Tamiya Churchill Build
    September, 2013
Posted by Marcus McBean on Sunday, July 30, 2017 4:43 PM
Started this build last month and this is where I am at with it.  I built a set of Friulmodel tracks #ATL-60 and had a question.  First off here are some photos (moved from photobucket to Flickr).
I won't bore you with the rest of the build photos.
About the Friilmodel tracks for the Churchill.  Are they mirrored tracks or is one left side and the other right side?  If I turn the set the same direction as the other track run the pins I assemble the tracks with are on the outside and the cast pin molded on the track is on the inside against the tank side.  I want to have the molded pin facing the outside for both tracks,  but the way they assmeble is impossible to have both molded pins facing outside or have I made a stupid mistake when assembling them?  The tracks are Friulmodel #ATL-60.
Marcus
    December, 2002
Posted by Bish on Monday, July 31, 2017 5:23 AM
Nice start on that.
Fruil usually indicates when the set has left and right tracks. I checked there website and it doesn't say anything for the Churchill tracks. Unfortunatly with those type of tracks it means you have to have one side with the end of the wire on the outside. But once cut and painted you really can't notice.
''I am a Norfolk man, and i glory in being so''
On the bench: AFV Club 1/35th Sd.Kfz 251/4 AusfC
    November, 2009
Posted by Gamera on Monday, July 31, 2017 7:23 AM
She looks good to me, looks like you did a little colour modulation there?
Sorry no idea about the Friuls though.
"Fairy tales do not tell children the dragons exist. Children already know that dragons exist. Fairy tales tell children that dragons can be killed." -G.K. Chesterton
    September, 2013
Posted by Marcus McBean on Monday, July 31, 2017 10:03 AM
Gamera
Gamera,
Yes the first time I tried this on a tank.  I primed it with black primer and then added white primer in the center of all of open areas so the paint would be darker on the outside and lighter in the center.
I think it came out good but I believe I could do better with more practice.
Marcus
    September, 2012
Posted by GMorrison on Monday, July 31, 2017 10:14 AM
Could a Matilda be far behind?
That's a classic old kit. I never could get it to go together right, but that was years ago.
I built a Tamiya T55 (Israeli Tiran 5) using Friuls. Same thing on the pins. I tried every which way to figure what I was doing wrong. But as stated, once trimmed and painted they look just fine to me.
And in the case of this monster, can't hardly see most of the track anyhow.
Cool model.
    September, 2013
Posted by Marcus McBean on Monday, July 31, 2017 2:16 PM
I put the tracks on with one reversed so the molded pins are on the outside.  If anyone asks I will just say the crew was in hurry and just threw them on.  Will post pictures later.
    January, 2006
Posted by SprueOne on Tuesday, August 01, 2017 9:19 PM
Looks good from here. Nobody will notice the track pins but will notice if one side is flipped around and different from the other side.
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell
    September, 2013
Posted by Marcus McBean on Friday, August 04, 2017 10:07 PM
Made more progress this week.  Assembly is done and now I am just doing the painting of the tools and such.
Started painting the crew gear and supplies.  Once that is done will add them to the tank and clear coat in prep for decals.
Marcus
    December, 2002
Posted by Bish on Saturday, August 05, 2017 12:53 PM
She is looking good. Not a fan of modulation myself, but your doinjg a good job of it.
    September, 2013
Posted by Marcus McBean on Monday, August 14, 2017 6:24 PM
She is ready for clear coat so I can put the decals on.
Sorry about the focus on some of these shots, I am still learning to use this cameral.
That's all for now.  Will post when I have the decals and weathering done.
    November, 2009
Posted by Gamera on Tuesday, August 15, 2017 7:33 AM
She's coming together great and really nice work there on the storage. Yes
    March, 2003
Posted by Tojo72 on Tuesday, August 15, 2017 7:45 AM
Nice modulation on the green,and the stowage looks great.
    September, 2016
Posted by ManCityFan on Tuesday, August 15, 2017 12:26 PM
Looks great!  This is on my wish list, so thanks for posting.  Now I want it even more.  The friulmodel tracks are awesome, and the stowage is very well done.
It's kind of funny how they put that little gun in such a large tank.   The model really shows this.
D
Dwayne or Dman or just D.  All comments are welcome on my builds.
    September, 2013
Posted by Marcus McBean on Tuesday, August 15, 2017 4:59 PM
Thanks everyone.
ManCityFan
I put this tank along side my Tiger II and it is as long as the Tiger but narrower and lower.  During most of the war the British tanks were very well armored but they were slow and under gun.  The Grants and Shermans really saved their butts during El Alamein.
    September, 2013
Posted by Marcus McBean on Wednesday, August 23, 2017 8:27 PM
Calling this one finished.  I didn't do any chipping but I did want it to look like it seen a lot of rain during it march through Europe and into Germany.  It sure rain alot there while I was station in northern Germany.  So I dot filter it so the paint would have a lot of streaks in it and faded due to the rain.  The road wheels were muddy up some what to show it traveling on wet country roads.
Some of the effects were lost or weaken when I put on the matte finish.  Wonder if I should have put on a clear coat after each technique?  I only put a clear coat down for the decals and again over the decals only after they dried.
This was my third attempt a weathering a tank.  Still have much to learn.
I really like building this model, it was easy to put together all though I did mis-understand the instructions more than once.  Hope the other Tamiya kits I have are as easy.
Now time of finish up my M4 Jumbo.
Marcus
    December, 2002
Posted by Bish on Thursday, August 24, 2017 1:57 AM
Really nice finish and very well presented. I like it.
    November, 2009
Posted by Gamera on Thursday, August 24, 2017 7:35 AM
Looks great to me. And like how you put her on a base, I think armour looks better in it's element as it were plus it allows you to handle the base and avoid touching the model.
Personally I only apply clear coats between weathering that might disturb what's already there. And then the final top matte coat.
    September, 2013
Posted by Marcus McBean on Thursday, August 24, 2017 9:16 AM
Gamera
I am going to have give that a try on my next build.
    December, 2002
Posted by Bish on Thursday, August 24, 2017 9:48 AM
I only apply two clear coats to mine. The first is after dry brushing the second a matt coat at the end.
    May, 2015
Posted by Griffin25 on Friday, August 25, 2017 9:13 PM
That looks really nice. Every model doesn't need a bunch of weathering. Its a nice clean build with great detail. The crews cleaned their tanks once in awhile I'm sure. Or it could be new off the tank carrier as a replacement. Cool base too. The flowers give it some flavor. Great job bud
    September, 2013
Posted by Marcus McBean on Friday, August 25, 2017 10:13 PM
Thanks Griffin25.  The base is just something I threw together and will use it again to display the next model.  I do hope to put these models I finish into a dioramas later when I have more time to dedicate to hobby.
    September, 2005
Posted by warshipguy on Saturday, August 26, 2017 6:44 AM
Beautiful job!  I am impressed!
Bill Morrison
    September, 2013
Posted by Marcus McBean on Saturday, August 26, 2017 10:16 AM
Thank you, Bill.
    January, 2015
Posted by M. Brindos on Sunday, August 27, 2017 11:18 AM
I like it a lot. I use modulation on my armor builds as well, but I have decided I like the effect muted and more subtle in 1/35. After dot filters and weathering the subtle modulation is not pronounced and really adds to the overall presentation of finished model.
So if you like the modulation effect, then keep doing it. you'll find your happy medium along the way.
- Mike Brindos
Figure Painting Moderator -- Genessis-Models
    September, 2013
Posted by Marcus McBean on Sunday, August 27, 2017 12:43 PM
Mike,
Thank you.
This was the first time I tried it.  I should have use a little heavier coat when spraying over the areas I covered in white primer.  Some areas were to light but I thought weathering would help make up for it.
I do like the effects so I will keep pluging at it.
Marcus
SUBSCRIBER-ONLY CONTENT
