Small Scale M1 Abrams
    November 2015
Posted by STOVK on Tuesday, April 10, 2018 2:28 PM
Hello All,
 Even though I am building a Diorama, I am posting here because I have a question regarding an M1 Abrams  model.
 I am in search of a good (very detailed) M1 Abrams model kit within the scale of 1:72 and 1:96. I've seen a few in my searches, but some look pretty cruddy.
 In addition, does anyone make any modern US Army/Marine figures in the same scale range?
 I was wondering if any of you "Tankers" out there have any thoughts.
 As always, thank you.
    December 2012
Posted by RX7850 on Tuesday, April 10, 2018 7:47 PM
I dont know what kit manufacture  you have looked at so far but  I would  suggest  the Flyhawk M1A2 SEP Kit# FH-3300 and Tiger models M1A2 SEP Tusk II  Kit # Tig9601. Both kits exhibit exceptional detail.
Good luck.
Posted by Rob Gronovius on Wednesday, April 11, 2018 8:53 AM
The Abrams tank is going on 40 years of use, do you want an early 80s Cold War tank (M1, M1IP), late Cold War/Desert Storm (M1A1, M1A1 heavy common), early Iraqi invasion (OIF) M1A1 heavy common, M1A2, later Iraqi war use (M1A1AIM, M1A2SEP)?
There is a website dedicated to 1/72 scale plastic soldiers. Go to this site, click the "periods" link on the right and select "modern" at the bottom of the page. Then you'll see some manufacturers, some with photos of the figures.
http://www.plasticsoldierreview.com/Index.aspx
    November 2015
Posted by STOVK on Wednesday, April 11, 2018 9:31 AM
Rob Gronovius
Good point. Mainly the standard M1A1. I am not interested in the TUSK or any of the variants and upgrades. My Diorama would be circa 1991
RX7850
Good luck.
I've looked at Dragon, Trumpeter, and Hasegawa. I also looked at Tiger, but I see the tracks are molded to the wheels. From the photos I have seen, I can't make out the level of detail.
I like that one from Flyhawk. I wonder if i could modify it from an SEP to a standard package? That'll test my limited skills.
Thank you for the help.
Posted by Rob Gronovius on Wednesday, April 11, 2018 11:32 AM
STOVK
No, you can't back date a SEP to an M1A1 without a lot of rework and scratchbuilding. There are hull changes and a totally different cupola. It would be like trying to backdate an M4A3E8 into a regular M4 Sherman.
I would direct you to Revell of Germany's M1A1 Abrams kit (#03112) which is a very good kit. It has some minor issues, but nothing that detracts from it and fits to a circa 1991 tank. Revell also has a M1A2 Abrams kit (#03146) which is the same kit with a couple small sprues that add the A2 specific parts. As an A2, the kit has more issues since the replacement parts just add a cosmetic change, but you can still build the kit as an M1A1 and it gives some updated wartime items to give you more options than the original kit. So as an M1A1, this is a good kit to get, but as an M1A2, I'd recommend some other kit.
https://www.revell.de/en/products/model-building/military-figures/vehicles-modern/id/03112.html
https://www.scalemates.com/kits/103914-revell-03146-m1-a2-abrams
    November 2015
Posted by STOVK on Wednesday, April 11, 2018 12:59 PM
Great info. Thank you.
