Tamiya Stug Advice Needed
    October, 2003
Posted by ModelNerd on Saturday, January 05, 2019 6:41 PM
I have this old Tamiya Stug kit in the stash and thought I'd give it a go. However it has those nasty vinyl tracks, which don't always look so good. Does anyone make aftermarket track links for this kit? I'll just say it up front that I know very little about armor modeling (I'm typically a plane guy), so wouldn't even know where to look for such an item.
Thanks-
- Mark
    February, 2016
Posted by German Armour on Saturday, January 05, 2019 6:57 PM
ModelNerd
Thanks-
Hi, if you want tracklinks, you should look for Pz. III seperate tracklinks.
Panzer III & StuG III Early tracks
AK Interactive - Nr. AK 685 - 1:35
Tracks Set Ostketten + Ice Grousers - for Panzer III/IV & Variants
Accurate Armour - Nr. T03 - 1:35
1:35 PzKpfw.III/IV Late Production Ostketten Replacement Resin Track (Accurate Armour T69)
1:35 40 cm Track (Dragon 3821)
40 cm Track for Pz III/IV
Dragon 1:35
3821
 1:35 Panzer III/IV & Variants, 40cm Typ B (Metal Track) (Easy Metal Links EML35-002)
Easy Metal Links 1:35
EML35-002
1:35 Panzer III / IV & Variants Wintertracks (Metal Track) (Easy Metal Links EML35-003)
EML35-003
1:35 Panzer III / IV & Variants Ostketten (Metal Track) (Easy Metal Links EML35-013)
EML35-013
1:35 PZ III/IV (Friulmodel ATL-04)
PZ III/IV in use 1941/1944
Friulmodel 1:35
ATL-04
1:35 PZ III/IV (Friulmodel ATL-117)
PZ III/IV in use 1943/1945
Friulmodel 1:35
ATL-117
1:35 Panzerkampfwagen III/IV final version (Friulmodel ATL-28)
Panzerkampfwagen III/IV final version in use 1944/1945
Friulmodel 1:35
ATL-28
1:35 Panzer III/IV Mid Ver. 1941-1944 40cm Track w/Slots (kgs61/400/120) Workable Links (Kaizen 30952)
1:35 Panzer III/IV Mid. version 1942-1945 (Workable Track Link) (Kaizen 30957)
1:35 Panzer III/IV Winterketten(Workable Track Link) (Kaizen 30958)
1:35 Easy Metal Links Pz III / Stug III Typ A (MPK Modellbau EML 35-01)
Easy Metal Links Pz III / Stug III Typ A designed by Modellbär
MPK Modellbau 1:35
EML 35-01
1:35 Tracks for Pz.Kpfw.III , Pz.Kpfw.IV 1941-44 open horn (MasterClub MTL35008)
1:35 Tracks for Pz.Kpfw.III (MasterClub MTL35014)
Tracks for Pz.Kpfw.III 380 mm short-horne
MasterClub 1:35
MTL35014
1:35 Tracks for Pz.Kpfw.III (MasterClub MTL35015)
Tracks for Pz.Kpfw.III 380 mm long-horne
MasterClub 1:35
MTL35015
1:35 Workable Track Links Set for Pz. III/IV. Early Type (MiniArt 35235)
1:35 PzIII/IV Late model TYPE A (Modelkasten SK-17)
Modelkasten 1:35
SK-17
1:35 PzIII/IV (Modelkasten SK-17)
Modelkasten 1:35
SK-17
1:35 Pz.III Early 36cm Track For use with Pz.III & Stug.III only (Modelkasten SK-26III)
Pz.III Early 36cm Track For use with Pz.III & Stug.III onlywith parts for Dragon Models
Modelkasten 1:35
SK-26III
1:35 Pz III/IV Early 36cm Track Links (Modelkasten SK-26III)
Pz III/IV Early 36cm Track Links (workable) for early Pz III & StuG III
Modelkasten 1:35
SK-26III
1:35 Ostketten Workable Track Links for Pz.Kpf III/IV (Riich.Models RE30008)
1:35 Metal Track Panzer III/IV Mid Type A (Spade Ace Models SAT-35034)
Spade Ace Models 1:35
SAT-35034
1:35 Metal Track Panzer III/IV Mid Type B (Spade Ace Models SAT-35035)
SAT-35035
1:35 Metal Track Panzer III/IV Late Type B (Spade Ace Models SAT-35040)
SAT-35040
1:35 Metal Track Panzer III/IV Late Type C (Spade Ace Models SAT-35041)
SAT-35041
1:35 Metal Track Panzer III/IV Final (Spade Ace Models SAT-35043)
SAT-35043
1:35 Metal Track Panzer III/IV Winterketten (Spade Ace Models SAT-35045)
SAT-35045
1:35 Metal Track Panzer III/IV Ostketten (Spade Ace Models SAT-35046)
SAT-35046
1:35 WWII German Pz.III/IV 40cm Normal Tracks Middle Pattern A (Voyager Model VT35018)
1:35 WWII German Pz.III/IV 40cm Normal Tracks Middle Pattern B (Voyager Model VT35019)
1:35 German Panzer III/IV Track 1 (Wolfpack WP12003)
German Panzer III/IV Track 1 40cm Track for Pz.Kpfw. III/IV 1942~1944
Wolfpack 1:35
WP12003
1:35 German Panzer III/IV Track 2 (Wolfpack WP12004)
German Panzer III/IV Track 2 40cm Track for Pz.Kpfw. III/IV 1943~1945
Wolfpack 1:35
WP12004
 Never give up, never quit, never stop modelling.Idea
    August, 2012
Posted by Rambo on Saturday, January 05, 2019 7:12 PM
Clint
    October, 2003
Posted by ModelNerd on Saturday, January 05, 2019 9:42 PM
Thanks everyone! Much appreciated!
- Mark
    September, 2004
Posted by tankboy51 on Saturday, January 05, 2019 10:44 PM
It's really pretty nice kit.  The track works well for me, but I'm not that picky.
    August, 2005
Posted by Phil_H on Sunday, January 06, 2019 7:54 AM
ModelNerd
This one is the mid-90's new tool kit, not the mouldy old '70's one. It's got the later gluable tracks with detail on the inner surface.
If I was to swap out the tracks, I'd love to go for the winter tracks with the grouser extensions, just cos they look cool.
    October, 2003
Posted by ModelNerd on Sunday, January 06, 2019 1:04 PM
Phil_H
Actually the tracks in my kit are flexible black vinyl.
- Mark
    August, 2005
Posted by Phil_H on Sunday, January 06, 2019 3:24 PM
ModelNerd
They are indeed, but they are a different formula of vinyl to the old ones. The older grey type were virtually impervious to most solvents and you had to join the ends using teh "hot screwdriver" method. The newer type can be simply glued together using regular model cement or CA.
Note that the newer (black) type has been said to disintegrate some time after completion if painted (or washed) with anything stronger than acrylic paints. No oil washes, enamel paints or lacquers, or you may have a bad day somewhere down the line after it's all finished.
    March, 2003
Posted by tigerman on Sunday, January 06, 2019 6:15 PM
Phil_H
ModelNerd
Bah! I built my Tamiya Pz III L many moons ago and the tracks are totally fine. Depends on what you mean by stronger? I sprayed enamel black and the acrylic over that and then used terpentine washes.
 Eric
