Tamiya M10 Tank Destroyer - Mid Production #35350 - FINISHED
    October, 2010
Posted by AlanF on Saturday, February 11, 2017 5:51 PM
A lot has been going on since I started this about a month ago so I don’t have many progress pictures, but here is what I have so far.
While the suspension is much simpler than the Asuka Sherman build I did earlier, it is still nicely detailed and goes together quickly.
The bottom of the lower hull has some nice detail.
While the top does have some sink marks, it really isn’t worth cleaning them up since they won’t be seen.
The top of the hull looks pretty nice as well.
The kit comes with 3 crew members.  I’ve NEVER painted a figure before.  All in all they didn’t come out bad.  I tried using what was called “Magic Wash” which is simply Future with a bit of acrylic paint, in this case black. By applying the wash the Future tends to force it into all the little creases. Not bad.  The do need a bit of cleanup, some highlights applied and, of course, a flat coat. I’m not sure I’m going to put on the goggles. There are no straps for them, so I think they would look weird just “attached” to the helmet. Any suggestions???
The lower hull and turret have been primed with black Stynylrez after the inside of the turret was painted and detailed.
Finally, we have a coat of good ole Olive Drab.
Next up is a gloss coat, decals, crew placement and weathering.
-Alan
    July, 2004
Posted by stikpusher on Saturday, February 11, 2017 7:07 PM
Looking good so far. Your wash on the figures certainly helps define their detail more.
I'm not 100% certain, but I believe that the floorboards visible beneath the open turret top should be Olive Drab and not white...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October, 2010
Posted by AlanF on Saturday, February 11, 2017 7:55 PM
stikpusher
Thanks.  Hummmm... the instructions do imply a white floor but instructions have gotten colors wrong before. Does anyone know?
    July, 2003
  • From: NEVER USE PHOTO BUCKET - IT'S A THREAD WRECKER.
Posted by disastermaster on Saturday, February 11, 2017 8:47 PM
http://i485.photobucket.com/albums/rr217/darkside_999/victory.gif~originalYep,
Olive Drab......
 2 black + 2 yellow + 1 Red
                http://i20.photobucket.com/albums/b232/gluetank/Animated/Disastermastermotion-3.gif
http://i20.photobucket.com/albums/b232/gluetank/Sherman%20M4A3E2%20Assault%20Tank/th_M4A3E2Icon.jpg  http://cs.finescale.com/fsm/modeling_subjects/f/3/t/134935.aspx?page=11
    November, 2009
Posted by Gamera on Sunday, February 12, 2017 6:50 PM
As I understand anything that can be seen from the air is painted olive drab. That would include the hull floor right under the turret. I've been painting the raised area od and the driver's area white. I think that's right though you should be able to find some photos online to make sure.
"Fairy tales do not tell children the dragons exist. Children already know that dragons exist. Fairy tales tell children that dragons can be killed." -G.K. Chesterton
    October, 2010
Posted by AlanF on Sunday, February 12, 2017 7:00 PM
Thanks for all the help with regard to the turret floor.
Floor color fixed (I hope.):
It still needs to be weathered and dirtied up a bit when it dries.  I also took the opportunity to fade some areas on the tank hull. Next comes the gloss coat and some decals before the M10 gets that lived in look and used look.
    November, 2009
Posted by Gamera on Sunday, February 12, 2017 7:03 PM
Hey Alan that looks really good! Yes
Really like the fading on the hull.
If you want you can drybrush the hull floor with a little metallic paint to represent where the crew's boots scuffed up the od paint. And add some mud in there too if you want.
    April, 2012
Posted by Reserve on Sunday, February 12, 2017 10:15 PM
Nice stuff here, and the guys are right about the floor color which you've corrected. When I put goggles on my figures I make the straps out of plain paper...easier to form and glue down plus you can soak the paper in the correct color paint before cutting and applying
Regards,
Mark
    December, 2002
Posted by Bish on Monday, February 13, 2017 10:37 AM
Looking good. I know nothing about US armour, but OD for the floor makes sense.
''I am a Norfolk man, and i glory in being so''
On the bench: Tamiya 1/72nd Bf 109E-3
    October, 2010
Posted by AlanF on Thursday, February 16, 2017 6:18 PM
Well, the M10 has been gloss coated and decals applied. You can also see that the turret floor has been weathered.
I must say the decals weren't the greatest and one of the stars is kind of messed up so I will have to work that into the weathering. For some reason the decals wouldn't stay put and almost instantly turned to mush with MicroSol. My mistake in trying to reposition the slid decal after MicroSol was applied. I've never had that issue before - live and learn I guess. The decals did settle down very nicely after MicroSol application, so in that way, they weren't bad.
Markings are for the 601st Tank Destroyer Battalion, 3rd Infantry Division, Southern France, August 1944.
Now onto the final assembly of the tracks and weathering.
    October, 2010
Posted by AlanF on Thursday, February 16, 2017 6:19 PM
Reserve
I might have to try that Mark.  Thanks for the suggestion.
    September, 2005
Posted by warshipguy on Friday, February 17, 2017 7:38 AM
I am new to armor modeling, so I am learning something new with each thread I've read.  I am most impressed with your M-10 so far!
Bill Morrison
    November, 2009
Posted by Gamera on Friday, February 17, 2017 10:44 AM
Looking really good! Yes
    October, 2010
Posted by AlanF on Friday, February 17, 2017 12:58 PM
warshipguy
Bill Morrison
So am I Bill.  I usually build 1:48 planes but I'm on an armor kick and I really like it. Armor is really a different beast, but the guys and gals here are awesome and they KNOW things!  I've learned a lot. Hopefully I'm improving on every build.
Alan
    October, 2010
Posted by AlanF on Thursday, February 23, 2017 12:52 PM
Finished!
M10 Tank Destroyer - 601st Tank Destroyer Dattalio, 3rd Infantry Division, Southern France, August 1944.
This was my first experience with figures and overall, I'm pretty happy with how they came out.  The only real issue is one of the stars on the turret got mangled - battle damage is my story and I'm stickin to it.  Maybe someday I'll replace it.  I'm really enjoying building armor.
    November, 2009
Posted by Gamera on Thursday, February 23, 2017 3:13 PM
Hey Alan you should be proud, really nice work there! Great job on the TD and the decals look fine. You even got the front one perfectly around the bolts- something I've had problems with before.
The figures look good, my first ones looked like rejects from 'White Zombie'...
    May, 2015
Posted by Griffin25 on Thursday, February 23, 2017 4:53 PM
Looks really good to me. That's a neat piece of armor. It's one of your first tries at armor and figures? Come on man. Yes
Rob
    July, 2004
Posted by stikpusher on Thursday, February 23, 2017 4:58 PM
Yes Very nice finish! Welcome to the "dark side" of armor. You can certainly be proud of this build. As you will likely soon learn with armor builds, mishaps in the project can often be hidden with stowage or weathering (mud!!!)....
       - Plankton
LSM
    September, 2016
Posted by ManCityFan on Thursday, February 23, 2017 5:01 PM
Nice job! I echo the comment on that front decal. That could not have been easy. So, you are going to do more armor, right?
Dwayne or Dman or just D.  All comments are welcome on my builds.
    October, 2010
Posted by AlanF on Thursday, February 23, 2017 5:43 PM
Griffin25
Rob
Thanks Rob. It's my 3rd tank and first time with figures. The Dark Side has gotten hold and won't let go.
Alan
    October, 2010
Posted by AlanF on Thursday, February 23, 2017 5:44 PM
ManCityFan
Absolutely. Next up is the Bronco M-24 Chaffe (N. Europe 1944-45).  I'm getting brave.  No rubber tracks in that kit.
-Alan
    October, 2010
Posted by AlanF on Thursday, February 23, 2017 5:45 PM
Gamera
Thank you.  I appreciate it.
    March, 2003
Posted by Tojo72 on Friday, February 24, 2017 6:23 AM
Nice job on this one
    December, 2002
Posted by Bish on Friday, February 24, 2017 6:26 AM
Very nicely done. Great finish and i do like those figures.
    September, 2005
Posted by warshipguy on Friday, February 24, 2017 7:35 AM
Excellent job on the figures!  I am now inspired to try them.
Bill
MrT
    December, 2010
Posted by MrT on Friday, February 24, 2017 8:40 AM
Smile
Very good work Alan!
    April, 2006
Posted by jgeratic on Friday, February 24, 2017 11:36 AM
Congrats Alan, extremely well done! Yes
regards,
Jack
    January, 2007
Posted by the doog on Tuesday, March 28, 2017 4:41 PM
Terrific paint job and nice styling on the weathering. A great looking build!
My FOTKI model gallery with most of my best models can be found HERE
My real name is "Karl" Smile
SUBSCRIBER-ONLY CONTENT
