Asuka 1/35 M4A3E2 Sherman Jumbo
    September, 2013
Posted by Marcus McBean on Saturday, August 26, 2017 11:00 AM
Started this build last week and having such a good time of it before I knew it the model was ready for paint and I realized that I didn't take any pictures of the build.  So I took a few for my records and thought I should share a few with the forum.
This is my first Asuka kit and I must say that this kit went together like a charm.  There were no fit issues and only a couple of sinkholes and minor flash (mainly on the small parts) to deal with.
Used Mr. Surfacer 1200 on the turret and gun mallet were the casting was missing.  Filled in the seam made my the upper and lower hull and then used a file to create the weld seam that runs around length of the turret.
There was a injector pin mark on the transmission case which required a little bit of Mr. Surfacer.
Added some casting numbers to the transmission and turret that my reference documents show should be there.  Asuka already had a casting number  on the hull decking by the driver's hatch. Some of the tools did not have straps so I used some flat lead wire to simulate straps.
The 50 cal machine gun that comes with this kit is awesome.  I was a bit worried that I would ruin it while putting it together with a glob of glue but I managed not to.
The detail on the radio and driver hatches was so-so, so I displayed them closed.  The loader hatch has a lot of detail and the commander hatch completely lack any detail.  After removing a large injector mark I added a periscope and made a strap out of flat lead wire.  Its not much but It should be enough once painted.  All of the periscopes and copula windows I covered with liquid masking which when removed should show the glass as is and not painted.  Did that with my Tiger II, added a slight tint of crystal green paint and they looked really nice.
On to painting and weathering.
Marcus
Tags: M4 Jumbo
    May, 2009
Posted by Pawel on Saturday, August 26, 2017 5:23 PM
Hello!
It's a good looking Sherman! I've heard a lot of good things about those Tasca/Asuka kits. While it's not my genre, I think it would be cool to build one of those - maybe one day I'll try it. Good luck with painting your model and have a nice day
PaweĊ‚
www.vietnam.net.pl
    September, 2013
Posted by Marcus McBean on Saturday, August 26, 2017 5:52 PM
Pawel,
Thank you.
    December, 2002
Posted by Rob Gronovius on Saturday, August 26, 2017 8:20 PM
I picked up a few of the Tasca Shermans, an M4A1 and an M4A3E8, basically the first and last US versions. Very nice kits that redefined the Sherman tank series.
    July, 2004
Posted by stikpusher on Saturday, August 26, 2017 9:06 PM
You're off to a great and rapid start! Looks like your basic build is mostly done.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November, 2005
Posted by T26E4 on Sunday, August 27, 2017 7:56 PM
Looks nice. My question is about your "weld seam around the turret". From my study of pictures, I don't see what you're indicating. The turret was a single casting from what I understand.  If there was a mark there, then it was simply something from the sand mold -- and it would be ground off if required
Roy Chow
Join AMPS!
http://www.amps-armor.org
    November, 2009
Posted by Gamera on Monday, August 28, 2017 11:43 AM
Looks good! The Tasca/Asuka kits are the Cadillacs of 1/35th Shermans. The running gear on the ones I put together were a little fiddly but not that bad. The Korean War version does have a set of tracks with about three parts to each link which I got about halfway though and then needed to take a break on.
"Fairy tales do not tell children the dragons exist. Children already know that dragons exist. Fairy tales tell children that dragons can be killed." -G.K. Chesterton
    March, 2003
Posted by Tojo72 on Monday, August 28, 2017 11:57 AM
Very nice work,I also enjoyed their Firefly also.
    September, 2013
Posted by Marcus McBean on Monday, August 28, 2017 5:32 PM
T26E4
Roy,
You made be right.  The reference photos I have are not very good but they do show along where the bottom of the turret side has grinder marks a long the length of the turret.  All of the Ordanance Steel Foundry (OSF) turrets had those marks that I can tell.
I mentioned the weld from remarks I seen and heard from others who have built this kit and stated that the grind marks where to smooth the weld seam.  I been unable to find anymore information about how or if the OSF turrets were casted in one piece.  Several pictures of the OSF turrets turned upside down looks like there is a seam were the turret wall turns towards the turret ring.  It could be cast that way or it may have been easier for OSF to cast a six inch thick turret wall and then mate it to the thinner turret ring, I don't know.  It would be nice to see a picture of the inside of the turret where it curves to meet the ring that would answer this question.
The Union Steel turrets all had smooth curves and not the sharper curve towards the ring like OSF.  Which makes it easy to spot who made the turret for that Jumbo.
If you have anything to share please do, I also have the Tamiya kit for a future build.
I put the base coat on it last night and will post pictures later.
    September, 2013
Posted by Marcus McBean on Monday, September 04, 2017 9:04 PM
Made more progress with the Jumbo.  She is ready for clear coat so I can put on the decals and do the weathering.
Decided not to use the rubber band tracks so I put a set of Kaizen T-48 workable tracks.  It only took me a week and a half to assemble them.  7 seperate pieces per link plus having to remove the sprue gate, two per link, 160 links total.
I know, I know the starboard side track is on backwards.  It was done on purpose.  I plan on building a diorama later based on the picture below.  In the rear is a Jumbo heading down the embankment to cross a stream or river with it's starboard tracks on backwards, plus the tracks do not have the duckbills that were install on the original issue tracks, they must be replacement tracks.  I believe this picture was taken just before the surrender in May 1945 which would explain the replacement tracks as this Jumbo had to travel a lot miles since arriving in theater in late 44.
I added some K-rations and a couple of 50cal ammo boxes also. I may add more equipment later but right now I like her as is.
Question; does the exhaust on a Sherman rust up like the exhaust do on other armor?  I haven't much time to research further so anyone can answer it would save me the time.
The detail will stand out better once I get some wash on her, which should darken the wood items and rope.
I really like how the casting serial numbers came out on the transmission case, and turret.
Next set of pictures should be of the final.
Marcus
    April, 2015
Posted by Mopar Madness on Monday, September 04, 2017 9:12 PM
Nice Sherman you got there!
Chad
God, Family, Models...
At the plate: 1/35 Tamiya Nashorn
On deck: 1/35 Tamiya Panzer III
In the hole: Probably something in 1/35 scale!
    January, 2015
Posted by M. Brindos on Tuesday, September 05, 2017 8:22 AM
Something's not right there. I think I know which picture you're basing this on, but the reference picture clearly shows an E8 with both runs of track facing the right direction.
The model looks fantastic so far! :) looking forward to seeing more.
- Mike Brindos
Figure Painting Moderator -- Genessis-Models
    September, 2006
Posted by RBaer on Tuesday, September 05, 2017 8:31 AM
Great workmanship on your Sherman.
Re the tracks: the picture you have posted is, as already stated, not a Jumbo, but rather an E8 with HVSS and relatively rare steel chevron tracks. The Jumbos were originally fitted with the T48 tracks, as in the Tasca kit, but with duckbill extended end connectors (EEC). I only know offhand of one example of a Jumbo with anything else.
Apprentice rivet counter.
    September, 2013
Posted by Marcus McBean on Tuesday, September 05, 2017 8:59 AM
The tank going down the river bank in the background, behind the truck coming out of the water is the Jumbo I am refering too.  The E8 is the tank in the foreground climbing up the river bank.
    September, 2013
Posted by blackdog62 on Tuesday, September 05, 2017 1:49 PM
Wow that's a really looks like a nice kit. You have done a great job on it.
The photos make it look even better would you mind telling us what camera and lighting you use.
I have one of there Sherman's in my stash in the box it's one of the best looking Sherman's s I have.
Jerry
    November, 2009
Posted by Gamera on Tuesday, September 05, 2017 3:54 PM
That's some nice work, looking forward to seeing her all done!
    September, 2013
Posted by Marcus McBean on Tuesday, September 05, 2017 4:37 PM
blackdog62
Jerry
blackdog62,
I used a Nikon D5300 digital camera with a Tamron 16 - 300 zoom lens.  The setup is done on my work bench using a red sheet (I have other colors) I have from a pop-up photo booth I rarely use.  The lighting is just the lights I have at the work bench.  Here is a photo of the set up I used to take the pictures of the last post.  I shoot the pictures in the raw and use Corel Paintshop Pro X9 software to adjust them if need be.  I save a copy off as a Jpeg so I can post them on line, as the raw photos are very large files.
Marcus
    September, 2013
Posted by Marcus McBean on Sunday, September 10, 2017 6:20 PM
I am ready to call this one finished for now.  Dirty her a whole lot to reflect her march across France and Germany.  My plan is make a diorama of her climbing or decending a very muddy bank along a stream.
She nothing fancy to look at but I had a lot of fun building her and lost only two PE pieces to the carpet monster.
After I posted these photos I realized that the Jumbo was missing a antenna.  No antenna comes with the kit so I installed a 2 meter after market antenna.
I wonder what else I forgotten?
    May, 2015
Posted by Griffin25 on Sunday, September 10, 2017 7:32 PM
Great looking Sherman. Look forward to seeing the diorama one day. I like your photo studio too. Your photo skills from this build and the other 2 I've seen are top notch.
    April, 2015
Posted by Mopar Madness on Sunday, September 10, 2017 8:04 PM
Thats a nice looking Sherman you've got there! Nicely weathered.
Chad
    September, 2013
Posted by blackdog62 on Sunday, September 10, 2017 9:55 PM
Very nice build I hopeing to get to 1 of mine this year. I especially like the work you did on the white stars.  I hope you Share the dio build with us.
My carpet monsters have bin knowing to darn right feast at times.
    July, 2014
Posted by M1GarandFan on Sunday, September 10, 2017 10:45 PM
Let me add my congrats on a great looking Sherman. It really looks nicely weathered. I hope to get around to a Jumbo eventually.
    December, 2002
Posted by Rob Gronovius on Sunday, September 10, 2017 11:37 PM
Marcus McBean
Hate to rain on the parade, but does it look like the front road wheels on both sides are "floating" up with the tracks?
    September, 2013
Posted by Marcus McBean on Monday, September 11, 2017 6:42 AM
Rob,
Forgot to push them down.  The mud is still sticky and there is no weight in the front to really push down.  They have the correct amount of links on each side, but they may be to tight.  If they don't settle down I will adjust the idlers.
    November, 2009
Posted by Gamera on Monday, September 11, 2017 12:05 PM
Other than the tracks she looks great to me!
If nothing else work when you fit her to the permanent base you can remove the turret, drill a hole into the bottom of the tank though the base, and put a wood screw in there to tighten her down. It will flatten out the running gear and secure her to the base.
    September, 2013
Posted by blackdog62 on Monday, September 11, 2017 1:58 PM
Camera nice tip on tightening the tracks down. Thanks I may need that truck someday.
    September, 2013
Posted by Marcus McBean on Monday, September 11, 2017 7:59 PM
Gamera
That is a great idea, thanks.
SUBSCRIBER-ONLY CONTENT
