Tyrrell P34 1977 Monaco Grand Prix
    May 2011
Posted by Real G on Tuesday, March 26, 2019 1:27 AM
Thanks Ben, I wish I had your confidence!
“Ya ya ya, unicorn papoi!”
    May 2011
Posted by Real G on Monday, April 8, 2019 5:45 PM
I am so terrible at gloss finishes, and work on the P34 bears this out.  While the Tamiya pure white went on nice and smooth, the blue was another story!
ttps://flic.kr/p/vEaS5x] [/url]P34-042 by N.T. Izumi, on Flickr
https://flic.kr/p/vDeF6N] [/url]P34-043 by N.T. Izumi, on Flickr
So I attacked the blue parts with fine sanding sponges.  The orange peel was gone, but the paint still looked bad.  I had some burn thru at the corners, so more gloss and more polishing is in order.
https://flic.kr/p/vGypVL] [/url]P34-048 by N.T. Izumi, on Flickr
https://flic.kr/p/vMKwJu] [/url]P34-051 by N.T. Izumi, on Flickr
Posted by keavdog on Monday, April 8, 2019 5:57 PM
Ya that white is really nice!  Looks like you got the blue tackled.  I find the burning through so frustrating when it comes to polishing cars.  I'd love any tips there for sure.  This one is going to be a beauty when she's done!
Thanks,
John
    February 2006
Posted by Wilbur Wright on Monday, April 8, 2019 7:23 PM
I recommend the Tamiya polishing compounds for getting rid of the orange peel without risking burn through of edges.  I got them from Hong Kong on Ebay.  I now swear by these.
I've been doing many more cars recently than military subjects and the gloss paint is a steep learning curve.  I've also gone from using enamels to using the Tamiya TS spray cans which dry very quickly, helping to eliminate dust.  These paints are very thin and take multiple coats
Learning to master the wet coats takes a lot of practice.  I have the big 1/12th version of this kit w the photo etch parts, which I am looking forward to building.
Gloss paint is always a great deal more work.  But each model gets better.
    May 2011
Posted by Real G on Tuesday, April 9, 2019 1:12 PM
Yeah gloss finishes have eluded me, so I'd like to conquer that mountain!
And I realized I just committed my first double post SNAFU - the last bunch of pictures were already posted earlier.  Sorry guys, I have been having a bad week.  It sucks getting old.
So anyway, here are some different pics:
https://flic.kr/p/w5F3fL] [/url]P34-057 by N.T. Izumi, on Flickr
The upper cowling had a diagonal separation line, which of course the sponsor logos went through.  So I made a photocopy of the decal sheet and cut the logos out to use as templates to establish where to make the cut in the decals.  It worked well, but I did experience some chipping at the cut edges, which were touched up with paint.
https://flic.kr/p/zw64o3] [/url]P34-071 by N.T. Izumi, on Flickr
https://flic.kr/p/Au7twH] [/url]P34-070 by N.T. Izumi, on Flickr
I had an unusual problem with the clear coat and decals - the clear coat dried with a matte, textured finish only on the decals!  I walked away from the model for a bit, then went back and tried gently polishing the texture down, which worked.  Anyone have that problem?  I have never encountered this phenomenon ever, on any kit.
    June 2018
Posted by DRUMS01 on Wednesday, April 10, 2019 10:18 PM
What brand and type of blue paint did you use?
What was the clear coat that you used?
How long had the decals dried before you sprayed the cleat coat?
They were the Tamiya decals, correct?
    P.S.: I told you that you could pull it out, looks nice!
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    May 2011
Posted by Real G on Wednesday, April 10, 2019 11:58 PM
Ben,
I used Tamiya TS spray paint and clear, on the kit decals.  I may have waited 24 hrs prior to applying the clear coat.  Moisture molecules on just the decals?
    June 2008
Posted by lewbud on Thursday, April 11, 2019 4:53 AM
RealG,
This is a most excellent build you have going. I look forward to seeing it finished.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    May 2011
Posted by Real G on Thursday, April 11, 2019 5:40 PM
Thanks Lewbud!
    June 2018
Posted by DRUMS01 on Friday, April 12, 2019 12:33 PM
RealG, I am not sure, but I had a fairly similar situation using Tamiya clear laquer on an older set of Tamiya decals. The clear laid over the painted areas just perfect, but the decals ever slightly ghosted to a dull finish. When it happened to me I was lightly misting on the clear coat and letting it dry between each application. After the third light mist and then polish it went away too.
My guess is it might have something to do with the age of the blue paint; the polishing of the blue paint; the type of polish used; the age of the decals.
Basically, it seemded like the decals stuck to the model, but not the best "stick". Then the clear coat cure tried to slightly lift them. making them appear dull. By polishing the clear coat you burnished the decal both to the blue and in the clear coat.
Just my guess... Like I said, you pulled it out like I knew you would....
Ben
LAST COMPLETED:
NEXT PROJECT:
    May 2011
Posted by Real G on Friday, April 12, 2019 1:02 PM
Ben,
Actually, the surface of the decals felt noticeably rough!  That was so weird as I canot offer any explanation or even theory as to why it happened.  But it was consistent for all the decals.  The bond to the painted surface was not the issue, as they all glued down tight with no silvering.  But at least when the decals were polished, the texture went away and they took on a glossy smooth finish.
As an aside, the "Koni" shock absorber logos disintegrated when placed on the model; they were on a smaller separate sheet.  Although the artwork crumbled, they left the white printed backgrounds intact, which for some reason immediately bonded to the kit parts!  I had to literally scrape the remaining decals off, damaging the paint.  I was lucky and had an aftermarket sheet with the correct size logos to relace the kit ones.
Shiny cars are really outside of my comfort zone, but I'm slowly getting there.  The next one will be better.
    May 2011
Posted by Real G on Tuesday, April 23, 2019 1:27 PM
So here is what the project looks like as of four years ago as well as today!
https://flic.kr/p/wixrhp] [/url]P34-066 by N.T. Izumi, on Flickr
My goodness, where does the time go...
    May 2009
Posted by Pawel on Tuesday, April 23, 2019 2:14 PM
Hello!
That's a nice publicity shot!
And yeah, doesn't time just fly when you're havin' fun?
Thanks for sharing and have a nice day
Paweł
www.vietnam.net.pl
    May 2011
Posted by Real G on Tuesday, July 19, 2022 8:36 PM
Necro Thread!  Stick out tongue
But that is just the way I am, like a discarded gum wrapper blowing along the road, susceptible to the whims of the ever-changing wind that whispers through my modeling mind.  But yeah, it's time to hit the road and get this project to the finish line.
I finally got the springs replaced by wrapping a pair of 0.020" plastic rods in parallel around a drill bit, then dunking in boiling water.  The pair of rods can be threaded apart when cool, forming two springs with nice, even pitch spacing.  I have found using plastic for the springs makes it WAY easier to taper the ends compared to metal.
The front shocks needed punched discs for the lower end of their brackets to act as stoppers for the springs.  I didn't bother making telescoping struts because I got lazy.  Embarrassed
I need to sort all these little miscellaneous parts out.  It has been so long that I have forgotten what most of the small stuff is for.  Some look kinda ugly, so they will be replaced.  Some of the PE discs might be replaced with plastic, as I like working with plastic versus metal.  Now where are my notes...
The rear spoiler parts have been sanded wherever the clear coat/paint was not smooth.  I got burn thru on the supports, so will need to repaint them before applying the gloss finish coat.
    May 2011
Posted by Real G on Tuesday, July 19, 2022 8:43 PM
I had so much fun with the springs that I looked at my other car kits to see if they would also benefit.  These are the shocks from Hasegawa's 1/24 Lancia Stratos:
I did not notice the ejector pins until after the photo was taken.  Yikes.  They could be trimmed/sanded off, but separate springs and (telescoping) struts would look so much better, especially if the springs are a different color.
Yeah, the Stratos is another kit I really should get to...
    May 2011
Posted by Real G on Thursday, August 4, 2022 5:34 PM
I absolutely STINK at painting, and it really shows!  I sanded down the rear spoiler supports for a third try at rattle can spray painitng.  And it went just as badly as the first two times.  So I sanded them relatively smooth (or so I thought), and ended up with this.
I'm going to try clear coating this mess to see if things start to look better.
    May 2011
Posted by Real G on Tuesday, August 16, 2022 2:24 PM
Still plugging away on this old horse.
I was thinking about how to make small 90 degree connectors, and had a eureka moment to use pin heads.
The Kynar wire insulation is stripped at the connection point and wrapped around the pin for a fairly secure join.
Other wiry bits continue to be added.
And the dreaded slog of polishing bits and pieces continues.
I REALLY stink at this!
I seriously need to get out the airbrush and finish painting the little detail parts so that the engine and suspension can come together.
    May 2013
Posted by Greg on Tuesday, August 16, 2022 3:26 PM
This is a great WIP, G.
The bodywork looks great, despite your hiccups.
Sort of a side note, the next thing I need to do on my Lotus is paint the rear set of springs, which unlike the front springs, will be visible. Every time I go down there to get started, I think about your scratchbuilt styrene rod springs and get frustrated and find something else to do!!! They are so cool. (but hey, it got me out for a walk today, so that's good)
Oh, and I have those awful ejector pin nubs on the Tamiya Lotus springs, too.  They are facing in, won't be seen, and I'm not going to try to whittle them into shape. Propeller
    August 2007
Posted by DUSTER on Wednesday, August 17, 2022 12:36 AM
Really like wat you have done here. Your changes are a major plus to the look.
Steve
    March 2007
Posted by armornut on Wednesday, August 17, 2022 11:09 AM
   Keep up the slog Real G, I may dig my 12th scale out and smash some things together. I've seen your magic, it will be great.
we're modelers it's what we do
    March 2012
Posted by mustang1989 on Wednesday, August 17, 2022 11:40 AM
I can't believe that I haven't commented on this thread since you've started 'er back up. For me, airbrushing with a Badger 350 is the way to go in regard to smooth paint finishes. I mean, you still will get a little orange peel but there's just so much better control of the paint. I use rattle can paint alot but have much better results when I decant it and shoot it through the 350.
Looking good so far pal. Great lookin' details and just love the idea of using plastic for springs.
 Forum | Modelers Social Club Forum (proboards.com)
    May 2011
Posted by Real G on Wednesday, August 17, 2022 2:45 PM
Greg - Would you like me to do a step-by-step photo shoot of how to make the springs?  A friend stopped by the other week and in 3 tries got a complete set of useable springs.  If this technique is new to people, I'd be glad to post pics - especially if it infects minds to try it out!  Spreading cooties is what the hobby is all about.  Stick out tongue
Armornut - I would absoluely LOVE to see you build the 1/12 Tyrrell!  It would be inspiration for me to start mine.  I have to be careful about not buying any more 1/12 F1 kits, as they demand super-detailing and a serious investment in time (I have too many other weird projects that need to be built).
Duster and Mustang - Thank you for the kind words!  Gaaah, I have to push myself and get across the finish line.  Everyone's support definitely helps - thanks guys!  Yes
    March 2012
Posted by mustang1989 on Friday, August 19, 2022 6:42 AM
I'll tell you what....I'd sure appreciate a step by step on those springs, that's for damn sure.
Bring it.
    May 2013
Posted by Greg on Friday, August 19, 2022 7:45 AM
Real G
mustang1989
Bring it.
I'm with Joe, I think a step by step would be a plus for the forum.
I won't be trying it on this build, though. A different way of doing my rear springs came to mind the other night, and I tried it yesterday. It's not nearly as cool as your scratch built spring, but I'm happy. (will post more in the F1 GB thread later on).
    May 2011
Posted by Real G on Friday, August 19, 2022 12:54 PM
Right on gents, I'll post a how-to.
I made some brake cooling hoses last night, which were simpler to do as they did not require the parallel rod method.  But using a finer rod resulted in shorter hoses!  They are just long enough to do the job.
I have solder that is the correct diameter to go inside the hoses to hold their shape, but might change to a more pliable core later on.  I'll have to see if the solder is too difficult to bend to shape (it's silver solder, so it's stiffer than the regular stuff).  Oh duh, lightbulb moment - why not just get the bendy regular stuff?  Time for a trip to the hardware store.  Or better yet, a dig through the materials box.
I'm trying to get the model done for the Best of the West contest in Lost Wages next week Saturday, so apologies if I begin to sound incoherent.  I used to be able to hold it together for about 2 weeks with little sleep in order to finish a model, but not anymore.  Sad
Pics to follow, including a report on the contest.
    May 2013
Posted by Greg on Friday, August 19, 2022 1:03 PM
Real G
Begin to?
Big Smile
    May 2011
Posted by Real G on Friday, August 19, 2022 1:10 PM
Greg
Real G
Begin to?
Big Smile
    May 2011
Posted by Real G on Monday, August 22, 2022 12:55 PM
A busy weekend:
Got the shocks built up, along with hoses for the front brakes.
The yellow brake lines are in place - and lend a nice splash of color.
Banging together the engine, as well as test fitting the spoiler supports.  It's a good thing I checked too, as the part at the end of the transmission was slightly skewed and needed to be pushed slightly away from the tranny before the spoiler supports would fit and set straight.
Argh, painting the PE went badly, AND the reinforcing strips that go on the front spoiler were too long.  So...  I had to cobble substitutes up using sheet plastic.
I feel better now though.
And now a sneak peek with it all loosely set in place.
Oops, I just noticed the rain tires are on backwards!
    May 2011
Posted by Real G on Wednesday, August 24, 2022 11:41 PM
I am doing it to myself again - less than 24 hrs to flying out and here I am madly dashing along.  I hate myself at times.  But I suppose it is the only way to force myself to do new things nowadays.
No photos as we are in the "blackout" phase (i.e. no proper computer), but I added a seat harness for the first time and am piping up the engine.  I also cut some windows and fitted them from the outside.  I am having problems running the front wheel cooling hose, as it wants to kink.
Well, no sleep for me tonight lads!  I'll pack in the morning.  And photos of the (hopefully) completed P34 as well as a report from the IPMS Best of the West will follow.  Now where was that can of pure liquid Schwarz...
    May 2011
Posted by Real G on Saturday, August 27, 2022 9:34 AM
The IPMS Best of the West is happening at the Orleans Hotel in Lost Wages today. The Tyrrell is sorta finished and ready to go.  At least I didn't do any construction in the hotel room!
Crash course building the kit taught me a lot about the ins and outs of F1 modeling, which will be applied to the Brabham BT46B "suction fan car" for the F1 GB.
Even though it was frustrating to cram together the Tyrrell, my love for 1970s era F1 machines is stronger than ever.  I think I'll watch "Rush" when I get back home.
