M109A6 Paladin Finished - Pics!
    November 2006
Posted by dupes on Tuesday, June 26, 2007 8:07 AM
Finally wrapped up my Paladin for the Italeri GB...quite honestly there isn't much Italeri left in the kit. Big Smile [:D] AFV Club tracks, Archer markings, Barrel Depot 155mm gun, a big Eduard PE set, some Tamiya stowage, and a bit of DupesCo. scratchbuilding. I set out to build an M109 from OIF based on pics I found at Prime Portal:
http://www.primeportal.net/m109_iraq.htm
Particularly vehicle A15 of the 413/16 FA although the model is essentially a composite of several different vehicles, as there weren't enough pics to go by.
Without further ado, here she is:
All input highly welcomed and appreciated!
    November 2006
Posted by jadgpanther302 on Tuesday, June 26, 2007 8:37 AM
now that is one awesome model. It looks like its in iraq ready to fire some HE.
    September 2006
Posted by shall on Tuesday, June 26, 2007 9:13 AM
Wow!  Really nice job!  What really intrigues me though is the color difference between indoor and outdoor lighting.
shall
    May 2005
Posted by CDNTanker25 on Tuesday, June 26, 2007 11:49 AM
Looks great to me man!  Nice weathering and all.  I'm a little curious about the back tools on the vehicle though?
James on the bench: Merkava II With MCRS-20% Merkava IID 75% IDF Magach Batash
Posted by HeavyArty on Tuesday, June 26, 2007 4:38 PM
Looks great.  I too would weather and fade the tools a bit more though.  Your bumper numbers are a little off as well.  The vehicle is from 4th Infantry Division, 3-16 FA.  They should read 4I 3-16 F, not 413-16F.  Also, the square block with 4 dots on it about center top on the hull, above the 4th road wheel, (parts 53 I think) are not present on Paladins.  They are left over parts to the air inflated flotation system on older models, along with the boomerang-shaped cover on the hull top just in front of the turret opening.  Other than that, great job on her.  The spare road wheel came out great too.
    January 2005
Posted by biffa on Tuesday, June 26, 2007 4:42 PM
Awesome job Dupes, im no expert on anything really least of all modern armour but i really like the way this one looks the paint and weathering are very well done.
Ron.
Ron g.
    November 2006
Posted by dupes on Tuesday, June 26, 2007 6:29 PM
Gaaaah! Wrong unit ID? This is what I get for not actually looking into the unit itself, rather than just referencing pictures. Dunce [D)] In one of the close up shots from prime portal where you can see the water can's stencelling, it says "AI5" rather than "A15". I compared that to the front bumper which showed "4I3-16F...A15" and figured that meant that the "1" and "I" were interchangeable stencils for a "one". D'oh! Luckily I should be able to cover up those little tabs and hopefully change those two 413's into 4I3's.
Sure enough HeavyArty I looked back at the reference photos and found that square block...wasn't there. I had some A5 pics as well and it...wasn't there. Sadly, I'm not sure that I can remove them now. Banged Head [banghead] I'm not sure what you mean about the boomerang-shaped cover though?
There are a couple of other minor kit discrepancies I noticed (too late) as well - the tow hooks on the front are the wrong type (must have been redesigned - more of a loop now), and I believe there's supposed to be a 4th antenna block (a short one) on the non-tool side. Not sure if that's on every vehicle, but I think so.
Hmmm. I apparently passed right over the tools for the majority of the weathering. Mysterious. Wink [;)] Have to get on that.
My sincere thanks to everybody who takes the time to leave some input. Love to hear what you guys think.
    November 2006
Posted by dupes on Tuesday, June 26, 2007 6:36 PM
You should see the difference when I had it sitting in direct sunlight trying to mimic one of the reference photos - yet another color entirely (very washed out). Yet another challenge to overcome - trying to make your pictures look like the model you see on the bench in front of you!
    November 2006
Posted by dupes on Tuesday, June 26, 2007 6:37 PM
Ron.
Ron - as you probably know I'm a big fan of your work - coming from you that means a lot. Thanks!
Posted by HeavyArty on Wednesday, June 27, 2007 8:32 AM
If you look on the hull top, just in front of the turret opening, you will see a raised area that is curved that goes across the whole hull and ends at the square pieces with the 4 knobs.  It is a cover plate that protected the hoses for the aforementioned flotation system.  Also, there should be a spaced-armour plate on top of the driver's hatch as well, the same size and shape of the hatch.  Unfortunately, Italeri did not update the hull when they made the Paladin kit.
Either type of tow hook or tow shackle is correct.  Both types are still used.
For the antenna, it sounds like an EPLRS antenna, which is used for situational awareness at the HQ by showing where the vehicle is on a digital map.  Not all units use EPLRS, some use Blue Force Tracker, or other systems.
    July 2003
Posted by zokissima on Wednesday, June 27, 2007 8:39 AM
Saw this one comming up for a while. Glad to see it finished up. I don't really like the stain streaking on the hull side, I would have used much thinner paint. Aside from that, it definitely looks the part.
What paint did you use for the basecoat?
    December 2006
Posted by detailfreak on Wednesday, June 27, 2007 6:40 PM
great job dupes.not much into modern armor but from the looks of things you got it good.Thumbs Up [tup]Thumbs Up [tup].getting a little away from your awesome arty.what kind of camera do you use.keep'em comin.greg
[View:http://s172.photobucket.com/albums/w1/g-earl828/]  http://i158.photobucket.com/albums/t104/cycledupes/1000Roadwheels4BuildBadge.jpg
    April 2005
Posted by wing_nut on Wednesday, June 27, 2007 6:57 PM
Have not been here in the armor area for a whle... glad I stopped by.  Nice!
Marc
    November 2006
Posted by dupes on Thursday, June 28, 2007 1:07 PM
Thanks for the comments fellas.
Let's see, the camera is a Sony...something or other. Nothing fancy, like 3 megapixels maybe? Had it for a few years (4?) so it doesn't have any of the new fancy stuff. Would love to upgrade but that would cut into the modeling budget, and we can't have thatWink [;)]
Had to look back last night to confirm my paint for the basecoat - it's Model Master acrylic Sand. The MM stuff has great exact color options (all the RLM's, FS's, etc) but I tend to get a grainy finish with it that I've never had with the Tamiya stuff...little post-sanding took care of that though. As for the streaking, I'm not 100% in love with how it came out, a bit grainier than I wanted, but I needed to depict many layers of oil/soot/crud buildup that were evident in the reference pics. If I could come up with (or find) a different method to mimic what I was seeing on the actual vehicles, I would no doubt try it.
    July 2006
Posted by redleg12 on Friday, June 29, 2007 8:03 PM
Looks great. I won't comment on particular items since most others have hit them already. As far as fixing things, if you enjoyed building it then don't try to fix it. Guys like Heavy or myself who spent many years around artillery will pick up the minor details on a US SPG but the other 99 44/100% of the world won't. Be happy with a job well done.
Remember, if you were perfect you most likely would not be modeling.
Someday I have to figure out how to give models the smell of muzzel blast. This is one that invokes the thought.
Great job and good luck. See you behind the breech block!
"The Moral High Ground....A Great Place to Emplace Artillery."
    March 2007
Posted by armornut on Saturday, June 30, 2007 8:18 PM
 that is very nice really nice,stupid question time,is that kit available? i need two ,one for me and one for a buddy who crewed one in operation desert storm,is the bussel above the spades and rear hatch scratchbuilt?thanks in advance if ya answer,that is a very sweet modelCool [8D]
we're modelers it's what we do
    May 2004
Posted by Zero Enna on Sunday, July 1, 2007 2:13 AM
That's an outstanding build!, I like the weathering... Did you found any fit problems with that kit?... Thanks for sharing. Most regards.
José
"Vivir venciendo o morir matando"
    February 2007
Posted by Luftwoller on Sunday, July 1, 2007 6:05 AM
Looks great to me too. Anyone who wears lycra cycling gear for fun, is ok in my book. lol.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    November 2006
Posted by dupes on Sunday, July 1, 2007 8:57 AM
Haaahhahaha....yeah, I end up wearing lycra about 6 days a week this time of year. Big Smile [:D] Gotta pile on those miles!
Thanks for looking and taking the time to post everybody. Let's see if I can answer your questions -
The kit certainly is available, it's Italeri #0372. On sale until July 5th at Great Models for $20.10 if you're interested. I would HIGHLY recommend the eduard photoetch set, it reaaaaaly improves things a lot for this kit. Note that it does not build into an OIF paladin out of the box - markings are only provided for a green camo scheme.
The bustle wasn't scratchbuilt, but does end up looking much better with the eduard parts. As for the stowage, there isn't any included with the kit. All of the tools are there, but that's it.
Fit problems - well, the front glacis required a lot of filler to fit flush. I ended up using a putty/super glue combo to get it in place properly. Other than that, the only issue I found (which was harder to deal with) was the rear plate at the back of the turret that covers up the ammo storage - there was absolutely NO WAY to make that piece fit without trimming. I ended up taking off almost an eighth of an inch (!) from each end to get it to finally mate up with the two sides, and honestly it still doesn't look quite right (some gaps).
Feel free to fire off any more questions.
Thanks guys!
