OK, this thing has been sitting for quite a while (many months) due to the paint fighting with itself on the main body. Most of the car is done; I just need to finish the body. A few times I sanded out the wrinkles (on the right rear) and touched up the paint only to have the issue come back a month or so later, so I stopped touching it up but continued to sand out the wrinkles as they appeared every few months. I thought I had won the battle back in April 2012, but sadly the same thing happened a little while after I painted it once again.
I continued to sand it as problems manifested, but I noticed it has been pretty stable all year.
It’s been about 6-8 months since I last sanded the problem area and it looked the same as when I last checked.
First I had to blend the white base in, and I found by tinting white primer with yellow and pink I could apply less paint and get an even blendable base. Then I started building up the Fluorescent Red.
You can see what I painted yesterday does not match, (it is too pale and lacking vibrancy, and not 100% uniform), but it is all the paint I can apply this round.
Today I built up some more TS-36. Still not there, but getting closer…
It still needs another round of paint, but I’ll probably let this dry for a while to make masking easier…
