It has been a while. Let me get caught up. Lots of casting and scratch work. As you saw in my last update I was casting projectiles powder cans and other needed items. Also made custom decals for the ammunition crates, powder cans and projectiles.
Sooo, first looking at the howitzer, the ramming staff is a .040 wood dowel cut 1 inch long and a punched disc from .020 styrene at .160 diameter. The swab is also .040 wood dowel 1 inch long. The swab is a ball of airplane tissue wrapped in the end. The swab is weathered with Tamiya Smoke. The end of the ramming staff is Alclad Steel.
The pail is a Tamiya accessory kit and painted Alclad Steel. Inside the pail is half full using tinted clear furniture urethane which gives the clear oily water effect in the pail
The lanyard is a scale 18” lanyard using shipbuilders string and small section of .040 styrene rod shaped for the end and 26 gauge SS wire used to create the lanyard end and hook
Next is the powder drum painted black and red and “partially buried”. Inside the drum are 5 powder increments that came with the kit as excess powder charges. To the left is a scale 2 meter aiming stake made with styrene rod and painted red and white, scratches with Alclad steel and aged with a mix of steel and rust pigment.
Next I made the walls for the ammunition enclosure using 1/32 inch plywood walls and the beams are .1 inch basswood. After making the back and side walls, here painted with black for some shading prior to painting using Marine Green.
Next the walls were assembled. The roof supports of the 105mm crates, with custom decals. The shorter powder cans are for green bag charges and the taller for white bag charges. All the cans have a custom made decal. In the second bay of the storage shed is crates for fuses with custom made decals. The roof is made from resin planks covered with air-dry clay sand bags. The planks are painted to match the walls and the sand bags are painted Tamiya Drab Green.
The section chest is from the resin parts box, the oil can from a Tamiya accessory set with a custom decal for “bore cleaner”
Next up the projectile, scratch colimeter, final assembly and weathering. Trying to finish up for Armorcon at the end of the month.
As always if you have any comments, please feel free to drop in.
Rounds Complete!!
