Best kits to represent the Tiger 131 in the new "Fury" movie?
    August 2004
Posted by a6m5zerosen on Thursday, July 17, 2014 6:50 PM
What is the best and most accurate 1/35th scale Tiger I kit out there to represent the Bovington Tank museum's Tiger 131 as seen in the upcoming "Fury" movie?  DML/Dragon?  If so, which kit?  Thank you
"no, honey, of course that's not another new model. I've had that one for a long time..."
Posted by Tojo72 on Friday, July 18, 2014 9:28 AM
I believe that Tiger 131 is a Tunisian Tiger.Dragon-Cyber Hobby has # 6286,good luck getting that one.Tamiya has # 35227 which is readily available.
Now as for the movie,I don't know what modifications they made on it to be in europe as depicted in the movie
    September 2004
Posted by tellis on Friday, July 18, 2014 11:28 AM
Tojo72 is correct on Tiger 131, it was captured by the Brits in North Africa, brought back to the UK for evaluation and is now maintained by the Tank Museum at Bovington. my understanding is that "Fury" depicts the war in Germany during 1945, which would infer that the Tigers these men face would be later models.
T Ellis  Springfield, VA  http://i158.photobucket.com/albums/t104/cycledupes/WWIIArmorBadge.jpg
Posted by Bish on Friday, July 18, 2014 11:57 AM
As Tojo says, it deepens what modifications they made to 131. One still I found seems to look as though the feifel air cleaners have been removed but the old style commanders hatch is still there. If the air cleaners were the only change, then any of the early production kits will do the job. You could go for the Tamiya kit 35216, I am not sure of the code for any Dragon kits that would fit.
    July 2004
Posted by stikpusher on Friday, July 18, 2014 12:01 PM
Or it could be a Tiger brought back to Germany for rebuild/overhaul. In 1945, that would not be such a far stretch as everything that was available to fight with was used. Germany truly was scraping the bottom of the barrel.
Here is a still from filming of the movie and 131 does not appear to have been modified for filming. Early type road wheels and cupola are plainly visible.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Bish on Friday, July 18, 2014 12:03 PM
That the photo I was looking at SP, and it looks to me as thought the air cleaners have been remove.
    July 2004
Posted by stikpusher on Friday, July 18, 2014 12:21 PM
Ah yes, no Fiefels. Just the exhausts are visible.
       - Plankton
LSM
    April 2013
Posted by KnightTemplar5150 on Friday, July 18, 2014 5:44 PM
http://www.tiger-tank.com/ is dedicated to this particular Tiger and has extensive information on the tank and her restoration. Note the unique step welded to her frontal armor - it's not typical of the Tiger series and seems to be unique to this tank. Also, search around - there's a rather notable photo of the Bovington Tiger after her capture which shows Winston Churchill standing on her engine deck to inspect the fording snorkel which was extended fully at the time of his visit.
    January 2008
Posted by Byrden on Wednesday, April 15, 2015 9:43 AM
Dragon will release a kit dedicated to portraying Tiger "131", just as she was in German service. If any modifications were made for the movie, that will be your problem.
David
    October 2008
Posted by P mitch on Wednesday, April 15, 2015 9:58 AM
Have a look for the Haynes Manual for the Tiger, its the full rebuild of 131 from Bovington and has lots of photos of the tank in all stages of completion.
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    January 2006
Posted by MECHTECH on Wednesday, April 15, 2015 5:26 PM
The New Dragon Tiger-1 Early Production Wittmann's Command Tiger #6730 would probably come as close as you can get. It  has all the parts you would need to build 131 as long as you have a reference to follow. And it has the new one piece track. It was just released this year.
    January 2015
Posted by M. Brindos on Wednesday, April 15, 2015 8:42 PM
One piece track? I have not heard of this. Off to Google I go.
Edit: Are you talking about those "DS" tan rubber tracks? I am still trying to figure out how to get paint to stick to them without it rubbing off lol. I've sprayed mine with Krylon to see if that makes a difference.
- Mike Brindos "Lost Boy"
    February 2006
Posted by DantheMan85 on Wednesday, April 15, 2015 9:52 PM
If Dragon releases a Tiger 131 it would be a cyberhobby kit, for around 80 to 90 USD dollars I'm guessing.  Having the same problem with my DS tracks, in some spots the paint  flakes off.  Only seems to happen when your fitting them on the tank.  Have the same problem with Tamiya's rubber tracks.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
Posted by Tojo72 on Thursday, April 16, 2015 6:51 AM
Wow,that's surprising,I have built five kits with DS.I have used acrylic and enamels and as of yet have had no trouble with paint or glue.Same for the newer Tamiya Tracks,no problems.
I'm not crazy about them,but I'm not spending extra money for AM tracks.Once in awhile I spring for Fruils,but in most cases I use what's in the kit.
    January 2006
Posted by MECHTECH on Thursday, April 16, 2015 7:14 AM
You have to wash with soap and then use a primer most definitely for any chance of paint sticking.
    January 2006
Posted by MECHTECH on Thursday, April 16, 2015 7:16 AM
And there is a video of Tiger 131 at a show on youtube. Just search Tiger 131
Posted by T26E4 on Thursday, April 16, 2015 9:44 PM
www.track-link.com/.../29571
www.dragonusaonline.com/item_detail.aspx
Just announced.  DML's Tiger 131.  Release date June 2015.  MSRP US$80
Roy Chow
Join AMPS!
http://www.amps-armor.org
    April 2005
Posted by JohanT on Friday, April 17, 2015 10:25 AM
Hello,
I am confused...
Do you want to build #131 Bovington?
131 as it was equipped in Tunisia?
The T1 as it is depicted in the movie?
A T1 as it would look in 44-45? Villers-Bocage?
What is the aim, build the Hollywood one or build a representation of what would have been a more likely version?
Very Best Regards
Johan
