What to use as rocks on a railroad build in 1:72?
    July 2008
Posted by castelnuovo on Monday, November 24, 2014 10:09 PM
I found this Autoblinda Ferroviaria by Italery. It was only 20 bucks, so what a heck, lets buy it. It has the railroad tracks but, the tracks put on a shelf looks as if something is missing. It needs a proper base, however simple. What can I use as those crushed rocks that are between the tracks. It is 1:72 scale.
Thanks....
    November 2014
Posted by STX440 on Monday, November 24, 2014 10:11 PM
Ballast is what you are looking for.There are several brands one of which is made by Woodland Scenics.
    September 2005
Posted by richs26 on Monday, November 24, 2014 10:34 PM
For ballast rock, try kitty litter which could be the right size.  If not try some HO railroad ballast as HO is 1/87 scale which could be close. Or some S scale which is 1/64 if you can find it.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    August 2007
Posted by DUSTER on Monday, November 24, 2014 10:49 PM
Go to your nearest model train shop and pick up some road bed gravel or even a piece of track with the bedding attached.
1/72 scale is not a railroad scale the closest is  1/76 which is  "OO" scale found in the UK. Closest in the U.S. is "HO" which is 1/87 scale.  But for "gravel " (or Ballast to the RR guys) you will be able to fudge the scale that much.
OR
If you want to save some $$. Use regular  clay cat litter - not the clumping kind, but the old fashioned clay stuff. I see small bags in the $1 store all the time. Glue it to a foam piece as a base for the track bed. Spray on some various color washes to break up the bland uniform cat litter color and  ya got it .
Post some pictures of your work, when you can, sounds real interesting.
Steve
    October 2004
Posted by ygmodeler4 on Monday, November 24, 2014 11:47 PM
Just be sure to hide it from the cat if you have one ;)
-Josiah
    July 2008
Posted by castelnuovo on Tuesday, November 25, 2014 9:55 PM
Thanks all for the tips. We have two cats so the kitty litter idea will be tried first. Will hide it from them Smile
    August 2010
Posted by Ghostrider114 on Tuesday, December 2, 2014 3:11 AM
DUSTER
The train guy at my LHS corrected me on this once, so I thought I'd pass it on.  Train scales actually refer to the gauge of the track, not the scale of the actual model train.  The scale of the trains varies from manufacturer to manufacturer, (although it's usually still roughly close to scale with the track gauge.)
    August 2007
Posted by DUSTER on Wednesday, December 3, 2014 5:39 PM
Ghostrider114
DUSTER
Thanks for the clarification.
This is why I build Air Plane kits.....where the scales are "always constant "(+ or -  a few  )
Steve
    April 2006
Posted by waynec on Tuesday, December 9, 2014 3:06 PM
DUSTER
Ghostrider114
DUSTER
and to add to the confusion, i have heard that dml 1/35 railcars have a track with of 1/35 BUT trumpeter is 1/35 with a 1/32 track width so it fits on US G scale. ballast comes in different RR scales as well as medium or fine within those scales so anything close works fine. also look in other ares. as mentioned kitty litter works. for 1/35 sand i use reptile terrarium sand from a pet store.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    September 2012
Posted by GMorrison on Tuesday, December 9, 2014 3:16 PM
For 1/72 I like aquarium gravel. It's really cheap.
Yeah, don't use anything attractive to critters.
Posted by CapnMac82 on Sunday, December 14, 2014 3:12 AM
Hmm, railroad gauge is measured from inside-to-inside of the rails.  In the US it's a nifty logical number like 4'-7 1/2" (0.o).  The UK is similar, but, some of the other European countries are not.  IIRC the Soviets, in particular, had a dissimilar gauge than the Germans, and this was for strategic reasons, so that rail cars from one side would have to stop at the border and have the contents trans-shipped.
G scale is not uniquely American, IIRC, as it's "Garden" scale, approximately 1:28 on a narrow gauge (either 1 meter or 3 foot gauge) track.
I gauge (either "I" as in Inca, or I as in Roman numeral 1) is described as being from 1/36 to 1/32 scale
Which is important a rail wheels are around 24-30" (60-75cm) in diameter.  So the 1:28 G gauge wheels would not be in scale for 1/35.  The rail profiles are going to be not quite right, too.
This is why some On3 (O gauge using HO gauge track as 3' gauge) modelers will hand lay O gauge track at HO width so as to not have problems with the wheel rims being deeper than the track height.
The rail guys think these things out, as having your rolling stock derail in a curve and wipe out the scenery makes for a bad day.
    April 2006
Posted by waynec on Sunday, December 14, 2014 1:04 PM
that made my head hurt. it's as bad as my ship club with their 3/16 scale and other odd ways to measure stuff.
Posted by CapnMac82 on Sunday, December 14, 2014 9:05 PM
All due apologies Wayne, not my intention at all.
"Our" side of things is used to having things be at _a_ scale.
The RC folks kind of bridge between "strict" scale adherence and operational needs.
The railroad people have two basic camps--those who mainly want to build, and those who mainly want to run.
    April 2006
Posted by waynec on Sunday, December 14, 2014 10:33 PM
CapnMac82
no apologies necessary. i forgot the smiley face after my head hurt statement. we have similar camps with artistic vs absolute realism.
    January 2014
Posted by zstripe on Friday, December 19, 2014 4:24 AM
Woodland Scenic's Ballast on My HO scale layout. It would be fine for 1/72, have used it on Military Dioramas:
Take Care! Big Smile
Frank
