Zimm decals
    November, 2008
Zimm decals
Posted by plasticjunkie on Friday, September 21, 2018 9:37 AM
Just wondering it the Meng Zimm decals will work on a Dragon KT ?
 GIFMaker.org_jy_Ayj_O
    March, 2003
Posted by Tojo72 on Friday, September 21, 2018 9:56 AM
Usually manufacturers make them for a specific kit,allowing for the fittings and such,but perhaps they would work with some surgury
    November, 2008
Posted by plasticjunkie on Friday, September 21, 2018 10:13 AM
Tojo72
Right just like resin parts labeled for let's say Revell will fit in a HB kit with lots of sanding and slicing. Just wondered if anyone has tried these Zimm decals which are a lot easier to apply than Squadron putty then rolling my zimm tool for the pattern.
    November, 2016
Posted by Poniatowski on Wednesday, October 03, 2018 1:45 PM
I used the Meng Panther decals on the Takom kit. They worked fine. As long as the kits are scaled the same, there should be no problem. Also, you can fill with putty or cut and such as mentioned above.
They didn't work well over complex curves such as the hull machine gun armor.
Ron
    November, 2008
Posted by plasticjunkie on Wednesday, October 03, 2018 3:35 PM
[quote user="Poniatowski"]
Ron
Thanks Ron.  I made a photo copy of the Meng zimm decal and cut out several parts and they fit really well on the Dragon Tiger so this one is on deck.
