1973 Porsche 917/10 Can Am
    October 2020
Posted by Scale-Master on Wednesday, February 21, 2024 9:53 AM
Starter resin & brass kit in 1/43rd scale.   Most Starter kits are curbside but this is one of the few "full detail" kits they offered.
As you can see there is still a good amount of clean-up required after removing the thin flash in the main openings.
This structure has to be cut out too.
The "full detail" section is basically one part and the removable engine cover.
Kind of interesting how they cast it with the steel axle in place.
Build what you want and build it for yourself, the rest will follow... Mark D. Jones
    October 2020
Posted by Scale-Master on Thursday, February 29, 2024 11:35 AM
The engine cover does not fit well; I guess they figured most people would display it off the car (on the included stand).  The panel lines on both sides look about like this, but at different angles… and the sides are much narrower than the tub.  The leading edge had to be addressed too as it didn't line up or allow the opening for the fan to be centered over the fan.  (Shifting the chassis is an option, but I figured getting the body set first was the better option.)
I used sheet styrene to fill in the needed material and modify the panel lines.  Even though I raised the engine cover when I widened it so that the leading edge matched the body, I still had to add material to the top of it outboard of the fairings so the body would flow smoothly.
First coat of white primer to see how it looks.
fox
    January 2007
Posted by fox on Thursday, February 29, 2024 12:06 PM
Nice work! Everything looks like it is where it's supposed to be.
Stay safe.
Jim Captain
 Main WIP:
    October 2020
Posted by Scale-Master on Sunday, March 17, 2024 10:59 AM
The screw holes in the front section of the body that attach it to the chassis & engine were reworked so the chassis could be moved rearward to compensate for the material I added to the leading edge of the engine cover and make the fan line up with the opening.
I started painting the engine and surrounding area, but there are still more parts to fit and they don't fit positively or symmetrically.
    October 2019
Posted by Tanker-Builder on Monday, March 18, 2024 10:02 AM
I have a Question:
 How do you like working on resin as opposed to plastic .Also how about the scale? any problems there?
    October 2019
Posted by Tanker-Builder on Monday, March 18, 2024 10:03 AM
I have a Question:
 How do you like working on resin as opposed to plastic .Also, how about the scale? any problems there?
    October 2020
Posted by Scale-Master on Monday, March 18, 2024 2:26 PM
I like them both about the same.  For thinner parts the styrene is more forgiving/less brittle but overall they work about the same.  You have to use CA or epoxy to cement resin, but I use CA for most of my styrene assemblies so not much different there either.
Scale/size doesn't present any problems for me.  I build 1/8 to 1/87 regularly.  Just detail what ever it is to the scale it is.
fox
    January 2007
Posted by fox on Monday, March 18, 2024 5:23 PM
And you do it very well in all scales too! Bow Down
Stay safe.
Jim Captain
 Main WIP:
    October 2020
Posted by Scale-Master on Wednesday, March 27, 2024 4:31 PM
The engine and rear suspension is pretty much done and much of the cockpit has been detail painted.
The wheels are built too.
The engine cover still fits so it is time to paint the body.
    October 2020
Posted by Scale-Master on Tuesday, April 2, 2024 7:55 PM
I used BMF instead of the kit supplied Mylar for the sides.  It didn't feel like it would conform as well as foil.
I started with the roundel & number decals.  They went on fine.
fox
    January 2007
Posted by fox on Wednesday, April 3, 2024 5:25 PM
W O W!!! Toast Toast Toast
Stay safe.
Jim Captain
 Main WIP:
    October 2020
Posted by Scale-Master on Wednesday, April 3, 2024 7:57 PM
Thanks Jim!
The stripes also went on well which was a little surprising as one of the stripes had a slight fold in it and I fully expected to crack at that point.  They also conformed quite well to the contours including the louvers front and rear.
fox
    January 2007
Posted by fox on Wednesday, April 3, 2024 8:47 PM
Outstanding work on those small cars! Bow Down
Stay safe.
Jim Captain
 Main WIP:
    June 2018
Posted by DRUMS01 on Wednesday, April 3, 2024 10:24 PM
Very nice and great modeling so far....
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    October 2020
Posted by Scale-Master on Saturday, April 6, 2024 6:29 PM
Thanks Guys!
All the decals have been applied and I shot the clear coat.
