Metal circle template?
    December 2011
Posted by Chrisk-k on Friday, September 6, 2013 2:23 PM
I use a plastic circle template for painting the wheels. A problem is it's impossible to clean it after many painting sessions because a solvent eats it. Has anyone seen a metal circle template? I cannot seem to find one.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    September 2012
Posted by GMorrison on Friday, September 6, 2013 2:41 PM
I have something fairly similar to this:
http://www.tnartsupply.com/browse.cfm/triangle-8-30-60-aluminum-5271-/4,16436.html
Its a little unwieldy but better than plastic.
    July 2012
Posted by Hasenpfeffer on Friday, September 6, 2013 2:56 PM
Check these out. I'm sure you could find them cheaper if you look around, but this gives you an idea of what is available.
http://www.am-works.com/store/armor-painting-stencils-c-2_12_18.html
    June 2006
Posted by ps1scw on Friday, September 6, 2013 4:22 PM
Eduard makes great masks for airplane canopy's do they make for road wheels?
    December 2006
Posted by Jester75 on Friday, September 6, 2013 4:44 PM
Cant you clean them off with an ammonia soaked paper towel? Thats what I use and there has been no damage so far.
Eric
    March 2010
Posted by Nathan T on Friday, September 6, 2013 5:42 PM
A metal scribing template with circles is what you need. Available at sprue bros.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, September 7, 2013 12:05 AM
 Metal can get bent and that can cause irregularities in the circular pattern if over-spray gets under any indented or not quite flat edge.
 Save your money and keep it simple.
 I put a piece of wide masking tape on the paint-side of the plastic template (just the hole you're going to use) and simply cut out the center with a fairly "SHARP" scalpel - it's quite easy.
 There's no need to place it on a flat surface. Hold the taped template up in one hand and cut the circle out from the non-stick side with the other. When you're finished painting; just pull off the tape - no cleanup.
http://yotesgurl.files.wordpress.com/2010/04/caveman-caveman-cave-dweller-prehistoric-smiley-emoticon-000204-large.gif I've used the same plastic template for over twenty years now and it still looks http://emoticoner.com/files/emoticons/smileys/baby3-smiley.gif?1292867551 brand new.
       Now, where's that "Post" button?
                  Ah-HA, here it is.........  http://marketlive.in/images/like/post-button.jpg
 https://i.imgur.com/LjRRaV1.png
    August 2005
Posted by Phil_H on Saturday, September 7, 2013 11:10 AM
I make my own disposable circle masks using scrap plastic packaging, into which I cut a pilot hole and enlarge using a tapered reaming tool.
Posted by Tojo72 on Saturday, September 7, 2013 2:06 PM
I have been using and cleaning my plastic one for years,no problems.
    September 2010
Posted by mikeymize on Saturday, September 7, 2013 11:28 PM
ps1scw
Yes they do. Many options with those as well as the ideas given out thus far. Sometimes I find that there aren't Eduard masks for the particular model brand I'm working on but usually I've found at most I can modify them with a bit of Tamiya tape and the results are quite satisfactory. I really like the spinner masks they make for Luftwaffe "spiral schnauze" ; the corkscrew pattern many late model planes had. That really makes those so much easier!
"Time you enjoy wasting is not wasted time".
