Trumpeter's 1/16 Jagdtiger completed pictures
    November 2004
Posted by snapdragonxxx on Friday, August 18, 2017 7:11 AM
I have had this project on my bench since 2February and I initially only envisaged a month and a half to build. I wanted mostly out of the box build but I eventually ended up roaming the  internet for stuff!
I have been waiting agesto finish this as the only things I had to do was to paint the tracks and as Xtreme Metal is a funny paint to deal with when it comes to humidity then I had to wait until the weather broke, which it did a couple of days ago with a thunderstorm that rattled every window through the house... and most of the downstairs ones are armoured because of their size ( building regulations requirement).
There has been some frantic activity as paint was thrown about and onto tracks. The tracks have had a two coat treatment with no primer.  A Layer of Extreme Metal Burnt Metal was put on followed by Xtreme Metals Gunmetal. This gives a darker steel look than the steel in their range and lighter than Vallejo's Metal Colour Steel and is just right.
I had to go searching for cables as the ones provided in the kit just didn't fit Too thick! This was another delay as the right diameter to fit with the parts was sourced through Ebay and was sent by slow boat from China!! These cables are actually Steel (1.5mm for towing and 0.8mm for the track cable) and took some fixing on through the mounts etc as they are not as flexible as soft metal copper wire. Quite a bit of naughty words issued from out of the build room which had the paint shop hiding, such as "Stay put you.. (insert favourite naughty word)!" and many more. Finally with the aid of superglue they were fixed and due to the springiness of the steel they look really good in place and don't need painting!
Dodging the great Yorkshire weather to get the photos has been not exactly fun as when the sun comes out and I go out of the house it starts raining on me and then the games ensue! But eventually I got the pictures I need.
I was not happy with my original exterior paint job and re-painted the exterior.
As some of you know I have been using for the exterior authentic paint reproductions of 1945 colours from original chipset and formulas. and as you will see with the last photo they stand exactly to original battlefield pictures.
Enjoy!
It has been a large scale build and both fun and frustrating at times but overall an enjoyable one. Not one for a tank beginner but you do need some complex armour builds under your belt before tackling this and the other vehicles in the range. These ones are time consuming and I reckon that it has been on my bench since 2 Febuary and so, averaging out the hours I have spent I reckon on about 1176 hours over 196 days!
It will be a while until I tackle another 1/16 build but I have my eye on their 1/16 Tiger II and their up and coming Panther G's. They are expensive kits, but provide hours of frustration
    November 2004
Posted by snapdragonxxx on Friday, August 18, 2017 7:30 AM
Some interior views
    February 2015
Posted by acctingman on Friday, August 18, 2017 9:00 AM
She is a beauty!! Love your camo pattern. It's inspirational for sure! (at least for this noob here) Thanks for sharing!
Posted by Tojo72 on Friday, August 18, 2017 9:31 AM
Very impressive build,nice work.
Posted by Gamera on Friday, August 18, 2017 11:05 AM
Sharp work there, love the camo.
I've seen 1/16th Shermans and they're big- that thing must be a monster!
    November 2004
Posted by snapdragonxxx on Friday, August 18, 2017 2:15 PM
Thanks for the kind words and comments.
My original camo wasn't very inspiring so I went back and started again with the dark green 1945 base. Over that was done the Schockolade Brun and Dunkelgelb (1945). Dunkelgelb was a special colour made for me as the only colour availabe is a "scale correct" version and that is just plain wrong and much too light.
As a size reference. the first picture the tank is sitting on top of a pillar outside the house. The capstone the tank is sitting on is A3 in size.
I have to find house room for this now as I can't have it filling my bench or anywhere in my build room or it might just catch cleaner from the airbrush floating around.... and we don't want that!!!
The major obsticle I had to overcome was a warped lower hull that I hade to fix and modify my build from the instructions by having to install the firewall and other structural components to fix the warp before I could start fitting stuff. It did make for very tight working space and sometimes I had to work backwards from the instruction booklet before I could work forwards.
In fairness to trumpeter it is a great piece of work and both the lower and upper hull are huge pieces of moulded plastic, both of which have slight warpage, but they do come together and streighen up to be true properly when upper and lower hulls unite. You need some big clamps to help and Tamiya thin glue will not cut it... trust me!!
It is a very modular build and for those going to tackle it are best working through and building and painting smaller things first rather than fitting them and then trying to paint. build all the small bits and paint them before adding to the big hull. The engine space is very tight to work in even before adding the engine etc and the cooling radiators, fans and housing are a nightmare and I found myself adding supports to try and get them to sit properly and in place.
You will need LOTS of paint and I get through a 60ml bottle (more or less of Vallejo Red Oxide Primer (RAL8012) a full bottle of Vallejo 60ml Grey Primer (just right for the interior panzer colour) and 4 bottles of Vallejo 17ml Model air RAL6003.
Nozzle sizes of my airbrush used were 0.15mm, 0.2mm, 0.4mm, 0.6mm.
I'm going back to my normal scale of 1/35 for a rest!
Posted by tigerman on Saturday, August 19, 2017 2:03 AM
I think your paint job turned out excellently. i would have loved to see some weathering to it, but this is your build after all. Well done.
 Eric
