Micro Crystal Clear
Micro Crystal Clear
Posted by Hoghead on Thursday, February 8, 2007 7:12 PM
Hey How do you use this stuff ? I am trying to make a windshield for the Matchbox 1/76 Diamond T tank transport truck. I have a bottle but the directions on it are not much. HELP
    April 2004
Posted by crockett on Thursday, February 8, 2007 8:30 PM
Hi there,
You should really post your question in the techniques forum.
 Try slowly applying the Krystal Klear around the frame of the window with a toothpick. Work inward as each pass dries, add another layer until you have the entire opening filled. Wipe away any excess with a wet Qtip. Once completely cured (24 hrs.), you should have a nice window.
    September 2005
Posted by Kykeon on Thursday, February 8, 2007 8:31 PM
I have some myself that I use of making vision blocks and the like, but I have some doubt that it will be able to produce a film large enough for a windshield. Basically, you use a brush, needle or other small, pointed tool and apply a bead of the product completely around the circumference of the opening where you want the window. Once the bead is in place, touch the tool to one edge of the goo and slowly pull it away. The product should "string" with the tool, forming a thin bubble or film. Pull this toward the far side of the opening and touch it to the bead on that side, if you are lucky, it will have pulled the film over the entire opening. It  doesn't work every time. You might try to bend a piece of wire into an "L" that is just a bit shorter than the window is wide, then touch the whole length of the L into the goo, so that you pull a large amount away, producing a wide film, which you then anchor to the other side.
Hope this makes sense.
Or try Steve's way instead.....
Posted by T26E4 on Friday, February 9, 2007 10:34 AM
How large is the opening you're hoping to fill?  I would imagine it's about 3mm x 5mm right?  If so, I would advise strongly against using Crystal Clear.  Why?  Because it's going to be fuzzy and blurry -- totally drawing the viewer's attention to "why is the windscreen so funny looking".  Not what you're hoping to accomplish, I believe.
Instead, get some acetate (the clear material used  in many types of packaging).  Cut the appropriate size rectangle.  Carefully take a black permanent marker and blacken the edges of the acetate.  Then glue it into place using PVA (white or Elmer's) glue.
HTH
Roy Chow
Join AMPS!
http://www.amps-armor.org
Posted by Hoghead on Saturday, February 10, 2007 4:56 PM
Thanks for the help I am new so I didnt think to use the tech forum sorry . I think I will use the  clear plactic approach . It seems that it willl be clearer and easier. I will try the crystal clear on the rear window of the cab.
Posted by Hoghead on Monday, February 12, 2007 10:19 PM
 Well here is a pic of how the windows turned out on this Matchbox Diamond T I cut out acetate for the front windows and used a tiny piece of screen for the rear one which I saw on a pic of a restored one.
Posted by Hoghead on Monday, February 12, 2007 10:42 PM
 Another view of the Diamond T. This was a great kit of an out of the ordinary subject.
Posted by Hoghead on Wednesday, February 28, 2007 8:25 PM
Well here are a couple of images of my finished Diamond T and Sherman tank loaded on the trailer
Posted by Hoghead on Wednesday, February 28, 2007 8:30 PM
and the other.
Posted by Hoghead on Wednesday, February 28, 2007 8:40 PM
Here's a pic of the real one in Europe
    October 2005
Posted by Brumbles on Thursday, March 1, 2007 9:52 AM
Very nice work, Hoghead!  I admire anyone who can work in 1/76th!  I have trouble enough with 1/35th, with these failing eyes of mine...
