Automotive Paint
    November 2003
Automotive Paint
Posted by H23Tanker on Monday, February 9, 2015 10:26 AM
I understand there is a good way to use automotive paint to paint model car bodies, but I'm not sure how to proceed. The auto parts stores near my home have a great color selection..What's the best way to prepare a plastic model auto body so that it can be painted with automotive paint?
Tags: car , car modeling
Posted by midnightprowler on Monday, February 9, 2015 5:49 PM
You need to use a auto type primer, spray it in light coats to avoid crazing the plastic.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    December 2007
Posted by PANZERJAGER on Monday, February 9, 2015 6:17 PM
not too hard as long as you use a good sealer so the paint doesn't eat the plastic.
check out my latest build;
cs.finescale.com/.../1796827.aspx
 PANZERJAGER
    June 2010
Posted by OctaneOrange on Tuesday, February 10, 2015 12:26 AM
correct. it needs a suitable primer. newer automotive paints are matt+clear coat, so you may need to clear coat your model to gloss it up.
Posted by Don Stauffer on Tuesday, February 10, 2015 9:16 AM
In addition to auto body primers such as Dupli-color, I find Krylon primer works fine under auto paints, and may be easier to find.  BTW, I find most auto paints now are acrylics, not the old solvent lacquers which are now somewhat rare.
    December 2007
Posted by PANZERJAGER on Tuesday, February 10, 2015 3:23 PM
Plenty of solvent based auto paint out there.
TCP Global is a good source.
As far as using them on plastic, you are looking for a sealer more so than a primer.
The sealer is used to create a barrier between the solvents in the auto paint and the plastic.
most "primers" are porous, thus they will not adequately protect the plastic from the "hot" solvents used in most auto paint.
It is a good practice to use a "sealer" even if you are using rattle cans such as Krylon, because it too will eat into some plastic model car bodies.
I have been using auto paint for over 36 years and have learned from many mistakes over time.
In the long run, just use caution and start with a good foundation on your kit.  It will save you a lot of money, grief and mental anguish, especially at the price of model kits these days.
If you are interested, here is a link to my photobucket site, there you can see more of my past builds.
s251.photobucket.com/.../library
PANZERJAGER
 PANZERJAGER
Posted by Don Stauffer on Wednesday, February 11, 2015 9:21 AM
Even when using real solvent lacquers I have never had a problem with the paint bleeding through either Krylon nor Duplicolor primer.
    December 2007
Posted by PANZERJAGER on Wednesday, February 11, 2015 1:02 PM
Your lucky I guess.  All I am saying is you can go at it "fast & loose" or play it safe.
What works for you works for you.  I'm not saying your wrong, I'm just trying to give good well founded advice.
 PANZERJAGER
Posted by rangerj on Sunday, February 15, 2015 2:04 PM
Flo-quill Barrier works well as does a coat of Testors lacquer for plastic models.
    April 2005
Posted by wing_nut on Sunday, February 15, 2015 6:32 PM
I would think Mr.Surfacer 1200 or 1500  would do nicely too.  Lacquer based but not so hot is messes with the plastic. Gets a real good bite on it though so it's a tough finish.
Marc
    November 2008
Posted by plasticjunkie on Monday, February 16, 2015 6:43 AM
delete
 GIFMaker.org_jy_Ayj_O
    January 2003
Posted by leemitcheltree on Monday, February 23, 2015 11:39 AM
There's a lot of good tips here, Tanker.  Here are mine -
I've used automotive acrylics for years, with excellent results.  They are "hot", and although they CAN craze plastic (or warp thin section car bodies if applied too thickly), I've never had that happen.
I use spray cans (there are a million different touch-up colors out there), using a short section of a drinking straw to spray into my airbrush paint jar.  Wait for the paint to de-gas (5 minutes should do it), and then I usually add about 50% laquer thinner.
It bites the styrene and adheres very well.....but the trick is.....don't apply too much at once.  Slowly-slowly is the rule of thumb.  You should be able to get excellent coverage easily.
It dries very quickly, and dries hard, so sanding and polishing is easy - just like a full size car.  It takes waxes and polishes well (I use Meguiar's).
Remember....if you want to paint yellows, reds or blues, you might find it better to use a white primer - easier to get full color without having to apply a gazillion coats of color to hide the primer color.
Good luck!
Cheers, LeeTree
Remember, Safety Fast!!!
    October 2008
Posted by Rigidrider on Sunday, March 29, 2015 4:12 PM
Like PanzerJager said, TCP Global /HOK paints has any color you could imagine, any finish like pearls and Kandys, in about any type from lacquers, urethanes. enamels, and acrylics. However, avoid urethanes due to the cost and the reducers being so aggressive on styrenes.  The only caution is to not use generic clear coats as I've had some less then acceptable results due to wrinkling of the colors, even lacquer on lacquers. Most good primers (like Krylon, and most auto primers) work very well.
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    October 2010
Posted by Dogfish_7 on Saturday, April 4, 2015 7:26 AM
Good tips all!
Bruce
