1966 Ford Fairlane GTA
    February, 2003
Posted by midnightprowler on Thursday, December 21, 2017 6:32 AM
No pics here either, whether on the desktop, phone or tablet.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    March, 2012
Posted by Builder 2010 on Thursday, December 21, 2017 7:43 PM
I'll keep trying. I'm using Google Photo to load the pictures since Image Shack was behaving badly.
I have reached the point where the body painting needs to be done. Lacquer is a no-no indoors and it's not good for outside painting now. I did some odds and ends today. Got the battery wired up, finished the door jambs, painted the wheels and taillights, and blacked out all the grills and trim that had black lines in them.
I cobbled some battery connectors out of wine bottle foil. They're a bit crude and oversized, but they convey the feeling. The leads are 28 gauge black iron wire painted red for the positive lead going over to the molded on started relay. I also did some more detail painting in the engine compartment.
So now the engine is completely finished.
I sanded off the excess filler on the door jambs and they're ready for paint. I also found and removed some mold lines on the body. This is ready for paint.
I removed the vinyl wheel centers and built the four wheels. The chrome steel wheels had open spokes and blacked out areas between. I painted the blacked out areas flat black. I actually enjoy doing detail painting. I find it calming.
To black out the open areas of the grill and on some of the trim, I simply used some thinned Tamiya flat black which I let run down the grooves and used a cotton bud to remove the excess from the chrome. If I had some Tamiya panel line color in black I would have used that. I have that product in brown and it wouldn't work.
The last thing I did was use the Liquid Chrome pen to detail the backup light section of the red taillight lenses. The chrome pen was the perfect tool to add some real bright effects to these tiny parts.
So, if I can't figure out how to effectively do the exterior color in the winter, I might put this aside until Spring. I have another kit to build, a Trumpeter 1:350 scale USS Essex. I have some Photoetched leftover from the Missouri project and may be able to detail the Essex without having to buy more. Most of the color for the Essex will be water-based and can be applied in the basement. I'm lobbying the CEO to get a spray booth which would be a wonderful addition to the shop.
    March, 2012
Posted by Builder 2010 on Thursday, January 11, 2018 12:22 PM
With the weather not cooperating and me not having a spray booth (yet... still working on it), I'm starting a new project on a new thread; the 2002 Trumpeter issue of the USS Essex. See you there. When I can spray outside (lacquer-based paint) I'll get back to the GTA.
    March, 2012
Posted by Builder 2010 on Friday, January 19, 2018 4:30 PM
Well... the weather may actually be mild enough in the next couple days to enable me to spray some GTA parts. So to get ahead of this eventuality, I did a few minutes work on the model masking the engine compartment and the inner door panel so I could spray the primer and light yellow outside. It's all predicated on the temps hitting 60 degrees or more. The fender panels actually wrap over that flange in the engine compartment and it's painted body color which accounts for all that masking to expose such a little bit of paint area.
Incidentally, I've switched picture sharing sites and have settled on PostImage which is free, solid, and has no annoying ads (hear that Photobucket!).
Until next time, meanwhile keep tracking my Essex build on the Ships category on this forum.
    June, 2014
Posted by Tanker - Builder on Friday, January 19, 2018 4:47 PM
Uh Oh !
 I don't see a tanker offloading .What scale are you running . I have at least two that need a home .They are H.O. Nice job on both the R/R LAYOUT and the engine .
    March, 2012
Posted by Builder 2010 on Friday, April 13, 2018 7:07 PM
Hi gang! Winter's almost over here in Louisville so I can get back to work finishing the Ford.
Weather was lovely today... a bit windy, but i worked around it and finally got the primer coat onto the Ford GTA. First I needed to make a body clamp to hold it for painting. I know there are commercially available ones, but it's so simple to make one in house. I used a scrap piece of 2X4, and some old coat hangers. After cutting the hangers apart and bending them to a useful shape, I stuck them into the body and got a spacing measurement. I cut some notches in the chop saw and fastened the hanger clamps into the grooves with some self-drilling, star headed wood screws. Those clamps are not going anywhere.
A closeup slowing the clamping method.
It didn't have to be pretty, just functional. And it works great!
I sprayed the body, the separate door, the hood and the little masked area around the fender wells.
I then sprayed some of the Ford light yellow on the fender wells just to test the paint and see how it looks. The color is terrific, very close to my car's color in 1966. The Testor paint is a lacquer (supposedly), but did take several hours to dry. I will have to protect the body from dust during this drying cycle and it means an extended time to do two coats, plus clear coat with sanding/polishing steps in between. It's okay since I'm working on two other projects at the same time.
I'll sand the primer and see if I need a second coat and get ready for the first color coat, but the weather's going to change tomorrow with rain and colder so color will have to wait for a while.
    April, 2005
Posted by BigJim on Monday, April 16, 2018 6:55 PM
I don't know what is going on with your photos, but, the ones above do show up. Most everything before this, back to Dec. 5, shows a minus sign.
    March, 2012
Posted by Builder 2010 on Monday, April 16, 2018 7:37 PM
I don't know either since they're stable on the WW2 aircraft website where I also post the same thread. There's something funny with Kalmbach's site. I had trouble loading the site tonight. Could be related.
    March, 2012
Posted by Builder 2010 on Wednesday, April 18, 2018 5:07 PM
It was warm (80) today and the winds hadn't started up again, so I was able to get the first color coats onto the Ford. I'm not so good with spray can lacquers. I did some light coats on and noted on the instructions on the can that you should wait a couple of minutes to do additional coats. So I hit it again and got a nice color coverage.
I brought it inside to dry and got a good look at it. Coverage is good, but there's some orange peel which I'll sand out. It will then need additional color. According to the Revell Car Finishing Kit that I bought, you should wait one week before sanding the paint. It will remove some color and may require additional coats. I can use some guidance here since this is not one of the things I know a lot about. The last car kits I spray painted was when I was at Michigan State in 1964 and spray painted Revell's Orange Crate candy orange 2-part lacquer in the incinerator room at Bryan Hall. Yes... I actually built some models while in college and thoroughly enjoyed it. I rediscovered them one day when cruising a local hobby shop. I hadn't built anything from when I turned 16 (Cars, girls and guitars). No dust got into the finish. It's a pretty good color match to my 66 GTA.
Is there anything I need to worry about when recoating after the paint is completely cured?
I also sprayed the hood and door in the basement since it took very little paint and didn't smell up the house too badly. They too will need sanding.
I'm going to try and use the Molotow Chrome Pen to chrome the various raised lettering and the wipers. I'm having good luck with this tool and look forward to using it again.
    March, 2012
Posted by Builder 2010 on Monday, April 23, 2018 6:40 PM
It's been a week so I decided to start fine sanding the paint while some paint on the Essex was drying. It was going well with the 2000 grit starting media and then the driver's side roof pillar separated at the lower corner next to the body. This is the side that was drastically cut away when I opened the driver's door. I initially glued it with solvent cement and then some med. CA, but realized that probably wouldn't hold up through the rest of the sanding and polishing steps to come, so I epoxied a small piece of music wire (guitar B string) and will let that set before messing with it again. It might be visible, but it will be strong and I can't chance that it breaks again further in the finishing phase. After this sanding, which did move all the minor orange peel and any included dust, I will have to re-shoot another color coat since it's quite thin at the creases and edges.
