Soviet Draisine - Krasnaja Zvezda - 1:72 HobbyBoss
    January 2006
Posted by SprueOne on Friday, October 3, 2014 11:11 PM
box art sprueone
All images of this WIP BLOG is here: https://imgur.com/a/uF5wE
Soviet Draisine "Krasnaja Zvezda"
Kit Number 82912
1:72 scale
Hobby Boss
yup, I started another build . . .
This kit looks like a very simple build and the parts on the sprues are clean casts without seam lines or flash. Crisp detail too.
1/72 draisine sprueone
Well I just started and already confused about the positions of the left and right bumpers. The I-sheets indicate the rounded (part C8) to be installed on the 'left' and the flat (part C9) on the 'right'.
But, the box art and painting/marking guide shows the positions as (part C8) on the 'right' and (part C9) on the 'left'.
box art sprueone
Box Art
soviet draisine box art sprueone
Marking & Painting Guide
I've search the interwebs as thoroughly as possible and found only 2 pictures that are not clear on this detail.
Anybody know the correct configuration?
thanks for looking
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Saturday, October 4, 2014 5:26 AM
                                             http://topwar.ru/uploads/images/2014/604/qsko553.gif
  I believe it (C9) is located on the left side as the box art and painting/marking guide illustrates.
    This would make it compatible (bumperwise) with the locomotives and other switching vehicles I've seen    http://www.opelclub.co.za/forum/images/smilies/facepalm-smiley-emoticon.gif
Sherman-Jumbo-1945
"I was so much older then, I'm younger than that now"
    January 2006
Posted by SprueOne on Saturday, October 4, 2014 10:05 AM
Thank you, good info. A few others got back to me with concurring detailed information.
Now I can move forward with confidence
    July 2004
Posted by wbill76 on Thursday, October 9, 2014 3:55 PM
Should be a fun project SprueOne, looking forward to seeing what you do with it. Beer
    January 2006
Posted by SprueOne on Thursday, October 9, 2014 7:26 PM
Thanks for looking in, Bill. I think your FT-17 French Light Tank has way more rivets than mine though Smile
    April 2006
Posted by waynec on Friday, October 10, 2014 10:37 AM
i have one of these, kinda an impulse buy at the time but as i get more into 1/72 and have ALL the choo choo and railguns including DORA its not as much an impulse buy anymore. looking at my BR-86 german locomotive if i am in the cab looking forward the round one will be on the right side in the front and the left side in the rear. as yours is more like a rail car as long as the round one isn't on the same side on the front and back you should be fine.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    January 2006
Posted by SprueOne on Friday, October 10, 2014 9:45 PM
This is my second 1/72 model. The first was the old ESCI diorama kit that I built long ago: "Berlin Die Gotterdammerung" http://img.over-blog.com/600x369/5/65/76/73/les-dioramas/ESCI/Berlin/ESCI_2021-Berlin_die_gotterdammerung-01.jpg which I still have . . . somewhere...
Thanks for the info on the bumpers. Very helpful
    January 2013
Posted by jibber on Saturday, October 11, 2014 1:05 PM
Wayne funny you said that I'm looking at getting a BR-86, I just picked up a great deal on Ebay for  Hasegawa Karl Morser with the rail cars in 1/72 for $18. I opened it up the other day and it looks awesome. Thinking about a Loco to set on some tracks.
    July 2004
Posted by wbill76 on Saturday, October 11, 2014 4:48 PM
SprueOne
You could be right! Those WW1 guys didn't know any other way to handle armor plates/steel vs. rivets! Big Smile
    January 2006
Posted by SprueOne on Sunday, November 2, 2014 6:23 PM
Yeah, and it made sense until AP rounds were designed and deployed.
soviet draisine sprueone
Assembly instructions for the trucks and wheels
I started on the simple truck and wheels assemblies but wanted to make sure I glued the wheels to the axles at the correct width to line up with the fixed rails. So, I started the railroad bed assembly with the rails.
The rail parts have a base and crown. Look carefully
After cutting the parts off of the sprue, I sanded the gate tabs from the bottom first then inserted the rail into the tie bed base
Then it was easy for me to sand the top easily and evenly
YesIdea The kit design allowed me to just slide the rail part in from the side under each rail clamp
I found out that the correct width is to glue the wheels to the axles at by the truck box width. Easy. I'll do this after painting
One truck sitting on the rails. This sub-assembly is just dry fit right now
thanks for looking
    January 2006
Posted by SprueOne on Tuesday, November 4, 2014 9:40 PM
While building the trucks I decided to make an option to HO scale compatibility. This means installing trucks and wheels from one of my HO scale rolling stock cars to the Draisine
I have a track cleaner car that looked like it would fit perfectly
I traced the clearance of the Draisine trucks with a pencil so I know where to mount the bolts to secure the track cleaner chassis
All measurements and marks made then drilled to accommodate the modified fasteners. The nuts and washers provide the exact spacing clearance
IdeaYes assembly shows that the new modified Draisine Track Cleaner will work together with my other HO rolling stock
ok, now enough with the HO fun . . . back to business
thanks for looking
Tags: HO scale
    July 2004
Posted by wbill76 on Saturday, November 8, 2014 4:09 PM
That's pretty neat making it compatible with HO! Big Smile Nice progress on this one, got to love the detail for the scale.
    January 2006
Posted by SprueOne on Tuesday, November 11, 2014 9:32 AM
Thanks for the comment. The size and shape, I just had to do it.
Yes, this kit is very clean and has crisp detail
PVI
    May 2014
Posted by PVI on Thursday, November 13, 2014 1:47 AM
Now that is a cool kit!
    January 2006
Posted by SprueOne on Friday, November 14, 2014 7:35 PM
Hi, Thanks for checking in and your comment.
Yes, it is a very nice kit in regards to clean molding and crisp detail.
I haven't been posting progress lately because I've been working (distracted) on a bicycle project, my other other hobby Cool
    January 2006
Posted by SprueOne on Saturday, November 22, 2014 9:43 PM
The kit railroad bed was designed as a display base. I didn't like the end parts (A2) to taper down like a mound exhibit so I filled the ends with stock styrene sheet and putty to model flat 'infinity' ends. This looks more like a study display which I prefer the look of
    January 2006
Posted by SprueOne on Sunday, November 23, 2014 4:45 PM
The 2-part ballast bed were mated here (at the arrows). The ballast stones did not match so a careful carving and putty job brought it to a satisfactory look
Finishing up the railroad bed and rails assembly I want to share the detail of this kit:
little tiny rail joiner parts, nice!
a bicycle chain link next to this tiny turret.
This clean detail on the underside of the TC hatch will never be seen Huh?
All assembly done and ready for paint which I'll try to start today
thanks for loooooking . . .
    July 2004
Posted by wbill76 on Monday, November 24, 2014 2:49 PM
Nice modifications to the rail bed and details for sure. Keep it coming! Beer
    January 2006
Posted by SprueOne on Tuesday, November 25, 2014 10:48 PM
Thank you.
Base coat has been sprayed but no pics yet. Been working FT+OT and will be off on Thursday. Then I can post more progress pics.
    January 2006
Posted by SprueOne on Thursday, November 27, 2014 2:45 PM
Base color coat applied and working on details and weathering next
The wheel rims were first sprayed 'chrome' then after that dried, they were sprayed base color green through a quickly made mask
thanks for looking and Happy Thanksgiving
    January 2006
Posted by SprueOne on Sunday, November 30, 2014 4:11 PM
Finished the Soviet draisine, Krasnaja Zvezda, in 1/72 scale this morning.
Trucks assembled
Then . . .
. . . Convert to HO scale track cleaner for operational layout running options Wink Idea
Thanks for looking
    January 2013
Posted by jibber on Sunday, November 30, 2014 4:57 PM
Sprue thats a really cool build and I love the modifications. One thing I picked up from a train modelers site is that the ties could use a dark oil wash to highlight the grain and take some of the shine off. Keep that train stuff coming and thanks for showing it. Terry
    January 2006
Posted by SprueOne on Sunday, November 30, 2014 5:13 PM
yeah, that sheen is killin' me. Thanks for the tip!
    January 2013
Posted by jibber on Monday, December 1, 2014 7:37 AM
You bet. I really like your build Sprue, I wish Hobby Boss would get out more RR in 1/72.
    July 2004
Posted by wbill76 on Monday, December 1, 2014 5:35 PM
Very nice paint work! Looks neat hitched up to the other modern rig. Can you imagine that rolling down the rails through a small mid-west town or similar? Big Smile
    January 2006
Posted by SprueOne on Monday, December 1, 2014 9:03 PM
Terry - Thanks for the compliments and yes, I'd like to build more (military) railroad stuff in 1/72 after this nice little kit.
Bill - Thanks for the comment. Big Smile that would be wild, but I'd be reaching for my camera real quick Camera
    April 2006
Posted by waynec on Saturday, December 6, 2014 6:31 PM
jibber
ditto to both. and trumpeter needs a 1/35 boxcar. i saw a blurb trumpeter is coming out with a 1/35 soviet armored rail car
Soviet PL-37 Lt Artillery Armored Rail Car
http://www.elmcityhobbies.com/shop/index.php?main_page=popup_image&pID=4499
    April 2006
Posted by waynec on Saturday, December 6, 2014 6:36 PM
SprueOne
you could also try weathering powders or pastels to tone down the ties. if you want to do more RR stuff JIBBER and i have a GB starting in January (though both of us want to start it now)
    January 2006
Posted by SprueOne on Monday, December 8, 2014 7:35 PM
Sorry for the delay in reply. yes, I'm going to work in some washes with flat color bases and follow with dry pastels. Thanks for the tip.
Yes, I already responded to the RXR GB with interest Idea Yes
    April 2006
Posted by waynec on Tuesday, December 9, 2014 2:59 PM
SprueOne
we'd be happy to have you.
