Tank highlights and depth
    March 2010
Posted by Bocks Suv on Monday, February 8, 2016 9:48 AM
Building a 1/35 Merkava and just ABed it a typical dark military green, but now it looks flat and kinda boring. I'm tempted to highlight the raised parts, fiddly sections and seams with a very thin black paint, but wondering if that might get lost too and instead should I go with a lighter highlight color? Any tips would be appreciated.
Posted by Gamera on Monday, February 8, 2016 11:23 AM
Isn't what you doing called a pin wash? You might look up 'color modulation' too. I'm no expert but there's several around here who are.
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Monday, February 8, 2016 12:04 PM
OK..........
                   http://t1.gstatic.com/images?q=tbn:ANd9GcSHXM9jU8Hp6Xm_BEBsXtkV-akfzvTjLdGVeWlv0uEgDy1bELtWKbhJ
                 https://www.root86.com/public/style_emoticons/default/decke.gif
Here's all 'ya need.
(well that isn't going to work, I just LOVE http://www.myemoticons.com/emoticons/images/msn/moods/being_sick.gif this new forum format)
Alright, copy and paste the address below.
http://cs.finescale.com/fsm/modeling_subjects/f/3/t/84424.aspx#824087
Sherman-Jumbo-1945
"I was so much older then, I'm younger than that now"
Posted by Bish on Monday, February 8, 2016 12:50 PM
If you wnat to highlight the raised parts, try a dry brush with a lighter shade of your base coat followed by pin washing.
    April 2004
Posted by crockett on Monday, February 8, 2016 3:06 PM
Bocks Suv
Two techniques here, you will need an airbrush for implementation:
First is preshading to realize depth and contrast on OD green:
First, fill all seams and create welds with putty:
Next, an overall coat of dark gray / black:
Overspray with OD green and some polyscale flat mixed in:
Finally, fuel / oil stains applied with extremely thin gray / black, and, a lighter shade of OD across the top of the model (as the sun would hit it)
Finished product, with accents ..brushed on MiG pigments:
The second method involves post shading as on this IDF M60A1:
Base color (IDF sand olive is applied....then, a very thin dark gray / green is applied to all contrast points on the tank:
