Vallejo Panzer Aces "Track Primer"
    June 2006
Posted by Grem56 on Friday, May 15, 2009 11:24 AM
What is this colour supposed to be? A dusty base colour for tracks or a primer colour for tracks (red would seem more appropriate). Confused [%-)]
Julian
illegal immigrants have always been a problem in the United States. Ask any Indian.....................
Italeri S-100: http://cs.finescale.com/FSMCS/forums/t/112607.aspx?PageIndex=1
Isu-152: http://cs.finescale.com/FSMCS/forums/t/116521.aspx?PageIndex=1
    June 2008
Posted by Hans von Hammer on Friday, May 15, 2009 11:46 AM
Dunno...That is, unless it's a primer for making the paint stick better to vinyl tracks... But for me, the Base Color for tracks is Steel and if they have pads, they get painted Testor's Rubber.  After that, I weather them.. I like to have stuff painted factory -fresh then weather it,  same as in the real world...
I've just bought my very first Vallejo paint set (face-painting colors) but haven't tried them yet... I've been using regular enamel, oils, & acrylics for so long, I'm not sure I can learn a new way, lol...
    June 2006
Posted by Grem56 on Friday, May 15, 2009 11:57 AM
No, it's a paint colour and not a real primer. I started using Vallejo around Christmas and the more I buy and use the more I like them. My 2 cents [2c]
    January 2009
Posted by schwere panzer on Friday, May 15, 2009 12:53 PM
    for tracks I start with red automotive primer then I hit them lightly with green or mustard depending color tank is.  After that I dry brush with steel  then a dull silver in areas of steel to steel contact.
    August 2005
Posted by Phil_H on Friday, May 15, 2009 6:00 PM
Julian
http://www.acrylicosvallejo.com/Extras/documentacion/FolletoPanzerAces.pdf
#70.304 - It appears to be an earthy brown colour.
    August 2005
Posted by Phil_H on Saturday, May 16, 2009 2:18 AM
HVH: The first time you try them, you'll probably be thinking "What the ***? Why do people rave about this stuff? It looks like crud" and may be tempted to trash the lot.
IF you go straight from the bottle, more than likely it will look like crud. It may skin on your brush and not apply cleanly. However, once you thin it (start at 1:1 with distilled/demineralised water and adjust as required) it will start to make sense. The secret with Vallejos is to not try to achieve one coat coverage - start with a nice flat primed base and build it up in layers. The tutorial at the bottom of this page may be helpful: http://www.acrylicosvallejo.com/asp-inc/_modelis_princip.asp?p1=ing&p2=modelcolor&p3=
    July 2003
Posted by madmike on Saturday, May 16, 2009 6:16 AM
I drybrush Vallejo Chocolate brown over a black primer base for tracks. Then appropriate polished steel dry brushing and Mig pigments to finish.
Vallejo is superb paint once you get the hang of it, no brushmarks whatsoever.
Cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    June 2008
Posted by Hans von Hammer on Saturday, May 16, 2009 7:59 AM
Tausand Dank, Phil... I painted a face with them lastnight and that's exactly what I was thinkng, lol... Skinned-over, brush marks, blending? HAH!
Thanks man... May have saved a 36-dollar investment, lol...
    August 2005
Posted by Phil_H on Saturday, May 16, 2009 9:01 AM
You're welcome HVH. Smile [:)]
The first time I tried using them, I was trying to do some worn edges/scratches. Tip of a 3/0 brush into unthinned dark grey - the brush was "skinned" by the time I tried to apply it and I'm thinking "what am I going to do with this stuff?".
You do need to think a little differently. You probably won't be able to edge-blend the way you're used to with enamels. Think in terms of water-colours - layering, rather than blending. The best analogy I can think of is controlled translucent washes. Don't flood the brush, apply in thin layers to build the required depth. Applied thinly, it will dry in a few minutes - you can "layer" in about 10 minutes (or less) without it lifting the underlying paint. Thats about all I can suggest for now - I'm still coming to grips with mine.
    May 2005
Posted by hughes2682 on Saturday, May 16, 2009 11:44 AM
HvH,
Here is a link to Vallejo's web site. Cut and paste it. I could not get it to hyperlink, sorry. Once there click model color, and at the bottom is a tutorial on using the paints. They are rather nice to work with once you learn how they behave. I know, for I used to work exclusively with enamels and oils.
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    June 2006
Posted by Grem56 on Saturday, May 16, 2009 12:20 PM
Hi Gentlemen,
thanks for the input and I think MM answered my question. Track primer is evidently a base colour to apply to the tracks before weathering. Will try it on my E-100 build. Once you get used to these paints you will love them.
Julian
    June 2008
Posted by Hans von Hammer on Saturday, May 16, 2009 3:58 PM
Thanks for the link, Hughes... That's the ticket.
    May 2005
Posted by hughes2682 on Saturday, May 16, 2009 9:09 PM
HvH- You are most welcome. I've gleaned much good info from you on this site. It is nice to pay a bit of it back. The biggest tip that helped me, I saw listed earlier in this thread. Layer the colors. Especially with the base coat. These paints really shine when you learn highlighting, shadowing, tinting. Good luck and enjoy
Thank you gentlemen for the info on the track primer. I picked up the same Panzer Aces set. Saw that color and thought ??????
Cheers
Dave
    July 2005
Posted by Barruel on Sunday, May 17, 2009 1:20 PM
Hi
"Track primer" is a brownish grey that can be easily achieved with a mixture of 50% German Grey with 50% Flat Earth (using Tamiya references, as an example), if you do not have Vallejo at hand.
