Centurion IDF Shot build
Posted by Gamera on Thursday, April 1, 2021 8:49 AM
Somehow I missed your last couple of posts. Nice work, I really like the look of the faded paint of the upper surfaces.
    November 2020
Posted by Also known as Rob on Thursday, April 1, 2021 2:30 PM
Gamera
Thank you. Having a decent airbrush now, is make doing things like that a lot easier.
    November 2020
Posted by Also known as Rob on Sunday, April 11, 2021 2:08 PM
I've now had a few days free to apply some weathering. I decided to weather the hull first so that the wheels could be weathered before the skirts went on. In hindsight, I probably should have kept it to just the wheels and running gear, but I got carried away and did the whole hull.
I used Flory Models washes for the first time and I like them a lot. I like treatments where you apply a covering and then removed it until you have the desired result. It makes it a lot easier to avoid over doing it.
Tank and Flory Models wash
As you can see from the above picture, the initial application looks like too much.
The next step is to remove the wash with a damp cloth or cotton bud. With the result that the weathering is toned down a lot.
I really like the grubby effect that resulted.
I think I made a mistake applying white wash on it's own.
Although rubbing it back made it a more suble effect to me it looked a little unnatural. So I removed almost all of it. After the one application I used it in combination with the sand wash to get lighter brown washes, and that worked well.
Once I was happy with the wash effect, I applied Vallejo Desert Sand Earth Texture to the wheels and running gear. To blend in the colour a little, I then reapplied some wash over the sand.
The image below shows how the weathered hull compared to the still unweathered turret
The next step was to glue the side skirts to the hull.
There was a little touching up to do (around the edges of the skirt mainly) and the end of the gun need to be black.
With that done, it leaves the weathering of turret and side skirts to do.
Posted by Gamera on Thursday, April 15, 2021 11:43 AM
I love that! Looks fantastic!!! Heart
    November 2020
Posted by Also known as Rob on Friday, April 16, 2021 11:37 AM
Thank you Gamera Smile
The side skirts and turret are done now. I needed to give the whole thing one last look over, then a couple of coats of varnish. After that I need to start building the diorama!
Here's a quick snap of the Centrurion with a couple of my earlier lockdown models.
    May 2020
Posted by Hutch6390 on Friday, April 16, 2021 2:29 PM
Lovely job, mate - I really like that weatheringSmile
Vell, Zaphod's just zis guy, you know?
TakkaTakkaTakkaTakkaTakkaTakka
    November 2020
Posted by Also known as Rob on Saturday, April 17, 2021 3:31 AM
Hutch6390
Thank you
    November 2020
Posted by Also known as Rob on Sunday, April 25, 2021 4:03 PM
A little more work done this weekend.
I sealed the tank with a matt varnish. I usually use satin varnish for the top coat, but I'm hoping the matt will give a dry look.
So time to start work on the base. I cut a piece off an old shelf that I had free.
Cutting the base from wood offcut
I then took a sheet of cork and ripped a couple of holes and a tear in it. Then marked the placement of the holes on the wooden base. I then chiselled out holes in the base to line up with the cork sheet. Then the cork sheet was glued to the wood base with wood glue.
Cork sheet glued to base
Once the glue had dried, I applied a coat of AK Terrains Asphalt to the cork. The first coat gave good coverage but I struggled to get a flat surfice. The asphalt kept sticking to whatever I tried to smooth it with. In the end the best I could get was using a damp cloth and then tapping it down with my fingers, but I wasn't happy with the result.
So yesterday I applied another coat. I'd watched a couple of videos on using the asphalt, and realised I needed to use water with the sculpting tools I was using. With the tools dipped in water each time they were used, I was able to get the flat surface I was after.
This morning I masked off some line marking and painted those in.
Masking road markings
That's it for this weekend. The next job will be to add some sand!
For now I'll have to amuse myself deciding on the exact placement of the tank on the base
Posted by Gamera on Sunday, April 25, 2021 6:29 PM
Rob: The Centurion is coming along very nicely! I never knew that the tank was that much bigger than a Churchill though I suppose I shouldn't be surprised. And love the base, looks great to me! Yes
    November 2020
Posted by Also known as Rob on Sunday, May 23, 2021 9:17 AM
After a lot of distractions and a few retries, I think I'm finally happy with my desert road diorama base.
I think it will suit the Centurion well. This isn't quite where I want to put it, but it shows how the tank looks on the base.
 So just the figures to make and paint.
    November 2008
Posted by mrmike on Sunday, May 23, 2021 11:04 AM
That looks fantastic! The weathering and the base reflect the attention you've paid to them. What did you use for the "terrain"?
    November 2020
Posted by Also known as Rob on Sunday, May 23, 2021 12:53 PM
Thanks Mike.
I first put a layer of fine sand over the area I wanted the dune to be sited. The sand was purchased from a local craft store. I fixed it with watered down PVA glue. In the final view, this appears as the debris at the foot of the front face of the dune.
The pot holes were filled with the craft sand, fixed with watered down PVA.
The sand dune was sculpted from DAS air drying clay. I covered the area it would cover with a layer of thinned PVA glue and then lay a couple of blocks of clay in the general shape, and then sculpted it into shape. It took me a couple of attempts. The key thing I found was to keep my sculpting tools wet. I needed to do that to get a nicely flat top surface. Then I used a small round ended tool to sculpt the linear erosion lines down the front face.
Once I'd got the shape as I wanted it, I left it a couple of days to dry. Then I covered it with Vallejo Desert Sand Acrylic Texture. I laid it smoothly over the back of the dune (again, using a wet scuplting tool was essential), but used a brush in linear strocks down the front face to enhance the erosion lines.
I then knocked that colour back a little with Flory Models SAND weathering wash. I found that by rubbing the back of the dune in a linear direction (perpendicular to the erosion surface) with a dry rag, the wash was removed in a way that left some nice variation in colours and gave what I think is a realistic streaked appearance.
I also applied some Flory Models Light weathering wash, but stuggled to get the effect I wanted so most of that got wiped off or over painted.
I added some more sand after the dune was in place which needed some more glue to fix it. This left a residue. To remove this and return the tarmac to nearer it first colour, I spayed a light coating of black paint over the road surface (after masking the road marking lines). This covered some of the sand at the foot of the dune. So once that was done I hand painted the sand with a variety of sand browns mixed with a little yellow. I then applied some more of the Flory sand weathering wash.
Once everything was dry and I was happy with how it looked, I gave the whole lot a good coating of matt varnish.
Posted by Gamera on Monday, May 24, 2021 7:51 PM
I love the base Rob, and thanks for walking us though it!
