This is my first post here, I was hoping someone might be able to help me out with some airbrushing questions.
I have a Iwata hp-cs airbrush and I am working on a 69 Charger. I primed the car with dupi-color auto primer and sanded the car with 44 micron sanding film. I should also point out that this is the first time using an airbrush and the first model ive built in a number of years.
Anywho, i want to do a two-tone color scheme, where the bottom half of the car is silver and the top is black. I used the airbrush and Model Master German Silver Metallic enamel thinned 50/50 with mineral Spirits. Id like to think i put a fairly light coat on, I know i will need several more coats before i can mask off the body line i want and do the top.
My questions are; Its been almost a week since i put that coat of paint on, the paint is more or less dry to the touch but still sticky. I know i need more coats of paint. but should i sand inbetween the coats? Do i need to wait for a full cure to sand? or should i just keep spraying and sand when im done?
Any help would be greatly appreciated Thanks!
