Tyrrell P34 1977 Monaco Grand Prix
    May, 2011
Posted by Real G on Friday, February 01, 2019 5:06 PM
I don't think I have posted a thread on this model - that's what happens when you are a glacier-slow builder like me and forget stuff.  Anyway, I have always liked this weird 6-wheel design, so decided (many years ago) to try my hand at a Formula-1 car.  Please pardon my ignorance, as I knew basically nothing about them and learned stuff along the way.
Here's the kit:
https://flic.kr/p/rcLwP4] [/url]P34-Box Art by N.T. Izumi, on Flickr
I wanted to try detailing the kit as best as I could, plus make painting easier.  That meant re-engineering the body to separate along areas of different color.  To this end, two kits were purchased to hack apart and reassemble.  The vertical sides of the monocoque where the front suspension attaches to were molded with the upper body, so they were separated and glued to the bottom plate.  These parts would be all painted aluminum.
https://flic.kr/p/r7ASCn] [/url]P34-002 by N.T. Izumi, on Flickr
The small side windows were provided as clear acetate sheets which were supposed to be glued into recesses on the inside of the upper cowl, but you can see into the cockpit after the kit is finished.  So I glued a solid sheet of plastic into the recesses, filling them flush, and opening up the windows while leaving a small ledge to attach new windows from the outside.  The windows have a rubber gasket around their perimeters, but I'll figure them out later.
https://flic.kr/p/rK5m2K] [/url]P34-005 by N.T. Izumi, on Flickr
The upper cowling aft of the driver's seat had a poorly molded rib that did not match the one molded to the forward cowling, so they were removed in their entirety and replaced with triangular strip plastic.
https://flic.kr/p/r7ARcg] [/url]P34-004 by N.T. Izumi, on Flickr
A painful (but educational) lesson in buying a bunch of aftermarket accessories is that some (or in my case a lot) of that stuff really isn't all that helpful.  Case in point the PE for the backsides of the front spoiler.  I think it is made of stainless steel, which proved difficult to cut/trim and impossible to curl to accurately fit the spoiler edge contours.  So out came the sheet plastic and with little fuss, the job was done.
https://flic.kr/p/s7hcwj] [/url]P34-006 by N.T. Izumi, on Flickr
The kit is old, so there is a battery compartment underneath that fit poorly.  I tried to fill/sand the gaps, but just gave up after several tries.  A sheet of 0.010 sheet plastic was used to plate over the mess.
https://flic.kr/p/s5xsF8] [/url]P34-010 by N.T. Izumi, on Flickr
https://flic.kr/p/swx9ZA] [/url]P34-012 by N.T. Izumi, on Flickr
I have posted some pics of Archer rivet decals before, and this is the project where I first used them.  A reference book I have included a large photo of a wrecked P34 being hoisted off the track, which afforded a rare, clear shot of the underside.  I used the photo to add the rivet pattern.
https://flic.kr/p/uwLYLN] [/url]P34-037 by N.T. Izumi, on Flickr
https://flic.kr/p/vruyku] [/url]P34-038 by N.T. Izumi, on Flickr
Coat of primer, then some Alclad aluminum.
https://flic.kr/p/vjt7gb] [/url]P34-039 by N.T. Izumi, on Flickr
https://flic.kr/p/vmvkiy] [/url]P34-064 by N.T. Izumi, on Flickr
So after much filling of ejector pin marks and such, primer was applied to the body pieces to see how things were proceeding.
https://flic.kr/p/sCDWhw] [/url]P34-013 by N.T. Izumi, on Flickr
https://flic.kr/p/smfAqL] [/url]P34-014 by N.T. Izumi, on Flickr
Anyway, more later!
    July, 2008
Posted by Est.1961 on Friday, February 01, 2019 5:27 PM
Very nice Real G will keep watching. Finishing Airfix 1930 Bentley 1/32 and ordered Tamiya's Morgan today.
    April, 2003
Posted by keavdog on Friday, February 01, 2019 5:37 PM
Oh cool!  A lot of work so far and looking nice.  Following this one.
Thanks,
John
    March, 2007
Posted by armornut on Friday, February 01, 2019 7:48 PM
    I have 2 of the 1/12 scale kits, an old release and the re-issue with photo etch. My plan is to build one track ready and the other one showing the PE details. Always loved thjs akward looking race car. Turns out the idea of 6 tires was useless as the r steer tires wore faster than the drive tires and no real speed advantage in turns was gained.
    An awesome endeavour for sure, I will be checking in from time to time.
we're modelers it's what we do
    May, 2011
Posted by Real G on Friday, February 01, 2019 8:43 PM
Yep, the aerodynamic advantage of hiding the front wheels in the body was offset by excessive scrub in turns.  The Tyrrell team endlessly tinkered with the steering geometry to try and get all four front wheels to track correctly but apparently were never 100% successful.  The added weight of the extra set of wheels and suspension was also a factor, and Goodyear’s halting development of the tiny tires spelled the end of the P34’s career.
By the time the 2nd gen P34s were on the track in 1977, the front wheels were moved out into the airstream to improve roll stability, but negated the aerodynamic advantage of the narrower track 1st gen cars.
fox
    January, 2007
Posted by fox on Friday, February 01, 2019 8:44 PM
Very good work. I plan to follow your build closely. Heard about those rivet decals but never saw them in actual use. Great job. Gonna have to get me some of those.
Keep up the good work. Toast
Jim  Captain
 Main WIP:
   On the Bench:  Revell 1/96 USS Kearsarge - 70%
    May, 2011
Posted by Real G on Friday, February 01, 2019 9:40 PM
Thanks guys for the positive comments!  A disclaimer though - this build is several years old, so hopefully by the time the photo posts catch up to where the project is at, I’ll resume work on it.  I did get to the decal stage, but am having wonky clearcoat issues.  The drivetrain also needs a few small parts, but the big stuff is substantially complete.
And Armornut, I also have two 1/12 kits just like you - one a fresh reissue and another tatty boxed, but intact kit.  I plan on building one stripped down and the other all buttoned up.  That way I can work around the yellowed decals in the older kit.
    April, 2003
Posted by keavdog on Friday, February 01, 2019 10:01 PM
Thinking of the Ackerman angle/steering on this makes my head hurt...lol
Thanks,
John
    May, 2011
Posted by Real G on Friday, February 01, 2019 11:25 PM
keavdog
Apparently it was not so straightfoward as putting in two sets of front steering wheels.  I think the only way they could have achieved 100% perfect coordination under all cornering conditions would be to have computer-controlled individually steered wheels, something not possible in those analog days.
BUT, that is why I am so fascinated by the P34.
    March, 2012
Posted by mustang1989 on Saturday, February 02, 2019 6:40 AM
Goin' all out on this bad boy I see. Progress looks good so far. No matter how old the kit may be.......at least it's a Tamiya offering. Looking forward to more.
Being really stupid IS "the new smart"!!
    May, 2011
Posted by Real G on Saturday, February 02, 2019 1:34 PM
mustang1989
Considering this kit was one of Tamiya’s earliest F-1 models, it’s not bad.  There’s a bunch of little nicks and spurs in mostly hard to reach areas, probably due to the mold getting old.  Some ejector pin marks are also in annoying, tight spots, but all can be filled.  The Ford-Cosworth V-8 is still a very nice piece of plastic.
To borrow the military expression “mission creep”, what started out as an OOTB project rapidly mushroomed into a complex one.  This was primarily due to the acquisition of several excellent books on the car.  The more I read and studied photos, the more I wanted to improve things.  The downside is you get bogged down, the upside is that you try new things.  Plus almost everything I now know about F-1 came from reading up about the car.
    December, 2018
Posted by Ted4321 on Saturday, February 02, 2019 2:44 PM
Looking forward to watching this build.  Great work so far.
One of my favorite parts about this hobby is learning about the subject at hand.
Thanks for sharing.
T e d
    August, 2007
Posted by DUSTER on Saturday, February 02, 2019 6:46 PM
I'll just sit over here and watch intently
Steve
Building the perfect model---just not quite yet  Confused
    June, 2018
Posted by DRUMS01 on Saturday, February 02, 2019 7:57 PM
    May, 2011
Real G, I noticed in your comment about the yellow old decals. Did you know you can get some high quality replacements at a site called www.indycals.net . He offers them from 1/64 up to 1/12 scale. This is not a plug for him really. It's just I have this car too and purchased some of his custom decals to replace old yellowed ones.
The owner is Michael, he is a great retailer and modeler as well. He offers top quality products and service; like I said, I purchased several different ones. You may want to check him out in the event you would want to make the second car in the colors of the test car; the 76, or the 77 car. Just letting you know....
Ben a.k.a. DRUMS01
I am a veteran; to all others thank you for your service. I hope you found peace after your tour of duty, you have earned it...
PROJECTS:
- 1/48 C-130 - Staged
- 1/16 Kubelwagen (GB) - Started
- 1/350 HMS Roberts (GB) - Done
- 1/35 STRV -103 MBT (GB) - Done
- 1/48 X-15 (GB) - Done
- 1/48 Eagle Lunar Module (GB) - Done
    May, 2011
Posted by Real G on Saturday, February 02, 2019 11:39 PM
Thanks Ben, good to know!
    May, 2011
Posted by Real G on Monday, February 04, 2019 4:39 PM
OK here are some additional pics of the body work.
https://flic.kr/p/tbSCrH] [/url]P34-016 by N.T. Izumi, on Flickr
https://flic.kr/p/sePvWC] [/url]P34-018 by N.T. Izumi, on Flickr
https://flic.kr/p/sUepaE] [/url]P34-019 by N.T. Izumi, on Flickr
https://flic.kr/p/tbztro] [/url]P34-017 by N.T. Izumi, on Flickr
https://flic.kr/p/trQVd4] [/url]P34-022 by N.T. Izumi, on Flickr
Lots and lots of filling/sanding was in order!  But I eventually got there.
    May, 2011
Posted by Real G on Tuesday, February 05, 2019 4:31 PM
After a second go-around with filler and sandpaper, the model looked like this.
https://flic.kr/p/uoPT4K] [/url]P34-020 by N.T. Izumi, on Flickr
https://flic.kr/p/trN5CT] [/url]P34-021 by N.T. Izumi, on Flickr
The aftermarket plate is one of the few PE parts I found useful.  The asymmetrical shape is the reason the added rivets on the underside were not even at the front.
https://flic.kr/p/v4ATYF] [/url]P34-032 by N.T. Izumi, on Flickr
The pedal group had some heavy mold parting lines that defied my attempts to clean up.  Since I had two kits, I removed the pedals from one kit and evened out the base plate.  I then took the pedals from the other kit and added them to the cleaned base.
https://flic.kr/p/viKFMw] [/url]P34-033 by N.T. Izumi, on Flickr
    March, 2007
Posted by armornut on Saturday, February 09, 2019 4:52 AM
   Looking good G, itching to start mine. By yellow decals do you mean old and yellowed or are you refering to the color of the actual markings? If so I may need that afore mentioned decal address as well.
    May, 2013
Posted by Greg on Saturday, February 09, 2019 9:40 AM
This is fun to watch, first Formula car I remember seeing built here (since '13, anyway).
Thanks for posting this.
-Greg
    May, 2011
Posted by Real G on Saturday, February 09, 2019 12:32 PM
Armornut - By yellow I mean the decals have turned color due to age.  But the original kit’s yellow stripes were not the right color.  They were supposed to be a kind of fluorescent yellow that the reissued kits have corrected.
Greg - This is my first seroius attempt at an F-1 kit, and it has been a fascinating journey so far.  I am learning a lot about F-1 technology as well as the the race itself and the people involved.
    March, 2007
Posted by armornut on Saturday, February 09, 2019 7:29 PM
   Thanks Real G, I'm in good shape as I have new decals for the old kit, missing when purchased, and yessir they are BRIGHT YELLOW.  Watching with interest.
    May, 2011
Posted by Real G on Monday, February 11, 2019 4:55 PM
I have noticed the box art of Tamiya kits provide a wealth of detail information that the parts themselves lack.  Case in point the side plates on the front spoiler.  The kit parts have incorrect ribbing and lacks the kinked lower edge as shown on the box.  (By the way, I did some deep diving and got lucky to get ahold of a Model Art magazine that had an exhaustive article on the P34, with painstaking info on the different details found on the cars during their 2-year career.)
https://flic.kr/p/2duXUpL] [/url]P34-073 by N.T. Izumi, on Flickr
Sorry about the bad photo, but from L to R, the kit part, the Studio 27 PE part, and the scratchbuilt part.
https://flic.kr/p/uY3UyZ] [/url]P34-025 by N.T. Izumi, on Flickr
The embossed ribbing was done using a ball point pen tip on 0.015" styrene sheet backed with a rubber block that came with a beading tool set.  A friend had tried this technique to get stamped sheet metal boxes for a scratchbuilt Soviet ICBM carrier, and it worked well so I cribbed it!
https://flic.kr/p/u4Dvdg] [/url]P34-027 by N.T. Izumi, on Flickr
https://flic.kr/p/u23Ted] [/url]P34-026 by N.T. Izumi, on Flickr
https://flic.kr/p/voaWgA] [/url]P34-035 by N.T. Izumi, on Flickr
The kinked lower edge was done by scoring fold lines, bending to shape, then setting it with glue.  The beading tool provided punched dome rivets to finish them off.  The result is overscale, but at least the pattern is correct.
fox
    January, 2007
Posted by fox on Monday, February 11, 2019 7:48 PM
V E R Y Nice work. Toast
Jim  Captain
 Main WIP:
    March, 2015
Posted by JohnnyK on Wednesday, February 13, 2019 5:28 PM
Very nice work so far.
I remember building one of those in 1973. I think that it was the 1/12 kit. That was my first big scale kit and I was amaized by the amount of detail. It was so different from the 1/24 scale car kits.
    May, 2011
Posted by Real G on Thursday, February 14, 2019 10:36 AM
JohnnyK
I can only imagine the reaction that model got when it first came out.  It is impressive even today.  I have been using the instructions of this kit to figure out where all the pipes go on the 1/20 kit.  It’s been educational, as I don’t have much automotive experience.
