How to brush paint Testors small enamels to look it was airbrushed ??
    March 2007
Posted by KAYSEE88 on Friday, February 27, 2015 12:41 AM
i'm doing soon a 3-color camo on a 1/35 vehicle.  This is my first time using a paint brush because my airbrush broke and I need to present the model before my new one comes in the mail.
Anyone with proven tips on how to use a brush with enamels to get that sprayed on look? Note:  I only have a quarter-inch flat brush and a small angled one at hand.
Thank you in advance for the help!!
    January 2007
Posted by the doog on Friday, February 27, 2015 6:09 AM
Two bushes? Man, that's Spartan modeling! lol.
Generally, the best way to brush-paint is to thin the paint and apply two or three thin coats, rather than to glob on paint in one thick coat. And a wide, thick brush of GOOD QUALITY is best for this.
However, I would ask you HOW did your airbrush "break"? Most problems with "broken" airbrushes can be solved with a thorough cleaningl. You might want to investigate that before you waste the time and effort doing an impossible task.
    January 2015
Posted by M. Brindos on Friday, February 27, 2015 11:11 AM
Doog is right. Keep your paint thin and do several cotes. Use your small angled brush for dry brushing the color transitions to get a feathered edge between colors and go slowly. If you rush it, it will not look like anything but a bad brush job.
"Softly, softly, catchy monkey"
- Mike Brindos "Lost Boy"
    February 2015
Posted by Sgt Rock Fury on Thursday, March 5, 2015 7:28 AM
You'd be better off using a rattle-can and masking tape. To get a feathered edge with a spray can, leave the edge off the surface by folding one edge of the tape over (about an eighth-inch works)... If it's a "mottled" effect you're after, then take a round brush, cut the bristles back to about an eighth-inch in length, and use a stabbing/stippling motion to apply the paint.
Dip the brush into the paint left on the inside of the LID and then stab a piece of paper with it until it's similar to the amount used fir dry-brushing...
You can also use that technique to go th length of the color demarcation line... It won't look sprayed, but it's as close as you're gonna get without spraying...
