S35 photo analysis
    July 2004
S35 photo analysis
Posted by stikpusher on Friday, July 31, 2020 2:41 PM
I am currently building Heller’s old Somua S35 kitand almost at the stage of painting. The kit comes with markings for this particular tank, of which I was fortunate to find an actual photo. The way I see this photo, it appears that the hull has the horizontal style multi color scheme, while the turret looks to have the older vertical style multi color scheme.
What do you guys think?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Bish on Friday, July 31, 2020 2:54 PM
I can deffinetly see the vertical demarcation on the turret, just behind the 9. But it also looks like a vertical one just to the left of the drivers hatch, which tehn looks like it goes horizonal though i am not sure if that the light due to a change in angle.
''I am a Norfolk man and i glory in being so''
On the bench: Revell 1/72nd Type VIIc U-Boat
    July 2004
Posted by stikpusher on Friday, July 31, 2020 3:01 PM
Exactly! That’s what throwing me off as well. The front of the hull and the side stowage bins show the horizontal pattern. But that area to the side of the drivers hatch does not quite jive. And the turret does not at all.
       - Plankton
LSM
Posted by Bish on Friday, July 31, 2020 3:12 PM
I am not familiar with French armour or its colour schemes. Was it usually the case of the scheme being one or the other?
Also, there loks to be a 'blob' of darker colour under the drivers hatch, and it looks to be a similar shade to the patch to the left of the hatch which seems darker than the other 2 colours.
Posted by Bish on Friday, July 31, 2020 3:17 PM
I just found this image of a German S35. Like yours it has the drivers hatch open. Also like yours, it has a dark patch to the left of the hatch and another underneath it. It looks to be the shadow of the hatch.
    November 2008
Posted by plasticjunkie on Friday, July 31, 2020 3:23 PM
To me the turret demarcation line behind the 9 looks like a shadow? Here is a Somua with the 93 number that may be the same one.
https://www.youtube.com/watch?v=t7toN1CTMFw
Just noticed it has the 93 on the other side of the turret.
 GIFMaker.org_jy_Ayj_O
    July 2004
Posted by stikpusher on Friday, July 31, 2020 4:36 PM
PJ, the model looks to be painted as the one at Aberdeen Proving Grounds is or was. I have seen photos of it in a monotone scheme and in the horizontal style camo scheme.
Bish, I am not well read on French camo schemes either. It just appears that there were several iterations on the S35 during the production run.
One thing that I'm noticing from looking at the photo is that both the roadway and the tank look to be wet. Rain? If so, that will make the surfaces more reflective of light depending upon the angle. The turret is similar in shape to that of the Mickey Mouse hatch T-34 turrets, so multi flat angles.
Looking at the turret I can also see some evidence of color demarcation on the main gun mantle, and across the top of the cupola. Conflicting!!!
       - Plankton
LSM
    December 2012
Posted by Ixion on Friday, July 31, 2020 5:46 PM
Don't know if this is the same vehicle, drawn from the other side?
Unit insignia appears to be the same.
    July 2004
Posted by stikpusher on Saturday, August 1, 2020 3:32 PM
Yes, that looks to be the same vehicle, drawn from the opposite side.
       - Plankton
LSM
    June 2014
Posted by BrandonK on Sunday, August 2, 2020 10:59 AM
Looking at the shape of the vehicle and the angles it has, where it has them, IMO what you are seeing is highlights from lighting angles not different colors. All the edges of the lighter shades align with those of the shape of the tank. So, unless they painted it along those angles, it's most likely the light making it look that way. IMPO
BK
On the bench: Alot !
On Deck: Alot more !
