2 barrel from their M48/M60 update set.  I also removed the commander's cupola ring from the turret roof at this point in preparation for installing a Sherman early commander's cupola.  I made the fabric cover around the mantlet out of A&B putty as well.
I added strips of 0.040 styrene stock to the lower turret half to raise the turret up about 2mm as well since it is a bit squashed in the kit.  Once the basic construction of the turret and hull was complete, I gave them both a bit of cast texture.  To do this, I wet sections of the plastic with liquid glue, then stippled the surface with an old paint brush.  Another pass of the liquid glue toned it down and blends the texture look like cast steel.
After the cast texture, I installed the Sherman cupola and a .30 cal MG mount on the turret roof.
I also added Archer Surface Details casting numbers and symbols to the turret and hull.  I also constructed a storage mount for the search light and modified the air cleaners to the larger opening Israeli type.
Lastly, I cut the mud release holes in the sprockets.
I also added bolts and smaller details here and there, along with a Tank/Infantry phone to the right rear fender.
Some overall pics.
Now its off to the paint booth and markings.  It will also get a set of AFV Club's excellent T97E2 tracks on it.
As always, all comments welcome, so let me know what you think.
    July 2006
Posted by redleg12 on Monday, May 17, 2010 7:54 PM
Gino - Nice work....great fixing of the kit's short comings. I love the Archer surface details....good stuff.
Can't wait to see some paint!!
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    March 2007
Posted by KAYSEE88 on Monday, May 17, 2010 11:26 PM
HeavyArty
......so let me know what you think.
Well, Sir......now with all those amazing fixes and heavy research, you are being compensated with at least $1500....right????WhistlingWhistling
    June 2007
Posted by squeakie on Tuesday, May 18, 2010 12:21 AM
in the photo of the rear of the turret there is a large box of somekind with something white going over the top. What might it be? By the way the .04 shim for the turret answered a question that's been going thru my head lately
gary
Posted by HeavyArty on Tuesday, May 18, 2010 5:49 AM
Thanks for the comments guys.  She's moving along.  I hope to get some paint on her today.
...you are being compensated with at least $1500....right????
Yeah, I wish. Nowhere near that much.  It really didn't take that long to do the fixes and changes though.
I think you mean the Xenon serch light storage mount.  It holds the search light when not mounted on top of the barrel.
    September 2006
Posted by RBaer on Tuesday, May 18, 2010 9:59 AM
I'll be following this one like a flock of gulls and a shrimp boat......
Apprentice rivet counter.
    January 2003
Posted by p38jl on Tuesday, May 18, 2010 10:34 AM
Like peas n carrots.. ! Looks good..!
[Photobucket]
    June 2007
Posted by squeakie on Tuesday, May 18, 2010 10:55 AM
HeavyArty
http://img.photobucket.com/albums/v231/HeavyArty/IDF%20Megach%203%201973/IMG_0804.jpg
thanks! I've never seen anything like that before. Didn't say it in my previous post, but I really like the way you created the casting texture on the surface. Not too over done; yet it shows up very nice. You do nice work Gino, and it's always my pleasure to look it
gary
    April 2005
Posted by wing_nut on Tuesday, May 18, 2010 2:34 PM
Looks good Gino.  When you get it painted, get a shot of the turret with a good shadow to show that texture.
Marc
    July 2004
Posted by wbill76 on Tuesday, May 18, 2010 7:45 PM
Nice work dressing up the older kit Gino, definitely going to shine once you get some paint on it. Yes
Posted by HeavyArty on Tuesday, May 18, 2010 8:52 PM
Thanks for the comments guys.  I hope to get some paint on it soon and will keep you posted.
Posted by HeavyArty on Saturday, May 22, 2010 5:13 PM
The Magach 3 is done.  I sprayed it with Krylon Khaki from a rattle can, then proceeded to weather it with a couple sandy acrylic colors, then drybrushed with some Model Master Armor Sand.  I also drybrushed some steel on the tracks and drive sprockets.  The stowage is various packs from the spares box and a couple Verlinden IDF ration boxes.  I also secured the spare road wheels with center guide teeth.  The markings are a combo of Verlinden dry-transfers (inverted triangle), spare wet-transfers (barrel bands), and home made wet-transfers (IDF registration #s).
Here she is.
Some close ups.  The cast texture on the turret and hull came up nicely, as well as the casting marks.
More pics here.
I think it came out nicely and it was a fun conversion.  Let me know what you think.  As always, all comments welcomed.
    May 2009
Posted by Pawel on Saturday, May 22, 2010 5:45 PM
Hello Gino,
I like your build a lot, the conversion is really nicely executed. Personally I have a problem with the painting of the tank - too little color variation for me. If I was painting the machine, I'd add some shading, but I wasn't. Like I said, it's just me. Looking forward to see your next models - keep 'em coming and have a nice day
Pawel
www.vietnam.net.pl
Posted by HeavyArty on Sunday, May 23, 2010 7:09 AM
Thanks Pawel.  There is more variation in the color (quite a bit actually).  I think the lights and/or camera washes it out some.
    December 2008
Posted by New Hampshire on Sunday, May 23, 2010 7:19 AM
She came out really nice Gino!  Your customer should be roud to display it!
Brian
    July 2006
Posted by redleg12 on Sunday, May 23, 2010 10:45 AM
Rattle Can!!!!! Hole Excrement!!!....That almost seems like firing damp powder for you!!! Then again.....it looks like a complete burn and on target!
Nice....looks great....a bit clean but very nice. Love the casting and casting marks...they turned out great.
I am sure another very satisfied customer Wink
Rounds Complete!!
Posted by HeavyArty on Sunday, May 23, 2010 3:34 PM
Thanks Brian and Mike.
Yup, I find rattle cans work just fine for overall one color finishes.  I am using them more and more.  I guess I need to work on my camera skills.  The model is weathered pretty well and has quite a bit of tonal variation.  I guess it is washed out by the lights.
    September 2006
Posted by RBaer on Monday, May 24, 2010 1:45 PM
Looks great, Gino.
Did you scratch the mount for the turret .30-cal?
Posted by HeavyArty on Monday, May 24, 2010 7:18 PM
Thanks Russ.  The .30 cal mount, gun, ammo cradle and box, pedestal etc. were all left over from another kit (I believe it was the AFV Club Centurion Sh'ot Kal '73).
Posted by HeavyArty on Monday, May 24, 2010 8:14 PM
Thanks G.  On the cupola, my guess is they modded them.  The Israeli's also added the 105mm gun to them.
    June 2005
Posted by minimortar on Monday, May 24, 2010 9:53 PM
Very nice Gino! The M48 with the 105 has always been my all-time favorite MBT. Something real sexy about that combination and you've modeled up perhaps the most successful (+/-) version of that vehicle real nice like.
HeavyArty
...There is more variation in the color (quite a bit actually).  I think the lights and/or camera washes it out some.
Are your shooting with incandescant lighting in the room? Looks a tad on the yellow side from my point of view and I would tend to believe that you've got some sort of 'desk' lighting on somewhere close by but I'm far from being a half-way decent photographer.
Man, if I had 1/8 of your 'hootspa', I might get something done. I think that both you and Redleg12 should move to MA as I could sure use a heavy doseage of motivation...
Thanks,
Kevin Keefe
Mortars in Miniature
A Scale Model (Plus!) Collection of the Infantryman's Artillery
Posted by HeavyArty on Tuesday, May 25, 2010 6:52 AM
Thanks Kevin.  I am using desk lights w/incadescent bulbs for lighting.  I have tried messing w/the white balance on the camera too.  I'll have to see what else I can do.  Usually my setup works pretty well, maybe it was the vehicle color this time.
    September 2006
Posted by RBaer on Wednesday, May 26, 2010 11:30 AM
G, the Israelis hated the MG mini-turret/cupola. As soon as the M50 and -51 Shermans came out of service, the commander's cupola went on the M48s. I guess that may be why all the "monument" Shermans in Israel are missing cupolas......
